Hurst shifters for the V. - Page 2
Page 2 of 10 FirstFirst 12345678910 LastLast
Results 16 to 30 of 146
Like Tree32Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Hurst shifters for the V. in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by ctsvoom I was just about to ask if you were doing any with black knobs. Are they ...
  1. #16
    PISNUOFF Guest
    Re: Hurst shifters for the V.
    Quote Originally Posted by ctsvoom View Post
    I was just about to ask if you were doing any with black knobs. Are they all spoken for or can I get one of the 3 you're going to have done.
    None of the black ones are spoken for at the moment. Mention that you want a black knob in the comments section of the Paypal transaction.
  2. #17
    2007-V is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Oct 2013
    121
    I should be ordering one of these soon, however I have searched around and cannot seem to find the "how-to" on the install. I remember seeing it a-while ago but seem to have lost my research skills....or something.
    Also other than what you send and shifter bushings is anything else needed....or rather would be a good idea while in there? It doesn't look like it but want to be sure.
  3. #18
    PISNUOFF Guest
    The only other thing would be a set of polyurethane outer linkage bar bushings from either Luke at Lindsay Cadillac or Creative Steel.
    I send the installation instructions from my modified stock shifter along with the kits. The install how to floating around says to remove the entire center console, that is not necessary.
    Basically you remove the knob and boot, remove a hold down plate (4 nuts and 2 bolts), remove the bolt at the base of the shifter, drill out two rivets from the top. To install you transfer the pivot tube and bolt to the base of the Hurst, install two bolts through the metal hold down cup (presses the Hurst pivot housing between it and the body), reinstall the hold down plate, install the foam insulation and knob/boot.
  5. #19
    Oct 2013
    121
    Ok cool, and the CS are the $25 set they sell im assuming (I only see the one option for shifter bushing options). If so then I already have a set of those somewhere I never put on my old 05.
    Thanks again for the info, step 2...commission check....step 3...shifter and mounts...lol
  6. #20
    PISNUOFF Guest
    That would be the ones you need.
  7. #21
    76Y82 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    May 2013
    27
    20
    Quote Originally Posted by PISNUOFF View Post
    I'll have three kits with black knobs ready to ship on Friday.
    Ah, wish I had known about the black knobs before I got mine. Oh well, I'll pick up one separately.
  8. #22
    PISNUOFF Guest
    Quote Originally Posted by 76Y82 View Post
    Sell the white one on eBay. The are going for $30ish new.
    .......Or I could order an extra black kit and send you the black knob then you send me your white one. Email me if you want me to swap it out for you.
  9. #23
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    Quote Originally Posted by H-town_V View Post
    Hurst also offers a black shifter knob option. Same part number just black. I think the chrome shaft with a black knob would look killer, or you could plasti dip the chrome for a more stealth look.
    Black knob would be the way to go. I dipped the stock of mine and it didn't look right so I peeled it off. Well that's my opinion anyways. There needs to be a little color contrast there.
  10. #24
    May 2013
    27
    20
    Yeah, I'll just sell the white one and pick up a black one from Jegs. They've got them for like $30.
    No worries, thanks for the offer though!
    PISNUOFF likes this.
  11. #25
    ahahnu's Avatar
    ahahnu is offline Cadillac Owners Connoisseur
    Automobile(s): '05 LS6 V Stealth Grey; '14 Z71 SLT Sierra 1500 Stealth Grey
    Dec 2004
    Tailgating at Giants Stadium
    37
    2,821
    I have the UUC shortie in there now. The rivets were drilled years ago. More of a direct swap now?
  12. #26
    PISNUOFF Guest
    Same swap, just no drilling out rivets.
  13. #27
    ctsvoom is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cts-v
    May 2011
    43
    106
    Mine sent Brian and thanks.
  14. #28
    PISNUOFF Guest
    I have successfully adapted the stock attachment to the extra stalk. This gives you the option of using the stock CTS-V knob and boot instead of the exposed chrome Hurst stalk and knob. I will ask that you return your stock shifter if you want this option as I cut the top of the stalk and waste one of my cores in the process. Please note that you would like this in the notes section of the Paypal transaction.
    *** You will receive both shifter options when you ask for this.
  15. #29
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Brian, what are the chances that I could get a Hurst-modified-for-V-knob shifter, if I don't have a core, to do a direct A-to-B-to-C comparison between your shifter, 54inches shifter, and the improved CTS cup/Katech shifter?
    54inches likes this.
  16. #30
    PISNUOFF Guest
    No problem. Email me.
  17. Remove Advertisements
