Interior Light Bulb Types/Sizes HELP!
Results 1 to 12 of 12
2008-2013 Cadillac CTS Appearance Mods Discussion, Interior Light Bulb Types/Sizes HELP! in Cadillac CTS Second Generation Forum - 2008-2013; So ive recently joined the Cadillac community and I need some help. I am looking to replace my interior bulbs ...
    bronik90's Avatar
    bronik90 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS Coupe - 3.6l DI AWD
    Aug 2011
    Pittsburgh, Pennsylvania
    27
    101
    LightbulbInterior Light Bulb Types/Sizes HELP!
    I am looking to replace my interior bulbs to LEDs.
    An hour long Google search sends me in circles, and delivers a ton of replacement part sites that dont help what so ever.
    Does anyone know the actual types and sizes? (ie. what length festoon lights for the rear in mm [44mm?])
    Ive never had such problems finding simple info like this before. Thanks!!!
    MillerCTS is offline Cadillac Owners Member
    Automobile(s): 2008 CTS4
    Oct 2011
    Ohio
    45
    1
    Re: Interior Light Bulb Types/Sizes HELP!
    I found this site. http://superbrightleds.com I hope this helps.
    GreaseMonkey's Avatar
    GreaseMonkey is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS 3.6L Black Ice/Ebony
    Sep 2011
    Sterling Heights, MI
    336
    I'm also looking to do the same thing, along with replacing the license plate bulbs with LEDs as well. I want to match the color of the interior ambient lighting that my car has which would be a cool white color.
    There is a bulb in each door, two map lights up front, and two map lights in the rear. There are also the two license plate bulbs.
    According to superbrightleds.com, 2825 is the part number for all of those bulbs. I'm going to do a little more research and see if that is correct.
    Sep 2011
    336
    These look like they may be right.
    http://www.amazon.com/Cool-White-Omn.../dp/B004Z3JWM0
    bronik90's Avatar
    Aug 2011
    27
    101
    Quote Originally Posted by GreaseMonkey View Post
    Thanks for the input guys. Well I uncovered that the interior lights in the 2008 CTS are all 194 "wedge-type" (the connection itself), but 168 and 2825 will fit as well.
    I used a site called Tmart (an overseas site with a ton of cheap LEDs), which I have used before with success, and ordered some red LEDs for my interior. The total was about $19 and I saved a ton of money compared to sites that sell kits. It requires a little more time but is totally worth it IMO.
    http://www.tmart.com/search.html?q=L...gories_id=3155 <- If you're looking to convert to a clean white look, there are a ton of LED panels that you can use. The dimensions of the dome light lens (front and back, each separate light) is 1.12 x 1.4 inches, so buy carefully. The panels can lay directly on the plastic lens with almost no heat whatsoever, and it looks great. I've seen it done on an STS, and wow!
    If you want to switch to blue or red, meh good luck lol. There arent a huge choice of bulbs so options are limited. I still think it will awesome and I'll post pics once I install them.
    bronik90's Avatar
    Aug 2011
    27
    101
    And here is the link ( http://bit.ly/rV9Zp1 ) of a prius (yes, a prius) with a DIY makeover. these lights are a bit bright IMO, but it looks professional. Scroll to the 5th post down with the pics, and you'll see what I mean by "laying the panels" on the lens. you wouldnt see each individual LED as clear as that, its just the way the camera took the picture.
    Here are the 2 different bulbs I bought ( http://bit.ly/rvVsRh and http://bit.ly/uBuirx ). The second bulb will require me to strip the wire and connect it myself, but thats 10 seconds of my time and more $$$ in my pocket. and again, if anyone just wants a clean white look, there are tons of panels that will fit in the dome
    superbrightleds.com doesnt seem bad either. a little high priced though
    Sep 2011
    336
    Thanks for the info!
    I'll be ordering some up within the coming weeks. I forgot about several other light areas. One in each footwell, and then the trunk. So I think the total is 13. I'll have to go back out to my car and add all the locations up before ordering.
    DevilBuckeye is offline Cadillac Owners Member
    Aug 2011
    34
    1
    I bought from superbrightLed.com back when I had my Scion TC that I dumped money into. Great producty and great service from teh company. Wish I had pics, but I turned all my lights into RED LEDs. it looked awesome.
    Any pics of teh white LEDS in teh CTS yet? Very ineterested.
    ogbuehi is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Deville, 2011 DTS
    Jul 2004
    washington d.c.
    852
    Just be careful trying to use superbrights led bulb finder. I found that it kept recommending the wrong bulb numbers. Luckily I was able to just pull out the bulb and figure out the proper size. Once you upgrade from filament to LED, there's no going back. It's lighting that's actually useful.
    danoh123's Avatar
    danoh123 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS 3.6 Premium AWD
    Sep 2012
    Boston area
    167
    Quote Originally Posted by bronik90 View Post
    Interior dome light should be more flat style LED due to tight space thought other 194 works too.
    http://www.amazon.com/gp/product/B00...ls_o02_s00_i00
    All other areas you can use
    http://www.amazon.com/gp/product/B00...ls_o01_s00_i00
    Works for doors, foot well, and license lights.
    I don't have a clear recall, but the rear trunk light is
    http://www.amazon.com/gp/product/B00...ls_o04_s00_i00
    bronik90's Avatar
    Aug 2011
    27
    101
    Hey thanks for the input. Since I started this thread, I've swapped Cadillacs three times. In every one, I've changed the lighting to LEDs myself for $25 each time. The LEDs that I've purchased from tmart.com have been great quality and ridiculously cheap.
    The total install took me about 20 minutes, and I've done red, blue, and white lights in each car respectively The red and blue LEDs were 5050 SMDs and the white lights are "piranha" lights that look awesome.
    Side note: for such an easy DIY project, it amazes me to still see people spending $80 to even $200 for some "custom" kit that cost the site $15 to toss in a bag. Everything I've ordered has shipped from some warehouse in NY, and I've never experienced flickering or failure with any LED I've ordered.
    I have zero affiliation with tmart or any other site, nor do I get anything for recommending them. I just want to make it clear that you can change the personality of your CTS significantly, while getting professional results, without spending money unnecessarily.
    Cuest is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Performance w/Red & Carbon Interior
    May 2010
    NYC / Florida
    157
  15. Remove Advertisements
