Ls6 build & questions
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
2004-2007 Cadillac CTS-V Performance Mods Discussion, Ls6 build & questions in Cadillac CTS-V Series Forum - 2004 - 2007; -05 cts v ls6- Objective: to rebuild my blown "4 broken pistons" ls6 with a bit more power. Nothing to ...
    05 CTS-V LURKN is offline Cadillac Owners Member
    Automobile(s): 2005 cadillac cts - v LS6
    Feb 2013
    52
    -05 cts v ls6-
    Objective: to rebuild my blown "4 broken pistons" ls6 with a bit more power. Nothing to crazy, it's still gonna be my daily on pump gas "91".
    It is completely stock.
    Now I was thinking 10:7:00 high compression drop-ins by WISCO?
    PRICE $570.00 RINGS-$150.00
    Question:
    1-Would this work with stock fuel pump/injectors/ignition/ etc?
    2- can someone double check if I have the right specs for our ls6 engins.
    Bore - 3.9xx
    Stroke - 3.6xx
    Compression - 10:5:xx
    Cubic inch- ???
    3- is there any other alternative pistons
    I'm that price range?
    Pls help, I want to get different opinions before I start buying.
    Thanks!
    2007V is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V, maggie
    Apr 2011
    85
    Re: Ls6 build & questions
    Look through the options at http://www.texas-speed.com/ for starters. I assume you will bore it .005 over stock?
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    U want to save a little money then get 10.5:1 pistons port ur heads and keep the cc to 64cc on the heads.
    Forged pistons and connectin rods but stock crank. U will have enough protection to go north of 500hp and even put on a supercharger in the future.
    This way you keep the internals pretty much the same but ur strengthenin them for more upgrades tomorro.
    If u want a noce stockish idle with great power then lpe gt11 cam with stock rockers will be ur perfect cam.
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,161
    GENERAL ENGINE DATA
    Engine Type V8
    Displacement 5.7 liters (5665 cc) (346 CID)
    RPO LS6
    VIN S
    Bore 99.0-99.018 mm (3.897-3.898 in)
    Stroke 92.0 mm (3.622 in)
    Compression Ratio 10.5:1
    Firing Order 1-8-7-2-6-5-4-3
    Spark Plug Gap 1.016 mm (0.04 in)
    Feb 2013
    52
    Nice
    Quote Originally Posted by Naf View Post
    Nice , sounds like a good game plan...
    So let me just clarify it for myself..
    Pistons -stock spec but forged
    Rods - stock spec but forged
    Heads- port but keep at 64cc
    Cam- LPE GT11...
    Would I feel the power difference with a cam and head port?...estimating hp gain?
    thanks.
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    You would be around the 450/450 mark And yes u would feel the increase in power. Dont forget the ls7 lifters and bearin upgrade for the stock rockers
    Try and get bosch injectors and not the crappy ford ones, i think 42lb injectors. The wider spray helps maximizes the atomization...
    1 3/4 primaries with a 2.5/3.0" catback. 2.5" more torque, 3.0" more hp...its ur choice...
    Feb 2013
    52
    Are the ls7 lifters a must?...or can I run that cam with the stock lifters and rocker bearing?
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by 05 CTS-V LURKN View Post
    How many miles on your current lifters? That cam has lifts of 0.631/0.644 inch. The stock rocker geometry is designed for lifts of 0.550, and is marginal at lifts of 0.600 inch. The stock rockers will scrub the valve tips at those lifts. Additionally, Lingenfelter recommends valve springs with open spring pressures in the 400-425 range. If you install valve springs that exceed that recommendation it will worsen the effect of the valve tip scrubbing. If you want to run stock rockers, and you are going to have the heads ported, I would let either Advanced Induction or Total Engine Airflow port the heads and spec a cam that will work with the heads and your stock rockers.
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    Darkman, ur right about the springs but the lift is nuttin compared to the gt9 cam...the stock rockers will be fine...
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    How would you know - you ran that cam with Yella Terra roller rockers. http://www.cadillacforums.com/forums...l#post10922362
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    My friends went cheap and ran them with stock rockers and lpe also recommends the stock rockers with their cams...
    Feb 2013
    52
    Quote Originally Posted by darkman View Post
    Oohhh, Ok I see...
    But...Honesty I don't wanna go through all the work and parts...
    I mean thanks a lot for the info, but I just wanna get the car running hah and a bit stanger....
    So would the 10:7 compresión pistons no be a good idea if I'm just gonna throw them in there and start it ?
    Do you know of any simple drop in piston brands ?
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Oohhh, Ok I see...
    Your original post provided very little detail - like: What broke in the motor and what did not? Why are replacing pistons?
  16. #14
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    I think in his first post... He meant blown as in blower... I read it the same way you did though... As in blew the motor.
    Op- if you are going to rebuild the lower end have you checked into a Callie's rotating assembly? They come with a Callies compstar, rods and diamond pistons. Or maybe eagle's rotating assembly. I've kinda narrowed it to those two for my next motor.
  17. #15
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by RyRidesMotoX View Post
    Yeah, I noted the ambiguity but, decided blower guys don't usually ask about increasing compression......
  18. Remove Advertisements
