Results 1 to 4 of 4
Thread: 17" wheels on an 09 with the sport package?
    RWS is offline Cadillac Owners Member
    Automobile(s): '14 ATS 3.6 AWD
    Feb 2006
    9
    Anyone happen to know if stock 17" 09 wheels will fit on a car with the FE3 suspension and brake package? I know that 18' wheels are standard with the sport package, but I am looking to use a taller (and less expensive) 17" set of tires for winter use.
    Tri-SS's Avatar
    Tri-SS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V, 2011 CTS-V
    Feb 2008
    Southern Ontario, Canada
    168
    Re: 17" wheels on an 09 with the sport package?
    I was wondering the sort of the same. I was told that I could put 18s on my 2010 FE3 by the folks at Tire Rack. I should have the car next week and will see. I dont think you can go down to 17s. Check out TireRack.com.
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    The offset and bolt pattern are the main stumbling blocks. I would think both will be ok. Now the ride will be more effected and remember your speedo will be off.
  5. #4
    Northern SRX's Avatar
    Northern SRX is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-4 3.6 & 2008 SRX-4 V6
    Nov 2006
    Ottawa, Canada
    950
    I'm sure that I've read previously that others with the FE3 couldn't get the stock 17s to fit because of the size of the brake caliper with the FE3 trim. You should search this forum.
  • You may not post replies
