Ls6 build & questions - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
2004-2007 Cadillac CTS-V Performance Mods Discussion, Ls6 build & questions in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by darkman Yeah, I noted the ambiguity but, decided blower guys don't usually ask about increasing compression...... Yea ...
  1. #16
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    Quote Originally Posted by darkman View Post
    Yea true. I think the 10.7:1 is a little high. Especially since he is going to have the motor apart. If everything is remaining equal as far as stock measurements and only the quality of the metal is increasing, then I would just put some dished, maybe 15cc pistons in there. Lower the compression and run more boost.
  2. #17
    05 CTS-V LURKN is offline Cadillac Owners Member
    Automobile(s): 2005 cadillac cts - v LS6
    Feb 2013
    52
    Your original post provided very little detail - like: What broke in the motor and what did not? Why are replacing pistons?
    Ohhh f*** sorry about that hahaha
    So yeah I ment blown as in 4 broken pistons hahah
    So now knowing that, what do you think about 10:7 drop in pistons...will it run with no problems. .and everything else being stock?
    Quote Originally Posted by RyRidesMotoX View Post
    Yeah sorry about that dude...
    I blew it as in Broke it hah 4 broken pistons. ..
    But yeah now knowing that..what do you think about 10:7 drop ins with everything else stock?...
    Will it run fine?
  3. #18
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,213
    Re: Ls6 build & questions
    Quote Originally Posted by 05 CTS-V LURKN View Post
    So you broke 4 pistons in a stock LS6 without damaging any other engine parts?
  5. #19
    Feb 2013
    52
    As crazy as it sounds man...
    Yeah I got lucky!...
    2 on each side...
    Well I do need to get one of the heads resurfaced...it's kinda chewed up at the valve bowl...
    It's crazy...I have no idea how any of the broken pistons pieces didn't f*** up the valves...
    Dude it was bad...I found pieces of piston rings inside the cat..
  6. #20
    Jul 2012
    Wildomar, CA
    31
    976
    It didn't chew up the block like a piece of bubble gum?
  7. #21
    Feb 2013
    52
    No man...Just a little scuff on one of the cylinder walls but that's about it.
  8. #22
    tmonttt is offline Cadillac Owners Member
    Automobile(s): CTS
    Jun 2009
    26
    13
    Be sure that "scuff" is something that can be cleaned up with a .005 bore. There's not much room for error in these cylinder walls.
  9. #23
    Becker's Avatar
    Becker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 black with tan V
    May 2013
    31
    391
    that block sounds sketchy to me , four broken pistons!? yikes
  10. #24
    Jul 2012
    Wildomar, CA
    31
    976
    Did you check the water jackets for cracking and such? It would be easy to overlook something that would really jack stuff up later... If the block is going to a machine shop they should see anything but I wouldn't take anything for granted.
  11. #25
    Feb 2013
    52
    Yepp just did last night... everything seems to be ok...Looks like I would just need to scuff it down just a bit..
    So now my plan is just going with OeM REPLACEMENT pistons....
    Could you point me to the right direction where I could find a set..New or used
    Thanks
  12. #26
    Jul 2012
    Wildomar, CA
    31
    976
    Scoogin dickey, summit, jegs, whatever is cheapest... Summit has price match.
  13. #27
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    40
    594
    I would highly suggest against using used pistons. Cranks and rods are fine if resized. But not pistons.
    Sent from AutoGuide.com Free App
  14. #28
    V for victory is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2013 Dodge Durnago R/T
    Mar 2011
    Levittown, PA
    51
    243
    I used a Eagle rotating assembly in my stroked 383, 1987 Monte SS street car build. made 475 / 675hp with a 100 shot of NOS. Great product! 10.02 1/4 mile @ 125mph had to sell as it would only one speed.....Fast! LOL
  15. Remove Advertisements
