Replaced OEM fog lamp bulbs with Hoen xenonmatch superwhite bulbs
Page 1 of 6 123456 LastLast
Results 1 to 15 of 81
Like Tree1Likes
2008-2013 Cadillac CTS Appearance Mods Discussion, Replaced OEM fog lamp bulbs with Hoen xenonmatch superwhite bulbs in Cadillac CTS Second Generation Forum - 2008-2013; I observed that the original OEM 'Osram' H11 halogen bulbs installed in the fog lamp housings looked yellow in comparison ...
    RAB's Avatar
    RAB
    RAB is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS Premium AWD Sport Sedan w/FE5 - RadiantSilver|Ebony
    Jun 2007
    Ontario, Canada
    2,108
    I observed that the original OEM 'Osram' H11 halogen bulbs installed in the fog lamp housings looked yellow in comparison to the super white color of the xenon HID headlamps, ice cube optic DRL's and LED light pipes. I decided to order a pair of H11 Hoen 55W superwhite xenonmatch bulbs. Received the new bulbs today, and installed them straight away. I'm extremely pleased with the outcome. The difference is really pronounced when viewing in person. The 'fogs' look great now, although it's somewhat difficult to convey the difference/effect in photos.
    Regardless, I've attached a few photos here along with some comment:
    Looking straight-on at the car, the L/S fog lamp bulb in the photo is original OEM Osram, and the R/S side is Hoen xenonmatch. The difference in light color is very apparent in person, but not overtly so in photos.
    The bulb on the left is OEM Osram, the one on the right is Hoen xenonmatch.
    [Note: Suggest ignore the instructions in the owners manual for fog lamp bulb change out, which are vague at best].
    To access/replace the fog lamp bulb on a given side of the vehicle, turn the wheel/tire fully inward on the side being worked on. Remove the three pertinent (you'll figure it out) plastic push-pins to allow the fender/wheel-well liner to be pulled away from the fender, to expose the fog lamp housing within.
    With the 3 push-pins removed, manoever/pull the wheel-well liner away from the fender with one hand and with the other hand reach in and grab the fog lamp base/bulb assy and twist it in a counter-clockwise direction until the base/bulb are freed from the fog lamp housing. Replace the bulb, and then apply the base to the fog lamp housing at a 4 o'clock orientation, then turn the base/bulb assy in a clockwise direction to the 6 o'clock position to lock it in place. Do NOT touch the glass on the new bulb during any part of the process. Re-install the wheel-well liner to its proper position/alignment, and re-install the plastic push-pins to secure the liner.
    The fog lamps now color-match all the front lights extremely well. They look great!
    Hope this info/instruction helps. Hey, just do it!! - I guarantee you'll like it.
    Rab.
    durpydurps likes this.
    urbanski is offline Cadillac Owners 10000+ Posts
    Automobile(s): 05 CTS-V
    Mar 2003
    San 'tone, TX
    23,163
    Re: Replaced OEM fog lamp bulbs with Hoen xenonmatch superwhite bulbs
    hey that rocks!
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    YEAH... nice little guide ... with photos and everthing
    i especially liked the "you'll figure it out" part
    LUVMY04V's Avatar
    LUVMY04V is offline Cadillac Owners Master
    Automobile(s): 04 cadillac cts v
    Feb 2006
    Dekalb IL
    35
    5,585
    watch out for heat problems watch carefully
    ive heard great things about hoen though
    RAB's Avatar
    RAB
    Jun 2007
    Ontario, Canada
    2,108
    Quote Originally Posted by luvmy03caddy View Post
    Good point. I had some concerns about additional heat prior to ordering the Hoen replacements, but decided it should be a non-issue given the fact that the OEM H11 Osram's and the replacement H11 Hoen's are both filament-type gas charged bulbs, and both are rated at 55W.
    At their website, Hoen states, "All xenonmatch bulbs operate at vehicle manufacturer suggested wattages and are plug and play...".
    The Hoen H11 bulbs I purchased are marketed as "xenonmatch", but they're absolutely not xenon HID lamps. Hoen's xenonmatch bulbs are designed to match the color of xenon HID lamps, but do not provide any additional light ouput compared to the original OEM H11 bulb.
    Not sure if the different types of charge gas utilised by the manufacturers of 55W single filament H11 bulbs would result in some different capsule temperatures. For example, Osram charge their H11 bulb with gas from the halogen group, while Hoen apparently charge their xenonmatch bulb with xenon (Xe) gas. I think I'll send a note to Hoen and request operating temperature info for their H11 xenonmatch bulb vs. the conventional OEM H11 bulb.
    RAB.
    MoFex's Avatar
    MoFex is offline Cadillac Owners Connoisseur
    Automobile(s): 08 White Diamond CTS DI RWD FE2 all options
    Oct 2007
    metro Atlanta
    60
    2,541
    I had Hoens in my current car in fogs for the same reason you installed them - to match HID's. Now, the heat is not a problem as they both have the same wattage. So I would not be worry about that. However the Hoen does not last that long. Actually my lasted less than a year. If you can live with changing bulbs that often - go for that. Also thay have lower lumen output. At the end I switched to HIR - color does not match the HID's but they last much longer and the lumen output is twice the halogen ones.
    BTW - nice job and good instractions! Oh, and if the look is what you were after I believe you achieved it!
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,393
    Great upgrade
    Pucks is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac CTS
    Jul 2007
    Long Valley, NJ
    45
    312
    RAB - nice job . I disagree with one thing you said though - I think the difference is overtly noticeable in the pictures. Looks like a perfect match and much better looking than the stock bulb.
    I've added this to my short list of mods:
    1 - Replace license plate lights (Zymurgy find)
    2 - Replace fog bulbs as above.
    Both are noticeablely better than stock and the price is right.
    I'll most likely have the "least modded" CTS in 5 years, but these two are no-brainers!
    And thanks for the instructions - I just need to go find the other thread to see where to order.
    Jon's Avatar
    Jon
    Jon is offline Cadillac Owners Master
    Automobile(s): 16 ATS-V, 04 CTS-V, 09 CTS, 07 SRX, 04 CTS
    Feb 2004
    Alberta, Canada
    31
    6,655
    Lookin good!
    RAB's Avatar
    RAB
    Jun 2007
    Ontario, Canada
    2,108
    Quote Originally Posted by Pucks View Post
    Pucks, thanks for your positive feedback.
    I washed & detailed my CTS4 yesterday afternoon, then went out for dinner and a drive around town last night with Mrs. Rab. There was no fog to contend with, but had the fog lamps on anyway. Have to say the replacement fog bulbs have turned out to be a great match color-wise to the HID headlamps and LED light pipes, which is what I was after. I'm very pleased with the outcome.
    With either the original equipment Osram bulbs or the new Hoen bulbs that I installed, I've noticed there's not a heck of a lot of lumen output going on with the fog lamps on the new CTS. Not sure how effective they will actually be in a true fog situation, regardless of what H11 bulb is applied. HOWEVER.. the 'fogs' certainly look great when they're on! - - particularly with the superwhite bulbs. Hey, better to look good than be functional, right?! At least having these particular fogs lamps ON on clear nights won't irritate the drivers of oncoming vehicles.
    BTW, I ordered the replacement bulbs directly from the Hoen website. Here's the link: http://www.hoen-usa.com/ . The Hoen (xenonmatch) bulbs are provided 2 to a pack, for US $30.00 plus shipping.
    Still waiting for the LED license plate bulbs I ordered from V-LEDS.com (aka frickinbrite.com). They should arrive in the next couple of days. After applying those bulbs I'll be done 'modding' my new CTS4... at least until something else interesting comes along.
    Zymurgy's Avatar
    Zymurgy is offline Cadillac Owners Connoisseur
    Automobile(s): 2017 XT5 and 2014 Corvette
    May 2007
    Richardson, TX
    1,180
    Great job RAB! I used Hoens on my C6 fog lamps with the same results. Guess I'll have to order a set for the wife's CTS.
    Warrior47321 is offline Cadillac Owners Member
    Automobile(s): 2008 CTS DI/FE2/AWD/BlackRaven/Cashmere
    Oct 2007
    49
    Easy mod. Good directions. Looks great!
    RAB's Avatar
    RAB
    Jun 2007
    Ontario, Canada
    2,108
    Quote Originally Posted by Warrior47321 View Post
    Hey Warrior47321 - glad to hear it worked out well for you.
    I think the swap to the superwhite foglamp bulbs is a must for anyone who pays attention to front end lighting detail.
  16. #14
    lordbaby's Avatar
    lordbaby is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac CTS DI FE3 PDQ Crystal Red/Ebony
    Oct 2007
    1,008
    fog lamp is for fog... does the ones your changed also for fog>?
  17. #15
    RAB's Avatar
    RAB
    Jun 2007
    Ontario, Canada
    2,108
    Quote Originally Posted by lordbaby View Post
    ... what was that again?
  18. Remove Advertisements
