Wheel cleaning help
Results 1 to 8 of 8
2008-2013 Cadillac CTS Appearance Mods Discussion, Wheel cleaning help in Cadillac CTS Second Generation Forum - 2008-2013; Im almost embarrassed to be positing this but heres how it goes: I purchased the dupli-color tire shine coating and ...
    arw1510 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
    Oct 2008
    1,229
    Wheel cleaning help
    I purchased the dupli-color tire shine coating and used it on my car. Now as always when spraying tire shine on the tires, its nearly impossible not to get any on the wheel itself or over spray on the body. My problem is that where it dried on the wheel wont come clean. It honestly feels like its painted on. I have to scrape with my nail to even remove a little bit of it.
    Does anyone have any recommendations at all as to what would help me clean my rims?
    Ive tried a few of the wheel cleaners that i had and its still not helping much. I have the 19 in polished aluminum wheels if that helps.
    The stuff works good on the tires, but the tires need to be absolutely dry, if wet it dries brown. and dont think about using it on plastic trim.
    alex08cts-di is offline Cadillac Owners Member
    Automobile(s): 2008 cts di
    Aug 2010
    26
    89
    Re: Wheel cleaning help
    May have to use a wax or wheel Polish to try n buff it out a lil becareful not to use something that may harm the finish on the wheel
    Hammerhead100's Avatar
    Hammerhead100 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS Performance Sedan
    Sep 2012
    South Carolina
    160
    The wheel is clear coated. Be careful. I think I would find another tire dressing
    May I suggest Optium Opti-Bond Tire Gel
    http://www.detailedimage.com/Optimum...P283/32-oz-S1/
  5. #4
    Getch78 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS 3.6DI
    Jun 2011
    PA
    119
    Duplicolor's site mentions rubbing alcohol to 'easily' remove any over spray. Sounds like a PITA, good luck!
  6. #5
    Bandit1's Avatar
    Bandit1 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 ATS 3.6 RWD Premium
    Oct 2008
    Ashburn, VA
    494
    Recommend using 3M Adhesive Remover for the over spray removal. Then follow that up with a polish/wax of your choice. Also recommend you stop the use of tire dressing sprays. I use Eagle One A2Z All Wheel and Tire Cleaner to clean the tires followed-up with Zaino Z-16 Perfect Tire Gloss and either Zaino AIO All-in-one or REJEX on the wheels and lugs.
  7. #6
    Oct 2008
    1,229
    the rubbing alcohol tip seemed to work better, still going to require a lot of elbow grease to get that back to what they should be. Ill try the adhesive remover too
  8. #7
    rgauchey is offline Cadillac Owners Member
    Automobile(s): CTS
    Aug 2011
    Wixom, Michigan, United States
    69
    74
    I use one of these wheel shields. Covers the wheel while spraying the tire...........http://www.zaneswheelshield.com/about.html
  9. #8
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    8,731
    I hand apply with a special sponge. I use Griot's dressing and apply it directly to the Griot's tire sponge.
  10. Remove Advertisements
