DRL LED Mod Problems
Results 1 to 5 of 5
2008-2013 Cadillac CTS Appearance Mods Discussion, DRL LED Mod Problems in Cadillac CTS Second Generation Forum - 2008-2013; Hey guys, So I did the LED mod for my DRL's, I noticed this problem start to occur about a ...
    250motorsportz's Avatar
    250motorsportz is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 ATS 2.0T; 2016 CTS 3.6L
    Jan 2007
    Vancouver
    1,299
    Hey guys,
    So I did the LED mod for my DRL's, I noticed this problem start to occur about a month after the install.
    Driver side DRL LED turns completely off about 50% of the time. If I flick on my fog lamps, the driver side DRL will kick on but will sometimes turn off again.
    Clearly the bulb isn't burnt out, I can't see this being a wiring (loose wire) problem. I was thinking something to do with the power/watts the DRL's get? I know LED's consume less power but I'm stumped here!
    Anyone have this problem before? I'm waiting for my 6000K D1S bulbs to come in and I'm gonna swap out the DRL LEDs with a new set to see if the problem consists.
    I also ran a jumper from the DRL fuse to my LED strip that I put behind my grill that luminates the upper and lower grill so now the DRL's run at night aswell sort of like parking lights.
    **This was just done today and isn't what is causing my driver side DRL to turn off**
    FBaby is offline Cadillac Owners Member
    Automobile(s): 2008 CTS4 DI
    Dec 2012
    3
    Re: DRL LED Mod Problems
    I know my Jeep needed resistors wired in...Not sure if the CTS needs them as well!?
    agreif is offline Cadillac Owners Member
    Automobile(s): 08 CTS DI AWD
    Jun 2009
    95
    ever figure this one out?
  5. #4
    Hammerhead100's Avatar
    Hammerhead100 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS Performance Sedan
    Sep 2012
    South Carolina
    160
    No problems so far with mine. Don't think resistors are required.
  6. #5
    JoeEXT's Avatar
    JoeEXT is offline Cadillac Owners Fanatic
    Automobile(s): 08 CTS4
    Oct 2003
    Boston, MA
    103
    Hammerhead100....I wanted to do this mode but heard similar issue here with 1 of the drl's. What led are you running and how long have you had them? Thanks
  7. Remove Advertisements
