Those Rear Reflectors - Can They Be Lit??
Results 1 to 12 of 12
2008-2013 Cadillac CTS Appearance Mods Discussion, Those Rear Reflectors - Can They Be Lit?? in Cadillac CTS Second Generation Forum - 2008-2013; I just looked at the rear reflectors on my 2011 Sedan. You know, the one's at the lower rear of ...
    UR LZN is offline Cadillac Owners Member
    Automobile(s): 2011 CTS AWD
    Sep 2011
    8
    I just looked at the rear reflectors on my 2011 Sedan. You know, the one's at the lower rear of the car. They are true reflectors and not just lamp housings without wiring. Anyone convert these to actual lamps? I can do the wiring but need to know where to get the housing. I'd like to wire it to my CHMSL - especially since my CHMSL now has a flasher, then solid-on module.
    Also, my son modified the reflectors on his Grand Cherokee - it REALLY gets the attention of the person behind you!
    So, any helkp on converting those reflectors to an actual lamp housing?
    Deucedog is offline Cadillac Owners Member
    Automobile(s): 2010 CTS 4
    Nov 2010
    Central NJ
    Re: Those Rear Reflectors - Can They Be Lit??
    I'm looking to do the same thing. I did see somewhere last year that the European model has a different valance panel the includes red lighting. However, the lights are more to the middle of the valance as opposed to the outsides. I'm trying to search for it now. If you find the link, let me/us know please.s1_RearFogLights.JPG
    Nov 2010
    Central NJ
    I'm looking to do the same thing. I did see somewhere last year that the European model has a different valance panel the includes red lighting. I'm trying to search for it now. If you find the link, let me/us know please.
    TrimThis is offline Cadillac Owners Fanatic
    Automobile(s): 2011 TG CTS Coupe
    Dec 2010
    South West
    200
    Mine are tinted along with the rest of the tails, but I like that look. I would think you could purchase from Cadillac. Good luck and see if they will fit the coupes also.
    Sep 2011
    8
    My son has a Jeep Cherokee with a similar situation - he found a wiring kit making it plug-n-play - it looks Awesome! I found a set of stop-light LED module (running and stop) that just fits. I'll need to punch a small hole in the valance for the wires and for mounting, then wire it to the talis... That should do it!...
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,779
    Quote Originally Posted by UR LZN View Post
    How about so pictures of the parts and install. thanks
    FBaby is offline Cadillac Owners Member
    Automobile(s): 2008 CTS4 DI
    Dec 2012
    3
    The SRT8 has an actual light housings while the CTS just has reflectors! It can not be done unless you fabricate a custom housing for it or find something to use instead...On the plus side, there is holes already there so you wouldnt have to drill!
    rocketeer's Avatar
    rocketeer is offline Cadillac Owners Member
    May 2006
    80
    Check with Luke from Lindsay. He got me a pair earlier this year for my V sedan. They are European rear fog LED lamps that mount right in the fascia.
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,779
    Did you have to buy the European valance as well, it looks like it has the same reflectors as US models and the rear fogs are in a different location.
    rocketeer's Avatar
    May 2006
    80
    I am using the original valence I'm not even sure about a European Valance. They will actually replace the reflectors that are in the valence. The multi function switch stalk on the steering column is different for the Euro version as it has a seperate switch function just for the rear fogs. I am not changing it I will wire the lamps to a seperate switch or to the front fog switch.
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,779
    The pictures of the European rear fog lights show them to be longer (wider) so I'm wondering how these simply replace the US spec reflectors. Do you have the part numbers? thanks
    rocketeer's Avatar
    May 2006
    80
    My bad I mis-spoke. They directly mount where the existing mesh is. I have seen pics of a set that were mounted behind the mesh which is what I am planning to do. I will send part no's when I get home tonight.
  15. Remove Advertisements
