08 CTS- How to Remove the Back License Plate Bulb Cover
Results 1 to 4 of 4
2008-2013 Cadillac CTS Appearance Mods Discussion, 08 CTS- How to Remove the Back License Plate Bulb Cover in Cadillac CTS Second Generation Forum - 2008-2013; Hi, I need some guidance to remove the back license plate bulb covers to replace my bulbs. I can remove ...
    ctsrules08 is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac CTS
    Mar 2011
    3
    Hi, I need some guidance to remove the back license plate bulb covers to replace my bulbs. I can remove the bulb case assembly down using a screw driver by pulling on one side but I can't seem to remove the cover to access the bulb. Any suggestions? Thanks in advance.
    dancastro is offline Cadillac Owners Member
    Automobile(s): 2010 CTS4 Premium - Black Raven/Cashmere
    Feb 2011
    31
    Re: 08 CTS- How to Remove the Back License Plate Bulb Cover
    Just give the bulb base a 1/4 turn twist & it'll pull right out.
    reciprocity is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V (red), 2009 CTS Premium Sedan (red), 2016 ELR (Radiant Silver Metallic)
    Jan 2005
    California
    337
    If I remember correctly, the covers work similarly to the battery door on electronics (like a TV remote battery door). I think there should be a small notch in one end of the lens. Just put a small screwdriver in there, push the whole lens to the side, and gently angle the lens out. It should come out really easily; don't force it. I was initially a little confused, too, and am glad I didn't twist or pry on the plastic and break the lens! You shouldn't need to unscrew anything to get to the bulbs.
    DanF's Avatar
    DanF is offline Cadillac Owners Member
    Automobile(s): 05 XLR
    Feb 2011
    DE
    57
    10
    Just done mine, no need to remove the lens, bulb comes out the back with a twist.
  7. Remove Advertisements
