Results 1 to 12 of 12
Thread: Any interest in aluminum shifter bushings (in lieu of the "Home Depot mod")?
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,446
    Question Any interest in aluminum shifter bushings (in lieu of the "Home Depot mod")?
    My car's at a shop now getting a new slave cylinder, and while the transmission is out I snagged the shifter mechanism off of it to do the "Home Depot mod" with the plastic bushings. A couple days later in a thread on corner-carvers.com I saw pics of a GT500's shifter mechanism with aluminum bushings installed. I'm not sure non-members can see the pics on cc.com, so here's how they look:
    (That's actually a Boss 302S transmission in that last pic, but you can see it appears to use the same type of pin with the locking clip on it to attach the forward end of the shifter arms to the transmission.)
    I PM'd the guy who makes the bushings and he said the measurements don't quite match up. However, if there's enough interest, he said he could do 10 sets or so for the CTS-V. The GT500 bushings go for ~$60, so that's what we'd be looking at.
    My guess is most folks will be happy sticking with the "Home Depot mod", but I figured I would post up and see if anyone was interested.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Re: Any interest in aluminum shifter bushings (in lieu of the "Home Depot mod")?
    I think we got lucky with the Home Depot stuff but just saying that out loud makes me cringe...
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    I'd be in Pat...
  5. #4
    Mar 2011
    2,045
    Frankly, I don't think you're going to beat the Home Depot bushings. They're 48 cents. And they're ABS plastic. There's nothing left to gain there, except NVH. However, if there's a chance he'll make a center shifter linkage arm with a better coupling to the transmission that doesn't require that stupid pin, I'm all ears.
  6. #5
    Naf's Avatar
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    I can mimic those, but like they said abs plastic wins hands down...Price and ease of replacement are better
  7. #6
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    I'd be in for a set.
  8. #7
    PISNUOFF Guest
    If you give me the inside diameter of the linkage arms, I'll make you some. I think that's the only dimension I didn't measure the last time I had mine out. I have the stock rubber bushings but I don't trust that dimension. I'll make you some way cheaper than $60.
  9. #8
    Mar 2011
    2,045
    Quote Originally Posted by PISNUOFF View Post
    I took some measurements earlier. Sadly, I didn't get the inside of the cup, but I got the outside of the OEM bushings. Therefore (as you previously said), I would take these with a grain of salt. As I recall, the OEM bushings are lightly snug until the metal core goes in. Then they fit pretty tight. I also found that the Home Depot bushings varied by a fraction of a millimeter, so I ended up throwing throwing one or two away before settling on the ones that I installed.
    http://www.cadillacforums.com/forums...surements.html
    I had to lightly tap the Home Depot bushings into their mounting ears on the T-56 with the aid of a rubber mallet. The T-56 mounting ears are probably 0.1mm smaller than the installed Home Depot bushings.
  10. #9
    PISNUOFF Guest
    Unfortunately I have all those in the pics above. I need the inner diameter of the arms. I suppose I could go to Home Depot and measure one of them.
  11. #10
    philistine's Avatar
    Sep 2011
    821
    Would brass be more appropriate than aluminum for this application? I'm thinking of galvanic corrosion (carbon steel + aluminum = no thanks) - I don't know what the arms are made of but just guessing.
  12. #11
    voodoochikin04 is offline Banned
    Automobile(s): 2003 cts, 2004 Cts-v
    Nov 2012
    Norfolk, NE (eastern Nebraska)
    31
    316
    why not delrin? perfect for bushings, cheap as hell....
  13. #12
    AAIIIC's Avatar
    Aug 2007
    6,446
    Quote Originally Posted by FuzzyLogic View Post
    And longevity, perhaps. That's the only reason I would consider going this route - I don't know how long anyone has had the Home Depot bushings in there.
    One that could be turned from aluminum on a lathe?
    Quote Originally Posted by Naf View Post
    There shouldn't be any need for replacement with aluminum, so I would hope that would be a moot point.
    The OD of the grey plastic box adapters is ~21.4mm with old school vernier calipers (none of this fancy digital stuff ). In my experience they slipped into the shifter arms pretty easily (no interference at all, really), so the ID of the shifter arms is probably in the 21.5 - 21.75mm range (just guesstimating).
  • You may not post replies
