Putting 20" staggered wheels on an AWD coupe... - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 71
Like Tree13Likes
2008-2013 Cadillac CTS Appearance Mods Discussion, Putting 20" staggered wheels on an AWD coupe... in Cadillac CTS Second Generation Forum - 2008-2013; Any new updates? Went to the tire shop and asked about Vossen rims and tires and got roughly the same ...
  1. #16
    soku is offline Cadillac Owners Member
    Automobile(s): '11 AWD Radiant Silver CTS Coupe
    Oct 2011
    12
    Re: Putting 20" staggered wheels on an AWD coupe...
    Any new updates? Went to the tire shop and asked about Vossen rims and tires and got roughly the same price as you Not sure I want to spend that much.
  2. #17
    MTL_CTS's Avatar
    MTL_CTS is offline Cadillac Owners Fanatic
    Automobile(s): 2011 Cadillac CTS-4 Coupe Raven Black
    Apr 2008
    Montreal, Quebec
    300
    Well I ended up going with the Yokohama advan sports... So far everything seems fine I've put a couple of hundred miles on them already if you live somewhere where the roads aren't too bad though I recommend going with the other combo I posted... 245/35 and 285/30 and lower the car... The smaller tires are not only cheaper since there is more selection but also you'll probably find some with better tread rating than the ones I bought so they will last you longer...
  3. #18
    doozmlk is offline Cadillac Owners Member
    Automobile(s): 2011 CTS4 Coupe Premium
    Nov 2010
    Brooklyn
    78
    So MTL, you are running the vossen cv3's with your awd? Please post pics if you are!!!
  5. #19
    MTL_CTS's Avatar
    Apr 2008
    Montreal, Quebec
    300
    Yes look a couple of threads down I made another thread... I would post more pics in here but I'm at work and posting from my phone...
  6. #20
    ITALYNSTALYN is offline Cadillac Owners Member
    Nov 2012
    60
    Just what I needed I'm a fellow montrealer, and just picked up a 2013 coupe cts performance awd and am going crazy like you did on what staggered setup to put. I know I want 20" and some really fat tires in the back. I would really apreciate your feed back on your experience all these numbers are making me dizzy . What staggered size will be perfect for the coupe awd??
    Thanx
    Ddiizzyyy
  7. #21
    MTL_CTS's Avatar
    Apr 2008
    Montreal, Quebec
    300
    Are you going to lower the car?
  8. #22
    Char T A's Avatar
    Char T A is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS4 Sedan
    Apr 2009
    38
    103
    I went with 255/35 front and 295/30 rear. With Toyo Proxes-4 it was less than $1000 for all 4!! Any reason you did not consider these?
    Quote Originally Posted by Char T A View Post
    Just double checked and my rear is only faster than front by 1.7 revs or larger rear by 0.06" basically identical size...[COLOR="Silver"]
  9. #23
    McLuv1n is offline Cadillac Owners Member
    Automobile(s): 2011 cts coupe 3.6 AWD - white diamond
    Nov 2012
    NY
    45
    anyone know the ideal offset for 20" wheels on the awd coupe? Also, what is the stock 18" wheel offset?
  10. #24
    Char T A's Avatar
    Apr 2009
    38
    103
    Quote Originally Posted by McLuv1n View Post
    Most are going with a 20x10.5" on the coupe with a +25 or +27 I am almost certain that included on the AWD.
    Sorry the above was just the rear I jumped the gun. Fronts 20x9 +35. Remember to get tires that are equal diameter with the AWD if you do a staggered fitment.
  11. #25
    Nov 2012
    NY
    45
    thanks for the heads up! I was also considering the TSW Mirabeau in 18" so I could stay as close to stock as possible. Only option though would be getting 18x8 in the front and 18x9.5 in the rear with 35 offset all around. Since the stock rims are 18x8.5 and 18x9, will the stock tires (235/50/18 fronts and 265/45/18 rears) fit on the different width rims? thanks
    these are the wheels...I think they will compliment the white diamond coupe very well...
    http://www.elementwheels.com/products.asp?cat=4669
  12. #26
    Char T A's Avatar
    Apr 2009
    38
    103
    Man it's just me but I would save the extra $500 bucks up and buy the staggered 20s and grab some Toyo Proxes-4 tires for $900 and do it right. I have always cut corners and this time got my 20" Vossens and I have never been happier.
  13. #27
    Nov 2012
    NY
    45
    If i did the 20s i would get 245/40/20 fronts and 285/35/20 rears as to not mess with the AWD, but will the fender gap be too much? I do not plan on lowering it at all.
  14. #28
    Char T A's Avatar
    Apr 2009
    38
    103
    I have 20s but went with slightly larger tires to fill even more wheel gap and they are same diameter so it is great for all wheel drive. Check out some pics and stats on my new site I am creating. customoffsets.com. let me know what you think.
  15. #29
    MTL_CTS's Avatar
    Apr 2008
    Montreal, Quebec
    300
    You just said it, it doesn't conserve fr/rr rev per mile bias... That being said the difference is so negligible you'll probably be fine, but I guess just to be safe I went with somehting that was in theory a better choice
    I never posted pics in here of the final product
    CTS-QC and South Shore 2 Door like this.
  16. #30
    Char T A's Avatar
    Apr 2009
    38
    103
    Quote Originally Posted by MTL_CTS View Post
    Ahh, gotta live a little If I can get a fatter tire and just take a tiny risk I am in! Your car would sure look nice next to mine at www.customoffsets.com !!
  17. Remove Advertisements
