"Seventh" hole in LS7 flywheel?
Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By EdmundGTP
2004-2007 Cadillac CTS-V Performance Mods Discussion, "Seventh" hole in LS7 flywheel? in Cadillac CTS-V Series Forum - 2004 - 2007; So I'm told this "seventh" hole in the LS7 flywheel needs to line up with the hole in the crank. ...
    Derek5.7 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Apr 2013
    Rochester, MI
    134
    So I'm told this "seventh" hole in the LS7 flywheel needs to line up with the hole in the crank. Can anyone tell me if the studs on the back only allow for this particular configuration or is it possible to bolt the flywheel on with that seventh hole mismatched? And/or what IS the purpose of this "seventh" hole? Is this what allows for it to be properly balanced?
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Re: "Seventh" hole in LS7 flywheel?
    Don't know why it's there but I lined it up with the whole in the crank and have no vibration.
    Bueller's Avatar
    Bueller is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    Nov 2007
    Florida
    572
    I didn't notice a seventh hole when I installed mine. I have no idea if I happened to get it lined up or not. Mine has no vibration with only a 1 in 6 chance of it lining up.
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    I swear I've read every ls7 clutch thread there is and this is the first I've heard of this. The LS motors that I know of are balanced internally so the flywheel and clutch assembly are independently balanced. In other words it should make no difference.
    EdmundGTP is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V
    Aug 2009
    Tempe AZ
    35
    612
    It's what makes it an LS-7 clutch and not an LS-6............ right?
    Bueller and Dan_Gurney like this.
  8. Remove Advertisements
