22 rims for 08 cts4
Results 1 to 3 of 3
2008-2013 Cadillac CTS Appearance Mods Discussion, 22 rims for 08 cts4 in Cadillac CTS Second Generation Forum - 2008-2013; Rims Brand: Lexani Model: LSS-10 Color: 2 Tone Machined and Black Center, Chrome Outer Size: 22" x 9" Offset: Front ...
    dsekhon is offline Cadillac Owners Member
    Automobile(s): 2008 CTS4 DI
    Feb 2012
    Vancouver
    18
    22 rims for 08 cts4
    Rims
    Brand: Lexani
    Model: LSS-10
    Size: 22" x 9"
    Offset: Front - +30. Rear - +15
    Bolt Pattern: 5 x 114.3
    just wondering if these would fit and if they would what tires are recommended
    SLICKNICK54 is offline Cadillac Owners Member
    Automobile(s): 2008 cts 3.6
    Nov 2011
    Canfield, Ohio
    31
    21
    Re: 22 rims for 08 cts4
    We are 5x120 / 5x4.5 bolt pattern
    And since you are an AWD , you will need same offset all way around I believe
    Char T A's Avatar
    Char T A is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS4 Sedan
    Apr 2009
    38
    103
    You don't need same offset with AWD but you need same diameter tires overall. The +15 rear is not going to work unless you want it to stick out of the fender on a sedan. I think for a 9" wheel you need +25 or higher. Also as mentioned bolt pattern is wrong.
    No 22s yet but here are some 20" setups.
    http://www.customwheeloffset.com/whe...e=&suspension=
