Adding Fog Lamps to non-performance package CTS - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 68
Like Tree4Likes
2008-2013 Cadillac CTS Appearance Mods Discussion, Adding Fog Lamps to non-performance package CTS in Cadillac CTS Second Generation Forum - 2008-2013; cts2008lover Did some testing today - Removed terminal #19 from the light green connector (orange wire from terminal #7 at ...
  1. #16
    LLingard is offline Cadillac Owners Member
    Automobile(s): 16 SRX Premium
    Aug 2009
    Ontario, Canada
    19
    Re: Adding Fog Lamps to non-performance package CTS
    cts2008lover
    Did some testing today - Removed terminal #19 from the light green connector (orange wire from terminal #7 at the switch) and temporarily connected it to the wire from the relay (to isolate the BCM if anything went wrong). When I turned the OEM switch on it no longer latched to complete the circuit but the fog lights did come on when you held the switch on. Put the #19 terminal back into the light green connector and tapped into the orange wire with same results - switch would no longer latch, telltale lamps on dash no longer displayed but fog lamps did come on if switch was held in on position. So, the schematic shows an I/O pull up resistor (+) internal of the BCM at the end of the orange wire and an I/O low side drive switch (+) at the end of the wire coming from the relay. My guess is that these two items need to be built into the circuit to make the OEM work - Does anyone have any idea where these can be obtained?
  2. #17
    footinface is offline Cadillac Owners Member
    Automobile(s): 08 CTS
    Feb 2010
    3
    will attempt the same on my car. TTT for others input
  3. #18
    GetzCTS is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2008
    90
    What will all this cost to ad the fogs???
    Thanks
  4. #19
    laclac is offline Cadillac Owners Member
    Oct 2010
    1
    can some one tell me if the chrome bezel p/#15904575 has the hole on the side of the actuallight bulb . heres the problem went to dealer to buy the bezels and the chrome bezel that he brought out had to hole one for the fog light and the oter was just a plain hole , then we went to the show room and the 2011 cts had bulb in one hole and some kind of filler piece inthe other has anyone seen this problem please let me no , dont want to order part and have the bezel without the filler piece thanks .
  5. #20
    C "T" ess's Avatar
    C "T" ess is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 ATS Performance Coupe 2.0T
    May 2007
    Tampa,FL
    66
    2,773
    I believe the other hole is for the brake ducting.
  6. #21
    Aug 2009
    Ontario, Canada
    19
    laclac
    The bezel does have two holes, one for the lamp and the other for air ducting to cool the brake parts at each front wheel. The ducting is meant for the FE2/FE3 suspension and brake systems. I have the FE1 suspension and did not add the ducting when I installed the fog lamps but did add screening to cover the hole from an accessory supplier just as a finishing touch. I have yet been unable to hook up the lamps using the factory switch but in the meantime have been using a seperate rocker switch - I've explained in previous posts in this thread. If you have any insight to the electrical end, it would be much appreciated.
  7. #22
    jef9876 is offline Cadillac Owners Member
    Automobile(s): 2010 CTS
    Aug 2010
    55
    1
    I have been wanting to add fogs to my 2010. Just a thought, if adding the OEM combo switch causes the fog indicator in the IP to light, why could we not use the voltage from that lamp to trigger an external relay, then connect the our fog lamps to this. Would we not have OEM type control?
  8. #23
    C "T" ess's Avatar
    May 2007
    Tampa,FL
    66
    2,773
    The lack of amps at the switch will be the problem and I don't believe there is a relay that can pump up the amps. If the stalk is plug and play, there should be a feed and the column connector where you can pull the power you need.
  9. #24
    grosserhund is offline Cadillac Owners Member
    Automobile(s): 2009 CTS
    Feb 2010
    Palmetto, GA
    51
    8
    Don't laugh too hard, but I don't suppose anyone has asked a dealer, or another shop for an estimate to install the fog lights...
    I'm willing to pay a dealer or a reputable shop for the installation, but not if it's going to kill the bank account
  10. #25
    Thabigguy is offline Cadillac Owners Member
    Automobile(s): 2008 CTS
    Nov 2010
    30
    7
    You could just buy the bezzels and glue in a set of side view convex circular Mirrors where the lights go and as long as no one asks you to turn them no one will ever know the difference.
  11. #26
    Feb 2010
    Palmetto, GA
    51
    8
    Let me clarify. All I was saying (and I should have said it) is that I'm not mechanically skilled. I don't mind paying someone to do a good installation on it, I just don't want to overpay is all I meant. The last 3 vehicles I've owned have all had them, and they are very useful as I do auite a bit of night driving these days.
    That being said, It looks like it may be more trouble than it's worth, but I'll keep looking around.
  12. #27
    droptopron is offline Cadillac Owners Fanatic
    Automobile(s): '10 3.0 AWD Sedan
    Jan 2011
    Long Island, NY
    139
    Not recomending in any way but this EBay guy sells a complete fog light package for $400 shipped. It uses OEM light assemblies but aftermkt wiring.
    http://cgi.ebay.com/ebaymotors/Cadil...item27b8300fbd
  13. #28
    awest5321 is offline Cadillac Owners Member
    Automobile(s): CTS
    Jan 2011
    1
    Bought the chrome bezels from Lynch Cadillac in Auburn, AL for $162 and found the pair of complete fog lights with mounting assembly, lenses, bulbs for $108 on Amazon.com. Assemblies bolt right in. Havent done wiring yet but got pair of H11 connectors at Autozone for $16. Got relays and wiring for my harness already just need to get my car up on my lift and start putting my harness together.
  14. #29
    heb80 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS Coupe
    Feb 2011
    16
    I installed some Hella's in my base model CTS bezels.
  15. #30
    Feb 2011
    16
  16. Remove Advertisements
