LS7 clutch kit
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By VincentT
2004-2007 Cadillac CTS-V Performance Mods Discussion, LS7 clutch kit in Cadillac CTS-V Series Forum - 2004 - 2007; Well I talked with someone selling a ls-7 clutch kit for the 04 V. Has anyone else installed this and ...
    LumberjackHering's Avatar
    LumberjackHering is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Nov 2013
    Jacksonville, NC
    24
    20
    LS7 clutch kit
    Well I talked with someone selling a ls-7 clutch kit for the 04 V. Has anyone else installed this and have any more information about the kit. Any help is greatly appreciated
    rand49er's Avatar
    rand49er is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2005 CTS-V, 2011 Cruze 1.4T 6MT
    Jan 2005
    South Lyon, MI
    66
    13,455
    Re: LS7 clutch kit
    Do a Google search specifically including cadillacforums in the search, and you'll find a ton of info.
    '05 CTS-V, Maggie, Kooks, Hotchkis, Ground Control, Corsa, B&M, DSS/Hendrix, Full 3M Clear Bra, Autovation, V Headrests, CTS Console, STS-V 55w Fogs, Black Vette FRCs, Specter Werkes, Katech LS9 Clutch, SS Brake Lines, Heavymetals U-Turn Fuel Line Eliminator, Momo Combat Evo Shift Knob, Wldwhl Clear Sidemarkers, Linea Corse LC855 Wheels or OEM wheels w/'06-'07 Center Caps, plus a couple more. 472 RWHP/411 RWTQ (Mustang Dyno).
    VincentT is offline Cadillac Owners Member
    Oct 2012
    50
    Re: LS7 clutch kit
    If you use a C6 corvette slave cylinder, it is pretty much a bolt on.
    http://www.cadillacforums.com/forums...h-install.html
    http://ls1tech.com/forums/cadillac-c...used-read.html
    Between these two, you should have all of your information. The first is actually a Monster clutch install, but is great for how to actually get into the clutch area. The second has more LS7 specific information.
    Edit to add: This is another great link. Follow this when installing and it can help out with avoiding clutch engagement/disengagement issues.
    http://ls1tech.com/forums/manual-tra...need-shim.html
  5. #4
    Oct 2012
    50
    Re: LS7 clutch kit
    I'll also add that it is a great mod to undertake. Definitely worth the time. In addition, it makes no difference if you use either the OE flywheel bolts or the ARP bolts. The ARP bolts are overkill for what the clutch can handle, but I used them because the OE bolts were going to take forever to come in and they can be reused. The OE bolts are torque-to-yield.
  6. #5
    Nov 2013
    Jacksonville, NC
    24
    20
    Thank you all so much. The information you gave me has made up my mind. I'm ordering the kit today.
  7. #6
    voodoochikin04 is offline Banned
    Automobile(s): 2003 cts, 2004 Cts-v
    Nov 2012
    Norfolk, NE (eastern Nebraska)
    29
    316
    Re: LS7 clutch kit
    the hardest part about this install, is driving like a grandma for 500 miles.... im not even to 200 miles yet!!! so hard.
  8. #7
    Nov 2013
    Jacksonville, NC
    24
    20
    Re: LS7 clutch kit
    Quote Originally Posted by voodoochikin04 View Post
    I'm assuming that I need to drive slow to break it in and not ruin the new clutch?
  9. #8
    fweasel's Avatar
    fweasel is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Aug 2013
    Chicago
    247
    Re: LS7 clutch kit
    Speed has nothing to do with it, it's all about keeping clutch slip to a minimum.
  10. #9
    Nov 2012
    29
    316
    Re: LS7 clutch kit
    Everything ive ever read said to drive 200-500 normal daily driving miles. No launches. No high rpm running in lower gears. No speed shifting. Minimal clutch slippage....... Is that wrong?
  11. #10
    Oct 2012
    50
    Re: LS7 clutch kit
    A proper break in is 500 miles of normal, city-like driving. No racing, no launches, no tom-foolery. You have to get plenty of heat cycles into the friction material. Otherwise you'll glaze the clutch and it won't grab well anymore.
    PISNUOFF likes this.
  12. #11
    PISNUOFF Guest
    Re: LS7 clutch kit
    ^^^Not overheating and many heat cycles are the key. For the reasons above plus the pressure plate fingers need to be heat cycled. I didn't do that with one (straight to the highway for a road trip) and it lasted three months.
  13. #12
    1yakini's Avatar
    1yakini is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Nov 2012
    Hampton Roads, Va
    36
    64
    Re: LS7 clutch kit
    Quote Originally Posted by PISNUOFF View Post
    You took the road trip and as a result the clutch only lasted three months? I understand it needs heat cycles but a road trip where its fully engaged for long periods of time hurt it? Im asking because you do break everything at some point.. thought maybe the clutch didnt last your turture testing
  14. #13
    PISNUOFF Guest
    Re: LS7 clutch kit
    Well, I replace it with a new LS7 disc and pressure plate assembly and broke it in the same way (minus the 1100 mile road trip) and it lasted about a year before I replaced it along with a motor swap. I installed it in a buddy's Trans Am and it's still going strong.
  15. #14
    1yakini's Avatar
    Nov 2012
    Hampton Roads, Va
    36
    64
    Re: LS7 clutch kit
    Thats crazy, I never would have thought that would happen. I had planned to get mine back today and drive the 500 mile round trip to W Va this weekend. Now I'm glad that it wont be ready in time and I will driving the rental car. I would hate to go through all of this and lose the clutch again so fast.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
