2011 CTS Coupe Door Wood Trim Removal
Results 1 to 9 of 9
2008-2013 Cadillac CTS Appearance Mods Discussion, 2011 CTS Coupe Door Wood Trim Removal in Cadillac CTS Second Generation Forum - 2008-2013; Greetings everyone, I have a very localized rattle behind the pass side wood trim - where the ambient lighting is ...
    nkoulian is offline Cadillac Owners Member
    Automobile(s): 2011 CTS Coupe Premium
    Jul 2011
    37
    Greetings everyone,
    I have a very localized rattle behind the pass side wood trim - where the ambient lighting is - and looking for advice on removal.
    Your input is appreciated!
    Meat Wagon's Avatar
    Meat Wagon is offline Cadillac Owners Member
    Automobile(s): 2010 CTS Wagon Performance 3.0
    Jul 2011
    12
    Re: 2011 CTS Coupe Door Wood Trim Removal
    Best I can figure out is that there's 4 nuts on the back of the woodgrain. It appears you'll need to get behind the door panel to do that. Sorry, I'm not familiar with how to remove the door panel itself.
    If it's a 2011, wouldn't you still have warranty? Take it to your dealer and have them look into fixing it.
    Jul 2011
    37
    Hey MW, thanks for your reply! My wishful thinking was that I could just pry it off. You're probably right though, I tried, it didn't budge...
    The reason I hesitate to take it to service is that, having a lifetime of experience dealing with service departments, and knowing how rough they can be, they'll probably fix something - if that - and screw up a couple other things. And it would take four visits at that...
    Been also looking to get a service manual, haven't found one yet.
    Meat Wagon's Avatar
    Jul 2011
    12
    go to www.helminc.com and you can order factory service manuals (just like the dealer has). They print them for many OEMs. They're pricey, but worth their weight in gold if you ever have to do your own repairs. They're like phone books in size.
    Unfortunately, they're out of stock on the 2011's until middle of the month. From their website:
    Service and Owner Information
    > Cadillac > 2011 > CTS > Shop/Service Information
    2011 Cadillac CTS/CTS-V Service Manual Set
    Price: $150.00
    Item temporarily unavailable. The item will be available on 8/15/2011.
    Click here if you would like to be notified when this item becomes available.
    Pkg Qty: 1
    Media: Paper
    Language: English
    Item/Part #: GMP11D
    Models and Years Covered
    Contains Factory Authorized Service information written by General Motors. It contains Diagnostic Information and Procedures, Schematics and Routing Diagrams, Component Locator, Repair Instructions, Description and Operation, Specifications, and Special Tools and equipment. Service information on HVAC, Body & Accessories, Restraints, Steering, Suspension, Driveline/Axle, Brakes, Engine and Transmission/Transaxle.
    Jul 2011
    37
    Thanks, MW, for the info. It's a good resource to have.
    I actually removed the panel very easily, and sure enough I found the issue and fixed it!!!
    You were right, the wood grain had self-tapping nuts on the back. I also noticed that it's a metal piece. Makes one wonder, why metal, and why the heavy duty install?? The piece could've been plastic - why add unnecessary weight??
    Anyway, I should also mention that I was really impressed by the fit and finish of the pieces, and by the layers of sound deadening material inside the panel...
    austin's Avatar
    austin is offline Cadillac Owners Connoisseur
    Automobile(s): ~2011 CTS-V Coupe & 2013 SRX~
    Apr 2005
    Boston, MA
    1,749
    Quote Originally Posted by nkoulian
    Glad it worked out for you.. How exactly did you manage remove the Coupe's door panel?
    davidpariso is offline Cadillac Owners Member
    Dec 2010
    Chicago IL
    4
    please share how to remove a coupes door panel. Are there screws to remove before pulling the panel off?
    Jul 2011
    37
    Hey David, yes there are 2 screws; one is behind the door release button - which you can pry out easily (the silver housing of the button pulls out) - and another below the armrest - unfortunately I can't remember exactly where). Once you remove the 2 screws, carefully pry out the sides and bottom of the panel and then lift up to clear the window groove. Before you pull out though you have to unplug a connector that supplies power to the door panel. Good luck!
    Dec 2010
    Chicago IL
    4
    Thanks for the help!
  12. Remove Advertisements
