Page 6 of 7 FirstFirst 1234567 LastLast
Results 76 to 90 of 98
Thread: steering rack failure
  1. #76
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Re: steering rack failure
    Quote Originally Posted by ctsv247 View Post
    I agree with this in normal spirited street operation. While I love it's parking lot manners, fast sweeping on-ramps require a lighter touch than I'm Accustomed to after owing various f-body cars.
    I wonder if a slightly larger pump pulley would slow the assist down without overly compromising low speed handling characteristics and pump capacity issues faced on the track?
    I think Turn One steering has done this with the V2. They lowered the pressure so there is more driver feedback. I find the Cadillac relaxing to drive with the luxury effortless steering. With the mods I have, there is enough feedback to enjoy spirited driving - not nearly the same with my roadster though.
  2. #77
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    Quote Originally Posted by FuzzyLogic View Post
    According to one of the experts, the stock power steering pump was not intended to run above 5000-5500 RPM. It's okay for sporadic use at high RPM, but that's about it. Extended high RPM usage (i.e. track conditions) will eventually destroy it.
    So if you could slow the pump down by say 10% or so, could you effectively raise its range of operation on the track while maybe increasing its steering effort just a bit?
    I know it could never be that simple.
  3. #78
    philistine's Avatar
    Sep 2011
    821
    So if you could slow the pump down by say 10% or so, could you effectively raise its range of operation on the track while maybe increasing its steering effort just a bit? I know it could never be that simple.
    More steering effort by reducing the pressure is exactly what was discussed when I called Turn One. However, they have more experience with the V2 than the V1.
  4. #79
    Feb 2009
    Greenville sc
    45
    992
    As is GM tradition, is the v1 style pump used on other GM platforms?
  5. #80
    Mar 2011
    2,045
    It will not increase its maximum operating RPM. The diameter of the impeller largely determines whether or not cavitation will occur at a given RPM.
  6. #81
    Feb 2009
    Greenville sc
    45
    992
    So changing the given rpm won't effect the cavitation occurrence for a fixed impeller diameter? If the only fixed component in this equation is impeller diameter, changing one variable (rpm) should change the other variable (cavitation).
  7. #82
    Mar 2011
    2,045
    You are correct. What I was trying to say was that installing a different sized orfice on the output of the pump will not change its rotational speed (driven by the serpentine belt). Therefore, its cavitation speed will be unaffected.
  8. #83
    Feb 2009
    Greenville sc
    45
    992
    What are your thoughts on changing pulley size?
    As a relative novice to the v I'm just getting familiar with the platform so I don't know if there's room for such a change or how common this particular pump is.
  9. #84
    Mar 2011
    2,045
    The practical problem with trying to increase the maximum RPM by 50% by using a bigger pulley is that you'll end up having to muscle the car around the parking lot.
  10. #85
    Feb 2009
    Greenville sc
    45
    992
    I might would trade a little parking lot prowess for a little less assist on high speed on-ramps....
  11. #86
    Mar 2011
    2,045
    That's where I feel like we're driving totally different cars. You must not have done any of the bushings, or your alignment is out of spec. The only time my V feels squirrely is when I'm braking down hard from 155-165 mph, and that's almost certainly because of my 0.08 of front toe out.
  12. #87
    Feb 2009
    Greenville sc
    45
    992
    I've only had it for a couple of months and yes it is 100% bone stock Cadillac rubbery mush. My initial impression is that the steering is a little over assisted but as you're pointing out this could change. I have plans to do an 8.8 with all the bushings and mounts along with a possible Camaro 6060 swap sometime this year so my impressions could change once all that is Done.
    After tons of research, I've found that You have done a lot of cool stuff with the v1 and I have a couple of quick questions for you. If you have the time can I pm you possibly?
    Thanks for your interest!
  13. #88
    Mar 2011
    2,045
    Of course. And by the way, if you haven't done the subframe bushings, the rear end could be kicking out sideways on you during turns when the OEM rubber bushings squash flat. It was first mentioned by neversatisfied on LS1Tech, and the idea eventually gained a lot of traction via a lot of small threads here and there. I was initially skeptical, but did some testing at various speeds and cornering loads and came away convinced.
  14. #89
    philistine's Avatar
    Sep 2011
    821
    ok so the power steering pump pulley doesn't have a bolt - search is over!
  15. #90
    Mar 2011
    2,045
    Quote Originally Posted by philistine View Post
    Come again?
    If you're looking for a little commiseration, my axles came in and Geforce screwed up the inner stubs. So I'm in for another several-week wait. At this point, I'm six weeks overdue to get this thing in the car.
  • You may not post replies
