Sedan CTS Vossen CV3s matte graphite on black - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 51
Like Tree7Likes
2008-2013 Cadillac CTS Appearance Mods Discussion, Sedan CTS Vossen CV3s matte graphite on black in Cadillac CTS Second Generation Forum - 2008-2013; Originally Posted by Char T A I like them better every day. 3000 miles and no issues. Be sure to ...
  1. #31
    eborunda's Avatar
    eborunda is offline Cadillac Owners Fanatic
    Dec 2011
    123
    Quote Originally Posted by Char T A
    I like them better every day. 3000 miles and no issues. Be sure to order shorter lug nuts for rears though so they don't stick out. I had them swapped to shorter last week.
    Where did you order the lugs from ? I just had my CV2 s installed and like you said the rear ones stick out
    Thanx
  2. #32
    Char T A's Avatar
    Char T A is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS4 Sedan
    Apr 2009
    38
    103
    With the deep concave on rears the standard lug nuts were flush on fronts and stuck out on the rears so shorter lugs sit in the wheel a little better.
  3. #33
    eborunda's Avatar
    Dec 2011
    123
    Did uou replace the nuts or just shorter studs ?
  5. #34
    Char T A's Avatar
    Apr 2009
    38
    103
    I did just nuts and they look pretty good. Not flush like fronts but close
  6. #35
    Char T A's Avatar
    Apr 2009
    38
    103
    Re: Sedan CTS Vossen CV3s matte graphite on black
    Quote Originally Posted by Ksmythe95 View Post
    ill post my pics with the 10.5 this weekend. Also i have AWD and I dont have any issues with the staggered set up. I have been running for 6 weeks no issues and i drive ALOT for work.
    Can you tell us your offsets for this set up?
  7. #36
    1AggressiveFleet's Avatar
    1AggressiveFleet is offline Cadillac Owners Member
    Automobile(s): CTS
    Nov 2013
    1
    sorry to revive an old thread here but let me just make sure i am correct im looking to order the cv1 and im looking to do 20X9 +35 and 20X10.5 +42 what offsets are you running
    Gomaz likes this.
  8. #37
    GProdigy's Avatar
    GProdigy is offline Cadillac Owners Fanatic
    Automobile(s): cts
    Aug 2011
    29
    320
    I have CV1's on mine...20x9 all around. b/c when i called they didn't make them 20x10.
    10.5's will poke out a little...
    if u need exact offest info just call vossen.
    the CV3's can do 20x10
  9. #38
    OceanLad is offline Cadillac Owners Member
    Automobile(s): 2010 CTS Wagon 3.6 AWD Premium
    Nov 2013
    Baltimore, MD
    44
    27
    Your car is gorgeous. One of the best looking CTSs I've seen, V, Coupe, Wagon or otherwise.
    Well done!
  10. #39
    json3144's Avatar
    json3144 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS4 Coupe Black Ice
    Jan 2011
    St Louis MO
    35
    83
    Quote Originally Posted by GProdigy
    I have CV1's on mine...20x9 all around. b/c when i called they didn't make them 20x10. 10.5's will poke out a little... if u need exact offest info just call vossen. the CV3's can do 20x10
    Can you update me on what suspension setup you're running?
    Thanks
  11. #40
    GProdigy's Avatar
    Automobile(s): cts
    Aug 2011
    29
    320
    Quote Originally Posted by json3144 View Post
    Thanks
    Im running BC coilovers...
    They come really low even at their highest setting but i like the stanced look. Right now I have the front a little higher than what you see in the picture i posted just to make sure i dont mess up the fender if i hit a bump turning.
    I highly suggest getting someone who is experienced to install coilovers. I went to a shop where the guys misleadingly said they knew what they were doing and they totally screwed it up and the ride was bouncy as helll..
    LUCKILY... BC racing is located here in Orlando so i just went to their shop and the fixed it with pretty good customer service.
    Now it rides smooth as stock with a lower stance and better handling.
    H&R's sit flushed in the rear but have some space in the front slightly lower than stock
    I originally had H&R springs which looked and drove great. But the only way to get the car look i wanted was with coils or bags.
  12. #41
    json3144's Avatar
    Jan 2011
    St Louis MO
    35
    83
    Im running BC coilovers... They come really low even at their highest setting but i like the stanced look. Right now I have the front a little higher than what you see in the picture i posted just to make sure i dont mess up the fender if i hit a bump turning. I highly suggest getting someone who is experienced to install coilovers. I went to a shop where the guys misleadingly said they knew what they were doing and they totally screwed it up and the ride was bouncy as helll.. LUCKILY... BC racing is located here in Orlando so i just went to their shop and the fixed it with pretty good customer service. Now it rides smooth as stock with a lower stance and better handling. H&R's sit flushed in the rear but have some space in the front slightly lower than stock I originally had H&R springs which looked and drove great. But the only way to get the car look i wanted was with coils or bags.
    Thanks for the feedback. I thought I read elsewhere that's what you had. I am running Eibachs with almost 2 coils cut
    Look = amazing
    Ride = shit
    After my research I think the BCs are the way I'm gonna go too
  13. #42
    GProdigy's Avatar
    Automobile(s): cts
    Aug 2011
    29
    320
    Look = amazing
    Ride = shit
    yea man..a cadi has to ride cadi smooth...
    again make sure when u get them that a shop who's had experience with BC coilovers does it... to save you headache.
    OceanLad likes this.
  14. #43
    CarlosZ06's Avatar
    CarlosZ06 is offline Cadillac Owners Member
    Automobile(s): CTS Coupe 2011 / Z06 C5
    Oct 2013
    GDL, Mexico!
    33
    damn! they look awesome!
  15. #44
    GProdigy's Avatar
    Automobile(s): cts
    Aug 2011
    29
    320
    o yea...json3144
    if your going to get coilovers..make sure they throw in the Damping extenders for the rears...
    so that you can adjust the damping without removing your rear seats...
    the dampers in the front are under the hood and extremely easy to adjust..
    its should be $40 or free with the set...
    current setup pic :iphone:
  16. #45
    json3144's Avatar
    Jan 2011
    St Louis MO
    35
    83
    So I ordered the BC coilovers new from them, got the shop ready to install today and it appears they sent a setup for a RWD CTS, I have an AWD indicated in my order to them.... Is yours RWD or AWD?
    of course they are closed today, Saturday
    Thanks
  17. Remove Advertisements
