Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 31
Thread: Dyno #'s ????
  1. #16
    Mar 2004
    Reno, NV
    5,496
    Re: Dyno #'s ????
    I like:
    www.smokemup.com
    Under the AutoMath tab
  2. #17
    Oct 2004
    Medford Oregon
    44
    241
    Re: Dyno #'s ????
    BAH, I was going to but they want you to register, then I did that now they want money.
  3. #18
    Mar 2005
    746
    Re: Dyno #'s ????
    Quote Originally Posted by GT04CTS-V
    Forgot to mention, my trap speed in the 1/4 was 112mph, using the HP calculator my wheel HP = 438. So the dyno at Tony's Corvette seems to be the closest. Not sure if I'm allowed to post a reference to the web site I used to calculate RWHP, but if you do a yahoo search for "trap speed horsepower", it's the 2nd listing.
    GT
    Damn 112 mph is good, but your ETs are high. this weekend i ran 12.23@112mph. also emailed you back the prices..
  4. #19
    Mar 2004
    Reno, NV
    5,496
    Re: Dyno #'s ????
    never asked me for money. I did register...but if I recall money is only for the more advanced calculators. The lesser ones (1/4 mile et, trap speed vs. hp, etc.) are free I think?
  5. #20
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    Re: Dyno #'s ????
    Quote Originally Posted by bryce3
    I'm not sure exactly when Velose got his dyno done but the temp was a cool 72 ish at about 9:20 in the morning. The fan was turned on and placed right in front of the car. I didn't turn the TC off so I'm sure it was on. Does the weight of the vehicle matter? I had them use 4100lbs. to account for my fat ass + the car.
    -Sean
    I had mine set at 4000 vs. your 4100. I'm sure it makes a difference. Also in my LPE dyno thread, Bill posted that having weight in your trunk will give you better traction and will produce better numbers.
    Bottom line is there are so many factors in this, it's really hard to compare. Just go to the same shope each time, and use the same perameters. At least that way you cut out as many variables as possible, and should be able to compare to your older runs. As I said earlier, I always compare my 3rd hot run, as it tends to be the most consistant (and matches real world driving anyway). If you do this, and then go DOWN on your HP/TQ ratings, I'd start pointing fingers at the mods you made , and not the dyno
    -Chris
  6. #21
    Oct 2004
    Medford Oregon
    44
    241
    Re: Dyno #'s ????
    I dunno, I tried the 1/8 mile one but couldnt get it to work. Maybe you could run the numbers for me.
    3150lbs 102mph in the 1/8 15% loss in driveline. Was currious what it would spit out.
  7. #22
    trekster's Avatar
    trekster is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V R.I.P.
    Apr 2004
    Downey,CA
    30
    1,234
    Re: Dyno #'s ????
    Quote Originally Posted by willsctsv
    I would be pissed. I was pissed when I only pulled 375RWHP on the Mustang Dyno over the summer with my mods.
    I guess I should be happy!
    I have the same mods as you except for the volant cai and headers with no resonators and cats. I was expecting 390-400rwhp.
  8. #23
    willsctsv is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Jan 2005
    Queens NY
    42
    864
    Re: Dyno #'s ????
    Black Beast, I bet if you dyno the car in these cooler temps. You might just be around 390-400 HP. I was thinking of going back to the dyno just for the hell of it.
    I know my car feels faster now than in the summer.
  9. #24
    Mullah88's Avatar
    Mullah88 is offline Cadillac Owners Connoisseur
    Automobile(s): '10 CTS4 3.6L Wagon prem; '06 STS 3.6L base; '98 Seville STS
    May 2011
    Charlotte NC
    29
    1,312
    But they dont get any respect from the league! It's not a "us vs them" situation, that's how it's been this whole season.
  10. #25
    izcain's Avatar
    izcain is offline Cadillac Owners Fanatic
    Automobile(s): Without a caddy
    Jan 2013
    Port Angeles
    174
    Re: Dyno #'s ????
    I was a dyno operator a couple years ago and I ran a mustang dyno. I can tell you without a doubt the 4-4100 lb rating that the tech puts in is going to make a world of difference. It also depends on what correction factor that the tech has loaded for the dyno to look at.
    A/C systems shut off at WOT anyways so nothing lost there. But all other parasitic losses can attribute. Sometimes the traction control will reduce power as well and play tricks on the dyno. Also the days, No two readings are comparable unless everything about the weather is the same.
    I would hope that tech had a fan on the car.
    When I was running the dyno an 04 Maggied, long tubes, corsa, intake, and tune from us put down like 460 range. But that was cooling the car down and trying for peak numbers. Our dyno was notorious for reading on the low side as well. I felt it was much more real world then some of the HP readings of others.
  11. #26
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,831
    Re: Dyno #'s ????
    Twitch says our midwest dynos are "generous."
  12. #27
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Re: Dyno #'s ????
    Back when this post was originally written dyno's used rubber bands and flintstone rollers. Scientific advancements like electricity have been made since then.
  13. #28
    izcain's Avatar
    Jan 2013
    Port Angeles
    174
    Re: Dyno #'s ????
    lol i just saw the dates! normally I am better at looking at the dates before posting lol
  14. #29
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    I am pleased.
  15. #30
    Feb 2007
    Cheese land
    1,596
    Re: Dyno #'s ????
    I'm getting snarky like Olsen and the rest of the old timers.
  • You may not post replies
