Monster Stage 2 clutch with 18lb flywheel installed, now very difficult to shift... - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Like Tree1Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Monster Stage 2 clutch with 18lb flywheel installed, now very difficult to shift... in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by VincentT There were a few others. The clutch pedal was extremely hard, hard enough that when sitting ...
  1. #16
    tim0shel's Avatar
    tim0shel is offline Cadillac Owners Member
    Automobile(s): NONE yet
    Sep 2013
    Greenville S.C.
    38
    47
    Re: Monster Stage 2 clutch with 18lb flywheel installed, now very difficult to shift.
    Quote Originally Posted by VincentT View Post
    There were a few others. The clutch pedal was extremely hard, hard enough that when sitting at a short red light I would put it in neutral instead of holding the clutch in. It would also grind into 2nd if I was shifting with any spirit. There was also a large amount of chatter, but I chalk that up to how worn the friction disc was.
    That sounds little like my issue and doesn't seem that the clutch is disengaging all the way cause when on flat level ground with pedal all the way going into first the car will start to roll little or pull. When in gear letting out it is grabbing instant. I hadn't noticed any chatter really. Of course reverse is almost impossible that's little to do with the sloppy shifter. Still trying to figure out all needed parts for that to be fixed up.
  2. #17
    04cts v is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Jan 2013
    41
    Quote Originally Posted by DDS rollin a CTS
    I'll forward this on to the shop and see what they have to say.
    Any update to what fixed the problem?
  3. #18
    DDS rollin a CTS's Avatar
    DDS rollin a CTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V, 2001 Honda Shadow Sabre
    Sep 2005
    Lafayette, IN
    35
    1,641
    Quote Originally Posted by 04cts v View Post
    Never did reach a complete solution. Installed a new master cylinder and Revshift trans mount insert, and Monster ended up fabricating a custom shim but it still drags ever so slightly and is still difficult to get into 1st and reverse. At one point we even sent the whole clutch back to Monster so they could take measurements and make sure everything was true. Finally I got tired of the rising bill from taking the clutch in and out so many times and resigned myself to living with it. If this clutch wears out while I still have the car I'll probably switch to an LS7 setup.
  5. #19
    Bueller's Avatar
    Bueller is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    Nov 2007
    Florida
    572
    LS7 ftw
  6. Remove Advertisements
