steering rack failure - Page 7
Page 7 of 7 FirstFirst 1234567
Results 91 to 98 of 98
2004-2007 Cadillac CTS-V Performance Mods Discussion, steering rack failure in Cadillac CTS-V Series Forum - 2004 - 2007; I was looking all over for the power steering pump pulley bolt - like an hour. Thought I lost it ...
  1. #91
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Re: steering rack failure
    I was looking all over for the power steering pump pulley bolt - like an hour. Thought I lost it then started looking at pics - there is no bolt, pressed fit. I bag and tag everything so I was losing my mind. My replacement rack finally arrived and I installed it along with coolant hoses, power steering pump etc.
    Once it get my front wheels on - ATI Superdamper and pinning kit. Then put jackstands on the rear and install those Swift springs. I got parts all over the place right now.
    Regarding the Geforce, wow! Sounds like they dropped the ball. FWIW Creative Steel shipped the 8.8" fast and 100% complete - perfect fitment.
  2. #92
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Quote Originally Posted by philistine View Post
    Seems like they've had issues with this before. The amazing thing, from my perspective, is that they don't just try to spin these by hand before shipping them out. I'll probably put more details on your other thread.
  3. #93
    Mar 2011
    2,045
    Philistine, did you convert anything over to AN-style fittings, and if so, what did you pick? Last night, one of my power steering hoses basically blew itself in half. Right where I occasionally drip power steering fluid on it.
    After doing more research today, I will be upgrading the hoses and potentially installing an orifice to reduce flow by about 25%. As I figure stuff out, I'll update this post with the parts list.
    Power Steering Pump
    - AC Delco 21997867 - $141.79 at RockAuto (reman), $123 on Amazon (reman), $145 on eBay (new)
    - OR -
    I came across the following CarCraft article, identifying that the stock GM pump requires 8 HP and the Tuff Stuff pump only requires 5 HP, reducing heat injected into the power steering fluid. 3 HP of losses = 2237 watts of heat. I left a message for their staff, and will let you know which pump we should use.
    I also want to talk to KRC one last time.
    Power steering pressure hose
    - Gates 365684 with 16mm swivel o-ring (Type III) and 18mm male o-ring x 61 3/4" - $39 at RockAuto, $35 on eBay
    Adjustable Flow Valve
    Heidt's PS-101 (two 3/8" NPT feed, two 1/4" NPT return) - $89 on Summit Racing
    - OR -
    Detroit Speed 091401 16mm O-ring flow control valve - $26 from Summit Racing
    It may also be possible to retrofit the stock system with AN parts, but you'll need 16mm o-ring to 6AN (Earl's 361-9919DFJ) and 18mm o-ring to 10AN (Earl's 361-9919FFK) fittings for the rack. You'll also need Viton o-rings, msot likely. The following is from an old Corvette rack, not the CTS-V:
    You'll also need a 16mm x 1.5 o-ring to 6AN adapter for the pump. There's plenty of options...the Russell 648060 (aluminum), the Fragola 491971-BL (aluminum), the Aeroquip FBM2608 (steel), and the Earl's 919955 (aluminum).
  5. #94
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    good info...thanks fuzzy
  6. #95
    Mar 2011
    2,045
    For the brake hose, you'll want something that is rated significantly higher than the pump will be producing to prevent explosions under transients. I'm going to use 6 foot lengths of 2500 PSI PTFE Russell PowerFlex power steering hose. Russell 632610 (6AN) and 632720 (10AN), respectively.
    Earl's also sells some maximum strength stainless steel fittings with their Endura coatings for corrosion resistance. They're expensive and somewhat garish-looking, but in this application, it might be worth it. Power steering pumps run at 1250-1750 PSI, which may obliterate lesser hose and fittings. Here's the list. At the very least, you'll probably want two 620401 (6AN) and 620501 (10AN). If you plan on using that variable flow valve, you'll also need four of each, plus two PRE-60676E (6AN to 1/4" NPT) and PRE-61016E (10AN to 3/8" NPT) nickel-plated steel adapters.
    The decision between Earl's Temp-A-Cure 81900AERL (19 row) and Derale's 51610 (16 Row) 10000 series coolers will probably come down to price. I like the extra-long dimensions, build quality, and bracket on the Earl's part, but once you add the cost of the 10AN to ORB-10 fittings and 1508ERL bracket, you're out $230 instead of $135 for the Derale and its 50020 bracket kit.
    For reference, the Fluidyne FHP-10029 measures 18 x 9 x 1" (LxHxW) and the Derale 13103 7000 Series measures 16.625 x 7.625 x 0.75".
    The Earl's 81900AERL is black and measures 15.25 x 5.875 x 2.0". The Derale 51610 1000 Series measures 13.0 x 6.6875 x 2.0".
  7. #96
    philistine's Avatar
    Sep 2011
    821
    Ok you really did your homework here with fittings. I do have a spare rack, power steering pump, and high pressure hose.
    I purchased a replacement hose from Rockauto: Edelmann 92291
    The power steering pump, brand new: ACDelco 21997867
    The new power steering cooler: Derale 13103 Series 7000
    The hose clamps: EAR-900110ERL
    The Edelmann replacement hose does not fit exactly like OEM - it's a little off in some places but the metal end fits well enough up to the pump. The hose clamps I had left over from a previous project so I used those on the Derale cooler - dress it up a little.
    I have the luxury of being able to fit just about anything with the entire 'old' system sitting in a box - including those inner/outer tie rods that you mentioned Banski might need/want for measurements. I definitely think it's worth the effort of building some more robust lines. I can only imagine how many crud covered weeping power steering lines are out there. The high pressure hose fits end to end with threaded fittings. The low pressure hoses do not seem to be a problem - or is it?
    Believe it or not but that is as best it fits in there - there is your Edelmann fitment, bleh.
  8. #97
    Mar 2011
    2,045
    You know, I admit that I simply don't get that Edelmann hose. How hard is it to build one correctly? Also, another question: what's its purpose? I mean, what's the point of the rubber section?
    Philistine, if you see any problems with the parts I mentioned, please let me know. That's all I can ask. It's not fun driving the car at low speed without power steering, but it has taught me how much better high speed driving can feel. The car feels amazingly stable, even with a tenth of a degree of toe out.
  9. #98
    philistine's Avatar
    Sep 2011
    821
    Quote Originally Posted by FuzzyLogic View Post
    I'm guessing but it could serve as an expansion joint to protect the pump, rack or both - it is high pressure
    I'll definitely give it a closer look.
  10. Remove Advertisements
