CTS-V bumper upgrade
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
2008-2013 Cadillac CTS Appearance Mods Discussion, CTS-V bumper upgrade in Cadillac CTS Second Generation Forum - 2008-2013; If think I have read all the threads about doing the V bumper swap. However, no where have I found ...
    ssrodder is offline Cadillac Owners Member
    Automobile(s): 12 CTS AWD, 1948 conv, 06 sts4
    Apr 2006
    NE PA
    28
    If think I have read all the threads about doing the V bumper swap. However, no where have I found the part numbers of the required pieces. I have already purchased the bumper and grilles. My local Caddy parts guys are no help. I also pickup a Vin number for a newer Caddy V, but I need the following part numbers.
    Left brake duct. Right brake duct (2 pieces). Left and right front half inner splash shields.
    Front V bumper absorber.
    Any and all help wouod be appreciated.
    is250sp's Avatar
    is250sp is offline Cadillac Owners Enthusiast
    Automobile(s): 2016 CTS 3.6 Premium RWD, 2012 CTS Coupe Premium RWD (sold)
    Oct 2012
    696
    Re: CTS-V bumper upgrade
    fog lights #10335108
    brake cooling ducts #25796005, #25858812, #25796006
    fender liner front halves #25796003, #25796004
    fog light bezels #25863012, #25863013
    absorber #20782127
    lower bumper protector #25882978
    headlamp washer nozzle caps #25793667, #25793666
    Apr 2006
    NE PA
    28
    Thank you. Much appreciated.
    Mistercoffee2's Avatar
    Mistercoffee2 is offline Cadillac Owners Enthusiast
    Mar 2012
    Houston TX
    516
    The shinny fog light rings do not come with the fog light bezels. My dealer wanted $118 each, offered them to me wholesale for $80 each. I got them from http://www.gmpartsonline.net
    Makes me sick!!!
    25863011 BEZEL 2 $0.00 $52.81 $105.62
    Sub Total $105.62
    Shipping method - UPS Ground Shipping $14.80
    Handling Fee $0.00
    Tax $8.71
    Total $129.13
    If you need additional Push Clips these are an exact match. http://www.clipsandfasteners.com
    Item name: PAS1860-25
    Item description: 25 Push Type Retainer GM 21030249
    Mar 2012
    Houston TX
    516
    Returning my fog light rings. This may be a better way.
    http://www.superbrightleds.com I ordered only one to play with and I like them.
    1 AEPC-x: Angel Eye Plastic Covers AEPC-80: 80mm Diameter $1.95
    1 AEx-x-BK: LED Angel Eye Headlight Accent Lights - Black Circuit AE80-NW48-BK: 80mm Diameter Natural White $11.95
    SubTotal: $13.90
    Sales Tax: $0.00
    Shipping: $2.99
    TOTAL: $16.89
    Photo 1 is OFF, 2 is 6 volts to keep it from being blown out as in 3 with 12 volts. 4 & 5 show the light ring, cover and fog light ring.
    I'm going to use 2 of these from the same site. Looks much the same, Very bright.
    2 AEx-x-COB: LED Angel Eye Headlight Accent Lights - COB AE80-NW81-COB: 80mm Diameter Natural White $26.95
    2 AEPC-x: Angel Eye Plastic Covers AEPC-80: 80mm Diameter $1.95
    SubTotal: $57.80
    Sales Tax: $0.00
    Shipping: $2.99
    TOTAL: $60.79 Less then half the price of rings.
    Guess I will glue it on somehow and hook it to be on with ignition so they are on all the time.
    I don't think heat will be a problem with the fog lights. If is is I will replace the fog lamps with LED parts. These ring are 80mm. I think the 100mm rings would look good around the HID's but I fear the heat would kill them. May do some testing.
    Thoughts?
    JusJZ is offline Cadillac Owners Member
    Automobile(s): 2011 CTS Couple Manual
    Jul 2012
    33
    27
    This mod looks cool. I have a 3.6 coupe with a bit different fog lights than the V, in a chrome housing. Do you think I could do this same halo fog light Mod on mine? I have HID head lights, should I get the Cool White or natural white to match? How do you connect to power?
    Mar 2012
    Houston TX
    516
    it's a work in progress now. I'm not sure how the color of the COB LED Angel Eye will look with the HID headlights. In fact I have never seen one as mine have not arrived yet. The one I'm playing with uses 5050 SMD LED's. I do not think the 80mm rings will work on the non V. Maybe the 60mm will. Get one and play.
    As for power, I want the rings to be ON with accessory/ignition so they will connect to an accessary circuit. Not sure where yet. As my bumper mod progresses I will post photos of the results.
    My apologies to ssrodder for hijacking his post on bumper swap with Angel Eye talk.
    EDIT: JusJZ, I measured my CTS Sedan fogs and 60mm will work and they make it in COB LEDs and 5050 SMD. I will start a post on these rings when I receive the COB's
    Apr 2006
    NE PA
    28
    No problem. Every time I read some new info that I might be able to use I consider it a big plus. Keep bringing it on.
    Mar 2012
    Houston TX
    516
    Quote Originally Posted by ssrodder View Post
    Thanks. I'm doing the bumper swap of course and plan to take my bumper in for paint tomorrow. Then I will take my car out of action, remove the bumper and do some work on the headlight lens. Got some sand damage that I will try to sand out.
    I would like my fog light bezels to be painted body color (Black Raven) and I don't know if they can be painted. I have never seen them other then the odd looking gray/green color.
    I did not buy the stock V splitter. For now I plan to do a home-brew splitter that is a little more aggressive then stock. Sort of like this KPE but different, maybe with the splitter all the way across the front:
    Jul 2012
    33
    27
    Mistercoffee2...thanks for the info! I look forward to seeing what you come up with. I did start a thread called, Halo Fog Lights:
    http://www.cadillacforums.com/forums...foglights.html
    If you want to post about your halo fogs there...
    Jul 2012
    33
    27
    Mistercoffee2, Any update on your halos?
    Mar 2012
    Houston TX
    516
    Quote Originally Posted by JusJZ View Post
    Yes, I had to overcome two problems, Rocks and Water. I started by making a cover for the LED rings which should solve both problems. I wanted a clear cover so could not use the defusing cover from SuperBrightLED. I have not assembled it yet. As you can see from the photo, too much of the Fog Light bezel is visible through the halo. I'm making another black plastic mask to go behind the halo with a smaller aperture to hide stuff.
    Side benefit is the Fog Light Lens is protected from rocks also. I will use HID bulb in Fog Light. I'm installing a relay to turn off the halo when the Fog Light is on.
    I'm also finishing up the V bumper swap where I followed the lead of SFV41901 and painted the outer headlight bezel body color (Black). (TO: SFV41901. Dude, getting that rubber sealer out of the headlight was a bitch! After two days of hacking at it I got a Heatgun.)
    http://www.cadillacforums.com/forums...headlight.html
    I also painted the yellow reflector so I will have no front side marker until I find another way to do one. Thinking about a 5" 25 LED strip incorporated horizontally into the left and right ends of the front splitter I'm working on.
    Major changes to the DRL and a 100MM halo around the HID Headlight. I know some will not like the yellow colored halos. It's yellow only when off (looks nice with my black car) and is Natural White when on.
    More to come.
    Mar 2012
    Houston TX
    516
    I'm really excited today because I just a purchased a CTS-V hood and rear bumper (used) and the deal includes repaint.
    Look like my car will be down for another couple of weeks.
    The chrome strip, insulator and rubber seal for the hood is another $230. (sic) One really has to have no other life to do this MOD stuff.
    Does anyone know if the part number is the same for the V and non-V hood seal and/or insulator?
    Did I tell you I'm 70 years old. Still nuts about cool cars like the CTS and the one in my avatar. (wish it were mine)
  16. #14
    Mar 2012
    Houston TX
    516
    DRL, a work in progress.
  17. #15
    Jul 2012
    33
    27
    That headlight halo looks awesome! Look forward to everything on the car. So for your fogs, you want the Halo off when the fog light is on? Will the relay turn off the Halo automatically when you turn the fog light on? Or did you install the relay just to have the option to do both?
  18. Remove Advertisements
