Issues installting brass T56 isolator cup bushing on trans shift selector
Results 1 to 11 of 11
2004-2007 Cadillac CTS-V Performance Mods Discussion, Issues installting brass T56 isolator cup bushing on trans shift selector in Cadillac CTS-V Series Forum - 2004 - 2007; Sunday night car emergency... Mechanic has the car on a lift and the trans out and can't get this bushing ...
    fweasel's Avatar
    fweasel is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Aug 2013
    Chicago
    256
    Sunday night car emergency... Mechanic has the car on a lift and the trans out and can't get this bushing to fit. He said it fits into the pocket in the trans itself, but doesn't appear to fit over the ball end of the shift selector itself. The original B&M shifter thread on LS1 mentioned a few taps from a hammer. Anyone else have experience installing this bushing? bronze_shifter_bushing.jpg
    jclayc's Avatar
    jclayc is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Sep 2008
    SC
    43
    418
    Re: Issues installting brass T56 isolator cup bushing on trans shift selector
    Take a dremel and shave off some of the rim
    fweasel's Avatar
    Aug 2013
    Chicago
    256
    The cup fits into the trans, which modifying the rim is supposed to help. Our issue is the cup fitting over the ball end of the shift selector itself
    jclayc's Avatar
    Sep 2008
    SC
    43
    418
    Oh my bad - the ball of my uuc shifter fit inside of the cup for me. I recall seeing late in one of those long shifter threads that others had the same issue with the cup and they got it to fit with a little grease and tapping - http://ls1tech.com/forums/cadillac-c...m-shifter.html
    fweasel's Avatar
    Aug 2013
    Chicago
    256
    Just heard back, problem solved. Needed more hammer.
    PISNUOFF Guest
    Quote Originally Posted by jclayc View Post
    The shifter itself does not attach to that piece. That goes inside the trans.
    jclayc's Avatar
    Sep 2008
    SC
    43
    418
    Bah, I just need to shut the hell up
    fweasel's Avatar
    Aug 2013
    Chicago
    256
    Just picked the car up and drove home. Shifter went from a sloppy mess to a stiff mess shifter won't return to neutral position on its own, left/right. Hoping the cup tolerance is just overly tight and that with some wear, things will loosen up.
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,362
    Sounds like the bolt at the end of the shift lever is to tight.
    fweasel's Avatar
    Aug 2013
    Chicago
    256
    Quote Originally Posted by odla View Post
    just came back in from the garage testing that theory. Even with the bolt removed, side to side movement was still too heavy. I'm really beginning to dislike his car. One step forwards, two steps back.
    ctsv154's Avatar
    ctsv154 is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V with a little hp persuasion device
    Oct 2007
    32
    3,824
    Bringing this back from the dead. Did this ever wear in? I bought a bronze shift cup and have the same issue. I had a shop install it when the rebuilt the trans. You would think they would have been like hey this isn't right but whatever. I just bought another one from Tick so hopefully it will fit the shift ball better. Problem now is it seems they hammered it in too. I'm going to try and thread a tap in it and knock it out with a slide hammer
  14. Remove Advertisements
