need rear tire size help
Results 1 to 2 of 2
2008-2013 Cadillac CTS Appearance Mods Discussion, need rear tire size help in Cadillac CTS Second Generation Forum - 2008-2013; I am getting rims sizes 20 x 9 fronts and 20 x 10.5 rears. Car will be lowered 1.4 front ...
    is250sp's Avatar
    is250sp is offline Cadillac Owners Enthusiast
    Automobile(s): 2012 CTS Coupe Premium RWD
    Oct 2012
    652
    I am getting rims sizes 20 x 9 fronts and 20 x 10.5 rears. Car will be lowered 1.4 front and 1.3 rear. The front tires will be 245/35/20. I want the rear tires to match up with the fronts so should I go with 265/35/20 or 275/30/20? If not what size do you recommend?
    Char T A's Avatar
    Char T A is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS4 Sedan
    Apr 2009
    38
    103
    Re: need rear tire size help
    I went with 295/30 and 255/35. I have an AWD and they are perfect and within <1% diameter. I swear by them. Check mine out http://www.customwheeloffset.com/whe...ck-custom-rims
    Quote Originally Posted by is250sp View Post
    Here is another one with the same front as you, lowered and he did 275/35 but i didn't run the diameters to verify if they are same size.
    http://www.customwheeloffset.com/whe...22-custom-rims
