Black Out Headlight Mod...
Page 1 of 4 1234 LastLast
Results 1 to 15 of 46
Like Tree11Likes
2008-2013 Cadillac CTS Appearance Mods Discussion, Black Out Headlight Mod... in Cadillac CTS Second Generation Forum - 2008-2013; Thought I would put document my adventure in blacking out the headlight housing. It requires heating the headlight in the ...
    NathanScott is offline Cadillac Owners Member
    Automobile(s): 2009 CTS V
    Aug 2011
    San Antonio, TX
    42
    40
    Thought I would put document my adventure in blacking out the headlight housing. It requires heating the headlight in the oven and you run the risk of cracking the lens. This was put together to show the process I went through and do no take responsibility if you damage your headlight doing this.
    Start off by removing the bumper...
    Tools to remove the clips
    Remove upper cover
    Turn wheels to right and remove 3 clips on left wheel well
    Pull front of fender out some to remove 10mm bolt
    Long extension helps
    Turn wheels to left and remove 3 clips and 10mm bolt
    Protect the paint and headlights
    Remove 2 10mm bolts in center and 2 clips at edge
    Pull front bumper foward to expose the headlight washer on left
    Remove white clip so the hose can pull off
    Same for right washer
    Merge likes this.
    Aug 2011
    San Antonio, TX
    42
    40
    Re: Black Out Headlight Mod...
    Tape the hoses up out of the way. They will leak if left on ground.
    Pull ends of bumper out on left and right side
    Pull the bumper out to release it. Make sure you have something on the ground to protect the bumper. Once the bumper is on the ground, remove the running light connectors left
    And right
    Remove the hose from the clips on bottom of bumper
    Bumper is off now!
    Remove the 2 10 mm bolts on side of headlight
    Remove on 10mm not on bottom
    Remove plut on bottom of headlight
    Headlight is out!
    Remove 3 7mm bolts holding the bracket on
    Remove all the t15 torx screws around the headlight
    Now the fun part...baking the headlight. Heat oven to 215 and once to temp, put light in for 10 minutes
    Use gloves to remove the light and start working the corners up. You might have to put the light in for another 5 minutes
    Seperate the lens and remove 2 electrical connectors
    Remove the T15 torx on back of chrome housing
    Merge likes this.
    Aug 2011
    San Antonio, TX
    42
    40
    Here are a few more pics of the process of putting back together
    Heat up the remaining headlight glue with a heat gun
    Use needle nose pliers to pull off all the glue
    Put lens assembly together
    I didnt get a pic of the glue, but used DAP black silicone. Apply in the channed evenly and install the lens assembly and screw down.
    A little preview of it put together.
    Install lights and put bumper on.
    Merge likes this.
    Aug 2011
    San Antonio, TX
    42
    40
    Before...
    After...
    I tried to take some more pictures in the shade to see if I could get rid of some of the glare. I will try to take some more picture later in the evening with my camera.
    dqw1, dqw1, Houdini and 9 others like this.
    Ste_V_e is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Nov 2011
    279
    Badass. Nice write up.
    Purple87SS is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Black Raven CTS-V, 1987 Turbo Buick WE4
    Dec 2011
    244
    Look awesome. I like the carbon fiber look on the inside of the lamps too. But I'd be afraid of moisture in the lamp after a while.
    STS_Chiller's Avatar
    STS_Chiller is offline Cadillac Owners Fanatic
    Automobile(s): None
    Jun 2010
    57
    136
    mmmmm baked headlight!
    Nice write up.
    dqw1's Avatar
    dqw1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    Apr 2005
    Madison, AL
    55
    2,018
    This type of thread should be a sticky or something like that for appearance mods.
    StealthViggen's Avatar
    StealthViggen is offline Cadillac Owners Fanatic
    Mar 2005
    280
    Great work man! I'll be doing this over the summer for sure. Thanks for the write up.
    Bigron is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-V
    Sep 2007
    Southfield, MI
    934
    What did you paint/tint the inside with? How does it hold up to the heat?
    Aug 2011
    San Antonio, TX
    42
    40
    Plastidip...have had it around the running light ring for months with no problems so was not worried about heat issues with it. I did not want to sand the chrome just in case I didnt like how it turned out.
    Satin69 is offline Cadillac Owners Member
    Automobile(s): 2012 CTS-V Coupe
    Apr 2012
    94
    You did a hell of a job. Thanks for the write up!
    litig8r187 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Black Raven CTS-V Murdered
    Jun 2011
    Aggieland, Texas
    133
    I like the look. Great write up!
    Here's mine.
  16. #14
    Tityrous's Avatar
    Tityrous is offline Cadillac Owners Fanatic
    Automobile(s): 04 CTS-V/12 CTS-V Black Diamond Coupe
    Jan 2009
    Raymond,NH
    31
    126
    Came out great!
  17. #15
    Aug 2011
    San Antonio, TX
    42
    40
    Thanks everyone. Looks good litig8r187!
  18. Remove Advertisements
