MAF questions
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
Like Tree6Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, MAF questions in Cadillac CTS-V Series Forum - 2004 - 2007; So I have been talking with another new forum member and we are wanting to tinker with things and trying ...
    BigDaddy-V is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V 04 LS6
    Mar 2013
    Wylie, TX
    412
    MAF questions
    So I have been talking with another new forum member and we are wanting to tinker with things and trying to work out the kinks on some initial plans for an CAI change and the MAF seems to be somewhat of an issue. Wanting to go to a bigger 4 inch tube through out and not have to worry about cutting down airflow throughout the system. I have been looking into the thought of the LS3/LS7 style maf placed in a certain location of the tube for easier access and positioning and also cutting down on the amount of tubing to be used for space and clearance issues that might arise. My question is after looking at the connectors for our ls6 maf and those previously listed maf's are they the same style plug? Is it really as easy as plugging it in and tuning to the new sensor?
    Please enlighten me a bit so I can switch gears or go back to the drawing board.
    BDV
    Becker's Avatar
    Becker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 black with tan V
    May 2013
    31
    391
    Re: MAF questions
    what are your final expected results with this? just curious
    Mar 2013
    Wylie, TX
    412
    Re: MAF questions
    Really not a clue. If it shows that it increases air flow then that is great. In my mind it is something that combined with other pieces like a cam or heads or headers or other things that will alter flow characteristics would add great benefit and grow the changes exponentially than by just doing those mods. I know most everybody will say that it is a waste of time and wont help that much on a stock motor but thinking beyond that is the basis. Also, it is kind of the thing to do now that Football season is over and I can focus on things like that more! Got to fill the void somehow.
    BDV
  5. #4
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    I think the connectors are the same. But you will need to rescale your computer to read the new maf properly. Otherwise with a larger tube the air velocity will go down and the computer will be like "Oh shit no air yo!!! Where are we?"... Which could lean you out considerably.
    So it will need a tune but you probably figured that anyways.
  6. #5
    Mar 2013
    Wylie, TX
    412
    Re: MAF questions
    I had already thought about that and have been reading many side posts on other forums like LS1 Tech and others about it and changing maf's out on different cars. I knew the tuning side was going to be the bigger part of the fine tuning and actually making it work the way that it should, however to get to that part first had to even know if the connectors would work or if there was an adapter or something. I just figured it would be something to tinker with and would maybe add the benefit of looking cool under the hood! hehe
    And if it showed no positive gains or had reverse effects then I would know and could stop kicking the idea around in my head. I know most of us on this forum have the Tim the Toolman Taylor way of thinking with "why not mod it if it is working perfectly fine" and give it more power so......
    BDV
  7. #6
    tommy compton's Avatar
    tommy compton is offline Cadillac Owners Connoisseur
    Automobile(s): 06 CTS-V
    Mar 2007
    tha peg
    2,497
    Re: MAF questions
    Pretty sure you have to repin and get the ls3 connector, I did on my Ls2 for a ls3 MAF
  8. #7
    Mar 2013
    Wylie, TX
    412
    Re: MAF questions
    Quote Originally Posted by tommy compton View Post
    How was that and was it hard to do? Also could you tell a difference in the flow or how it worked? Was it better or worse anything you can share would be great!
    BDV
  9. #8
    Mar 2007
    tha peg
    2,497
    Re: MAF questions
    It's not hard, I think racetronix or caspers electronics should have the connector for cheap. There is also pics of pinouts for the various mafs floating around on google images. I went the ls3 maf and 4" tubing for a blower set up, so I can't say what benifit it will be for a stockish set up.
    Repinning is always a better option than cuting a splicing wires IMHO
  10. #9
    Mar 2013
    Wylie, TX
    412
    Re: MAF questions
    Thanks Tommy for your input on it. It helps knowing if I decide to go that route it can be done. Now it just comes down to the tuning side of it. Now just need to decide if the tubing can even be done to give an option to go to the different MAF. Might just stay with the LS6 one but I just don't know how it will shake down. Thanks for some input guys and if there is anymore out there I sure will take it.
    BDV
  11. #10
    DMM's Avatar
    DMM
    DMM is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2010
    Maryland
    40
    389
    Re: MAF questions
    The LS6 MAF is completely different. There is not enough resolution in the P59 controller MAF tables to use the LS3/7 MAF unless you really know how to tune and use it only for the upper Hz ranges.
    Also, the P59 PCM is hard limited by its 512 gram/cyl airmass maximum. Even if you did need the LS7 MAF to get below the maximum 12k Hz you'd be at the PCM limits anyhow, so you'd have to scale the tune to get around all the limitations...which is a PITA.
    If you don't actually need the LS7, save the money and the PITA.
  12. #11
    Mar 2013
    Wylie, TX
    412
    Re: MAF questions
    Thanks DMM for some straightforward honest advice. I am not a tuner nor a computer aficionado to say the least. I never even though about the limits of the factory ecm either. This is why I come to the forum. I wouldn't want to change that much and i know the ls6 maf will hold up to like 550 horse and i am nowhere near that yet or plan to be all that soon. Just looking for options to see if this plan will work.
    BDV
  13. #12
    Becker's Avatar
    May 2013
    31
    391
    Re: MAF questions
    Interesting information. I am curious on the gains from the inlet size upgrade. On a stock displacement Ls6 I dont believe more is better, well for the price point. A good CAI and a ported TB and a 92/102 intake with a tune wouldn't be cost effective to me. I personally would up my displacement and/or head flow, followed by a bigger intake like 92 or 102 ported and a throttle body. Heck if you get to a bad enough setup you might be switching from MAF to SD.
    I could be totally wrong here though ...
    My plan is to wait and do mods in a group to save time and money and wasted money on tunes.
    But BDV if you decide to do anything I would still read follow the progress
  14. #13
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Re: MAF questions
    Quote Originally Posted by DMM View Post
    Also, the P59 PCM is hard limited by its 512 gram/sec airmass maximum. Even if you did need the LS7 MAF to get below the maximum 12k Hz you'd be at the PCM limits anyhow, so you'd have to scale the tune to get around all the limitations...which is a PITA.
    Can you summarize the LS2 CTS-V PCM's strengths/weaknesses in the same way?
  15. #14
    Mar 2013
    Wylie, TX
    412
    Re: MAF questions
    Becker,
    My plan has been always evolving with new info along the last year or so. I will be doing a cam at some point followed up by porting the heads and changing those up. I will be doing the high flow cat mod this summer so I will see how much that changes anything. I agree with you on the tuning cost part but any of the big mods would be done in time with the others to save on those costs. I am still really digging going the modified ls6 intake with the 90 snout. For the money I think it would be worth it. Only time and what money I can get going forward is the main factor.
    BDV
  16. #15
    Becker's Avatar
    May 2013
    31
    391
    For sure bdv. I've had a couple cars that I've put money and mods into and I've finally realized for myself that best way to go on the caddy is drive train before performance. I have enough power to break my car stock it seems which scares me on a DD. This is off topic though
    I commend outside thinking I just was curious on what gains would be made on upgrading the intake to the extent of re wiring a MAF and tuning.
    Sounds like our cars are right around the same as a project for the next few years. I'm jealous of the veterans on here that throw a bunch of time/money/creativeness into there V. I'm just not there, yet!
    BigDaddy-V likes this.
  17. Remove Advertisements
