Bearing Hub & Diff swap
Results 1 to 4 of 4
2004-2007 Cadillac CTS-V Performance Mods Discussion, Bearing Hub & Diff swap in Cadillac CTS-V Series Forum - 2004 - 2007; I've had my V for 1 month,....and honestly I've never really looked into axles or hub swaps in the past ...
    hefftone's Avatar
    hefftone is offline Cadillac Owners Member
    Automobile(s): LS2-V
    Jul 2014
    Dallas, Ga
    84
    I've had my V for 1 month,....and honestly I've never really looked into axles or hub swaps in the past for other vehicles but.....
    I've seen the creative steel 8.8 swap and I want it. I've read the thread about the Creative steel 5 lug conversion (using the 2010+ Camaro rotors and modified hubs.)
    I saw it mentioned, but never discussed. If you were doing an 8.8 swap, and wanted to convert to 5-lug too....does that free up any other options in doing the 5 lug conversinon, particularly with the choice of rear hub since you would be have to get custom (or at least modified) rear axles anway.
    I think the reason CS picked the camaro was retention of stock V1 axles....Could other hubs (G8 GT/GXP, GTO, V6 cts, caprice ppv, V2) be used in similar fashion if not restricted to keeping the stock V1 outer stubs.
    I'd like to compile some info regarding the similarities & diffences in the hubs. At this point i have no idea how similar or different they are....
    Lug pattern
    outer Axle stub bore Diameter/Spline count
    Sensor issues (abs,etc)
    Brake issues (parking, rotor, etc)
    I never realized the V1 was 6 lug until I bought it... F#$% you GM!!!!!
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    Re: Bearing Hub & Diff swap
    It's the ebrake that's the challenge with this swap and doing an 8.8 isn't getting you any closer to a 5 lug conversion.
    hefftone's Avatar
    Jul 2014
    Dallas, Ga
    84
    Quote Originally Posted by ctsv247 View Post
    The first part of your statement could only be true if ALL GM hubs had the same splined bores. The second part itself was already abundantly obvious.
    Feb 2009
    Greenville sc
    45
    992
    Quote Originally Posted by hefftone View Post
    i guess this is you being abundantly obvious.....let me spell it out for you.....THERE IS NOTHING TO ECONOMICALLY BE DONE WHILE DOING AN 8.8 SWAP THAT WILL GET YOU CLOSER TO A 5 LUG CONVERSION.
    You can answer the rest yourself if you'll take a little time to search.
  7. Remove Advertisements
