265/40-18 on stock wheels(all around)
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
2004-2007 Cadillac CTS-V Performance Mods Discussion, 265/40-18 on stock wheels(all around) in Cadillac CTS-V Series Forum - 2004 - 2007; I know from a little research that they will fit with stock suspension... So I'm just wondering who has run ...
    H-town_V's Avatar
    H-town_V is offline Cadillac Owners Fanatic
    Automobile(s): 05 cts-v
    Feb 2013
    341
    I know from a little research that they will fit with stock suspension... So I'm just wondering who has run this wheel/tire setup. What's the pros if any or the cons.
    I just ordered some continental dw tires in 265/40-18 and can't wait to get them put on.
    NickL84's Avatar
    NickL84 is offline Cadillac Owners Member
    Automobile(s): 2005 Cts-V
    Jun 2012
    Boston, MA
    32
    39
    Re: 265/40-18 on stock wheels(all around)
    As long as the tires are of equal or better load/speed rating, you should be fine. You may run into rubbing issues in the front while in a full turn, but I can't confirm that.
    BigDaddy-V is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V 04 LS6
    Mar 2013
    Wylie, TX
    412
    I don't have any clue how they will do on the car but will look forward to hearing what you say about them. as I just went stock size when I got new tires last year because I wasn't sure if we could do wider on that rim. I would like to at some point if those work get some wider ones.
    BDV
    PISNUOFF Guest
    Besides looking small in the wheel wells and your speedo being off you shouldn't have any issues. I've run 275/40's on the rear for many years so fitting a 265 on the stock rim is not an issue.
    carlson_mn is offline Cadillac Owners Enthusiast
    Automobile(s): Platinum 06 CTS-V, kooks, magnaflow
    Jul 2012
    MN
    34
    636
    They're going to be a little smaller than stock size tires is all. There's pros and cons to go along with that.
    PISNUOFF Guest
    I thought 255's were the largest you could go on the front without hitting the knuckle with the inside top of the tire.
    H-town_V's Avatar
    Feb 2013
    341
    Thanks all... If I have any issues up front I can exchange them for another size. ----------
    Quote Originally Posted by PISNUOFF
    I hope the wheel gap is not awful. The tire diameter is only 1.3% smaller than stock.
    Also can a tuner correct the speedo?
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    I've run 255/40, 265/35, and 275/35 up front, but all on TD wheels.
    H-town_V's Avatar
    Feb 2013
    341
    Quote Originally Posted by UnsafeAtAnySpd
    Any rub issues with the 265's or bigger. I really like the TD wheels... However I've stashed some money away for a set of f14's in the spring
    Jul 2012
    MN
    34
    636
    I'm currently running 255/45 tires. Not as wide but taller than stock. If I hit a major dip or bump in the road at speed the fronts rub. Other than that no contact.... makes me think you will be okay. Personally I couldn't stand the wheel well gap with the stock tires which is why I went a .5" larger, not to mention I kinda like the beefy look and the extra 10mm doesn't hurt. I can notice the slight gear reduction and I like it especially in 1st gear.
    PISNUOFF Guest
    Weird. I couldn't even get the tip of my pinky between the tire and knuckle with 255/45's up front on stock 8.5" wide wheels.
    A tuner can fix the speedo in two minutes. The speedo will only be 2.5% off.
    Aug 2007
    Arlington, VA
    31
    1,647
    Quote Originally Posted by H-town_V View Post
    I haven't had any issues with those up front or 285s in the rear and the car is now lowered. I run a decent amount of negative camber (not enough to not trash the edges of R6s though).
    Quote Originally Posted by PISNUOFF View Post
    It might be the different offset or maybe the lower profile tires. It was tight though.
    I do think eventually I want to get some 19s for the street and switch the TDs back to track use. Maybe I'll still keep the stockers for rain tires.
    2007V is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V, maggie
    Apr 2011
    85
    I have 265's up front, stock suspension and stock alignment specs. It is close to the knuckle but fine. 275s in the front would probably take a small wheel spacer
  16. #14
    H-town_V's Avatar
    Feb 2013
    341
    Quote Originally Posted by 2007V
    265/40-18 or another size? Can you post pics?
  17. #15
    Apr 2011
    85
    Yep, 265/40zr18 Michelin PSS.
    I can email you some pics but it won't let me upload from my iPad. They really don't show much. I can get an inspection mirror I between the knuckle and the tire but that is about it. Probably 3/16" or 1/4" of clearance. It is very close but clears.
  18. Remove Advertisements
