Lifters....yeah, its that time I think. - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 50
Like Tree4Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Lifters....yeah, its that time I think. in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by rand49er ...okie dokie..... Is that a technical term?...
  1. #31
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,213
    Re: Lifters....yeah, its that time I think.
    Quote Originally Posted by rand49er View Post
    ...okie dokie.....
  2. #32
    BigDaddy-V is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V 04 LS6
    Mar 2013
    Wylie, TX
    412
    Okie dokie is a big term for me! Also an elementary teacher so it fits for me!
    BDV
  3. #33
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,213
    Quote Originally Posted by BigDaddy-V View Post
    BDV
    I looked it up - it means copacetic.
  5. #34
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,833
    Quote Originally Posted by darkman View Post
    Highly. Thought I'd throw it into the conversation to impress a few of you with my sophisticated acumen.
    darkman and BigDaddy-V like this.
  6. #35
    Mar 2013
    Wylie, TX
    412
    Copacetic and acumen. Better slow down some of these guys might not know what we are saying! Hehe.
    BDV
  7. #36
    Wingsfan4life's Avatar
    Wingsfan4life is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V Black Raven
    Aug 2011
    Brooklyn Center, Mn
    46
    232
    I have a similar tap sound on mine..I asked about octane because I run a couple gallons of 110 mixed with 93 once or twice a week in warm months..and I've noticed the tap goes away with that mixture..
  8. #37
    2007-V is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Oct 2013
    121
    Yeah, I really need to get off my butt and check the injectors. Since it comes and goes now I am thinking that is more likely at this point....well that or something is trying to repair itself, which I am not upset about...lol
  9. #38
    nikdsctsv is offline Cadillac Owners Fanatic
    Automobile(s): none
    Jul 2009
    33
    139
    Doing valve springs and lifters just involves popping the heads off (after removing the intake man). Doing a cam, too, means you'll have to also take off the front fascia, drain the coolant system, and remove the radiator (wud I forget?) in addition to the "cover, oil pump, timing chain, and cam." "20 minutes?" You must be one of those NASCAR mechanics.
    Ok, I'm going to take a minute and let you re read what you wrote.
    Ok.
    Now, why do you have to remove the front facia? I assume you mean bumper and it is not required. If you have the heads of and have not drained the coolant, I'm impressed and will just stand back and watch. I like how changing a cam became more difficult then "popping off the heads" lol if you have the heads off the whole car is in pieces. Removing the radiator is easy as pie (since chances are the water pump and hoses are off by now), and using a puller to take off the balancer is easy as well. Once that is done for the in experienced lsx tech it would take an hour tops to remove the cover, oil pump, chain and cam and reinstall it all back. This is not rocket science. But hey, popping off them heads is easy, hell, I bet you can reuse the head gaskets!
  10. #39
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,833
    Quote Originally Posted by nikdsctsv View Post
    Ok.
    You're right about the coolant being drained before removing the heads.
    I reread your post. Here's your quote: "Removing the cover,oil pump, timing chain, cam? After the balancer is off those things take roughly 20 minutes."
    I guess my assumption is that there would not be room to slide the cam out without having the front fascia removed. You must admit, it certainly would be a whole bunch easier that way. Even if there is room to remove the cam without doing this and neglecting your omission of the radiator removal, how many of us casual, weekend, backyard mechanics do you think can realistically accomplish this in "20 minutes" while taking appropriate care not to booger up the cam lobes and bearing journals? In your case, if you can forgive me, I have to double down and acknowledge your prowess as a highly-worthy mechanic because most of us just don't do this stuff on a regular basis and lack the confidence that we're taking proper care of our precious cars, and I'm assuming the OP fits that description.
  11. #40
    Automobile(s): none
    Jul 2009
    33
    139
    You're right about the coolant being drained before removing the heads. I reread your post. Here's your quote: "Removing the cover,oil pump, timing chain, cam? After the balancer is off those things take roughly 20 minutes." I guess my assumption is that there would not be room to slide the cam out without having the front fascia removed. You must admit, it certainly would be a whole bunch easier that way. Even if there is room to remove the cam without doing this and neglecting your omission of the radiator removal, how many of us casual, weekend, backyard mechanics do you think can realistically accomplish this in "20 minutes" while taking appropriate care not to booger up the cam lobes and bearing journals? In your case, if you can forgive me, I have to double down and acknowledge your prowess as a highly-worthy mechanic because most of us just don't do this stuff on a regular basis and lack the confidence that we're taking proper care of our precious cars, and I'm assuming the OP fits that description.
    Ok, I can see your point. The radiator is very easily removed. But I'd dare to say it is easier to change the cam, then take off and reinstall the heads. Just last month I helped a buddy who does not belong working on cars, to change his springs and cam in his c5z. I'm just saying the cam is very easy to change.
  12. #41
    Oct 2013
    121
    I wouldn't say I am a total newb...but by no means an expert either. Also this is my only car currently so downtime is my biggest issue more-so than the actual difficulty level.
    With that said I wouldn't be doing a cam until I could do all the "supporting" mods to go along with it and that is a ways off at this stage....unfortunately
  13. #42
    Mar 2013
    Wylie, TX
    412
    Have you figured out what it is yet Buddy? Just wondering.
    BDV
  14. #43
    MarkFJ40 is offline Cadillac Owners Member
    Automobile(s): 05 CTSV
    Oct 2013
    62
    Good chance if you do have a lifter that cratered that the cam lobe is also damaged. Might as well do it all while you have it apart.
  15. #44
    Becker's Avatar
    Becker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 black with tan V
    May 2013
    31
    391
    Quote Originally Posted by MarkFJ40 View Post
    agreed... too bad you can't find out what is wrong without tearing it apart. keep us posted, I think you should get a stethoscope (autozone sells them) and see what you can find. You will know if its inside the block with a stethoscope.
    Could also try and get a video of it and all around the areas, including by the door or underneath. it may help others help you. just a thought!
  16. #45
    Oct 2013
    121
    I looked all over and couldn't find my stethoscope so had to order another one....Prime should have it here tomorrow/Wednesday. I have a couple of videos I have already made a bit ago (links below), however can make new ones if there is a certain area anyone would like to hear etc...
    Cold start: http://www.youtube.com/watch?v=Gvt3xvgVVM8
    After drive to work, approx. 185 oil temp: http://www.youtube.com/watch?v=CUx6qCjF3fQ
    I am not worried about the "sewing machine" noise that the LS2 is known for, its the other "tick" noise. The odd thing is it now comes and goes in severity, to a point of I think its almost gone and then if I get up around 200 on oil temps it will come back....however never more than other times it occurs.. so like it has a ceiling on severity but doesn't always stay at said ceiling....
    I hope that makes sense....
  17. Remove Advertisements
