Intake Replumb
Page 1 of 3 123 LastLast
Results 1 to 15 of 35
2004-2007 Cadillac CTS-V Performance Mods Discussion, Intake Replumb in Cadillac CTS-V Series Forum - 2004 - 2007; For fathers dayI finally took off the squeeze pipe. Came out pretty good. I just had to trim the elbow. ...
    lasstss's Avatar
    lasstss is offline Cadillac Owners Connoisseur
    Dec 2003
    Ellicott City
    2,873
    Intake Replumb
    For fathers dayI finally took off the squeeze pipe. Came out pretty good. I just had to trim the elbow. Also installed the HPS pads.. Hopefully less dust..
    Alu pipe came from Burns Stainless.
    http://www.stealthwork.com/
    All silicone parts made by OBX racing
    JOEYCTS-V's Avatar
    JOEYCTS-V is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V Sedan
    Aug 2004
    New York
    1,729
    Re: Intake Replumb
    It looks very neat. Where did you get the throttle body elbow?
    EDIT: Didn't see you included that info.
    CVP33's Avatar
    CVP33 is offline Cadillac Owners Master
    Automobile(s): '04V, '05V, '06SRT8, '10V, '13ZL1, '12 V, '16 Z06 SC757
    Feb 2004
    Killer of diffs 7X
    50
    6,441
    Re: Intake Replumb
    That looks very familiar.
    HDMLNIUM's Avatar
    HDMLNIUM is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V SOLD /// 2009 CTS-V own
    Feb 2005
    Maine
    50
    1,036
    Re: Intake Replumb
    Looks great, my next mod...:coolgleam
    Bill
    05 CTS-V--- Light Platinum
    3M Clear Bra and Tinted windows, LS6 Emblem, Stealth-V z06 fuel rail covers, Lasstss Billet interior pieces
    B&B Headers-high flow cats-and 3" resonator exhaust, Lingenfelter CAI, UUC shifter, Full BMR...
    Online Photos http://photobucket.com/albums/v466/HDMLNIUM/
    CVP33's Avatar
    Feb 2004
    Killer of diffs 7X
    50
    6,441
    Re: Intake Replumb
    Here's mine.
    willsctsv is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Jan 2005
    Queens NY
    42
    864
    Re: Intake Replumb
    They all look like the FFV to Me!!
    Imitation is the sincerest form of flattery!
    lasstss's Avatar
    Dec 2003
    Ellicott City
    2,873
    Re: Intake Replumb
    Quote Originally Posted by JOEYCTS-V
    Na, I added it rather than adding another post. I had 2 elbows, one was rubber like CVP33 has, its a smoother transition. The one I used is reinforced silicone but its a hard 90, gives a little more room. Still better than the divided squeeze pipe.
    StealthV's Avatar
    StealthV is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 Z06 / 2013 F150 EcoBeast / 2008 Twin-Turbo Bimmer
    May 2004
    MN>ND>MN>SD>IL>MN>IL
    48
    4,860
    Re: Intake Replumb
    Divided squeeze pipe, lol. Can't go wrong with polished stainless.
    Rey
    Rey is offline Cadillac Owners Fanatic
    Oct 2004
    Salem, OR
    476
    Re: Intake Replumb
    The exterior of the metal tubing picks up a lot of heat. Polishing, in addition to looking nice, does reflect some of that heat. I haven't measured the inside air temp, but I did measure the exterior of my unpolished aluminum tubing. It was running 125-135 degrees as measured with an hand-held infared thermometer. This was about the same temp as the throttle body (with the water connectin detached). Then, I wrapped the tubing with simple and cheap pipe insulation "tape". This reduced the outer wall temp of the tubing to 90 degrees.
    Another thought is that the path of the intake makes it a secondary radiator shroud, the primary being the fan shrouds themselves. I am thinking that some sort of simple heat shield between the fan shrouds and the intake tube would be helpful. Alternatively, perhaps some small extenders on the fan shrouds might work.
    I suspect that these Gen III motors are oversensitive to intake air temps because I suspect that GM is very aggressive in retarding ignition as intake air temps rise - like retarding the ignition well before knock sensors are activated.
    It would be an interesting experiment to see what effect icing the intake manifold would have on a dyno run. It is simple to do, just dump a bag of ice onto the top of the intake manifold and wait five minutes for a cool down.
    lasstss's Avatar
    Dec 2003
    Ellicott City
    2,873
    Re: Intake Replumb
    I have read a lot of that stuff. The pipe is 9" long. The 'residence' time of the air thru that pipe is negligeable. The heat given off by 'skin effect' is also small. If it were a tank holding compressed air and we were cooking it for an hour it might be an issue. Pulling air from around the nose of the car is more of a problem than materials. With the hood closed all parts normalize to the surrounding temp.
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    Re: Intake Replumb
    Martin,
    What did you do about the factory airbox and filter? Leave those the same?
    -Chris
    lasstss's Avatar
    Dec 2003
    Ellicott City
    2,873
    Re: Intake Replumb
    Quote Originally Posted by trukk
    Martin,
    -Chris
    I did but I do have the K&N. As I now have about 3500 mi on my 04 it doesent get much use. K&N's are a pain for a daily driver.. IMO..
    The after market peices surly add some horsepower but Im waiting to get a system that gets out of the engine compartment. I may fool with it after the mag install.
    Rey
    Oct 2004
    Salem, OR
    476
    Re: Intake Replumb
    While I agree with Lasstss that the residence time of air passing through the metal tubing is negligible, in real city driving where there is stop and go, heat soak will be a big factor in intake air temperature. I did some simple testing using digital thermometers attached to the outside of the grill and the inside of the stock plastic intake just at the airbox. Generally, I found about a 20 degree temp differential; but when the car sat for as short as five minutes the differential soared. I saw as much as a 75 degree differential. Once driving again, the heat differential decreased, but it took more than five miles of highway driving for the differential to stabilize to 20 degrees.
    Just covering the stock intake with mylar home dryer ducting as a heat shield brought the differential down to about 8 degrees; and the heat soak differential was more in the range of 40-50 degrees.
    All this doesn't make much difference on a long trip/road race or on a dyno run. But it does make a material difference in city driving.
  16. #14
    Automobile(s): none
    Jan 2005
    Queens NY
    42
    864
    Re: Intake Replumb
    if your city driving you won't need the extra 5hp your loosing due to heat soak! Right!
  17. #15
    LV_V's Avatar
    LV_V is offline Cadillac Owners Connoisseur
    Automobile(s): '11 Evo Green V Coupe - 6MT
    Feb 2005
    Las Vegas
    33
    1,684
    Re: Intake Replumb
    What size pipes/elbows do I need to order to replace everything from TB to MAF?
    I just ordered the Lingenfelter K&N filter to put into my More Performance heat shield. I want to replace the ugly, constrictive factory "squeeze pipe" as well.
  18. Remove Advertisements
