Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 77
Thread: Back up on blocks for winter work
  1. #46
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    Re: Back up on blocks for winter work
    Wire showed up, here are pics of the cables I fabled that will go from the alternator to the battery.
    Also, the isolation mounts for the X pipe were separated so I had to replace those also.
    Found a beefier one on Ebay.
    Tag is specs on the new alternator.
  2. #47
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    That shrink tubing looks like its the kind that doesn't have the sealant inside that makes it water tight. What kind did you use? btw what's an x-pipe? exhaust?
  3. #48
    Nov 2004
    8,788
    The shrink is non sealant type I got a while ago.
    X pipe is the exhaust.
    I use that instead of a resonator.
  4. #49
    rjoffe is online now Cadillac Owners Connoisseur
    Jul 2005
    1,913
    <threadjack>
    Heavy, saw this, and for some reason instantly thought of you:
    http://www.kickstarter.com/projects/920064946/oscilloscope-watch
    </threadjack>
  5. #50
    Nov 2004
    8,788
    You would be surprised at the stuff I was involved with back in the early 90's.
  6. #51
    Jul 2005
    1,913
    That was about the last time I needed a scope
  7. #52
    Nov 2004
    8,788
    Here are pics of the redundant alternator cables with heat wrap & installed.
    I added a "star" washer to the bolt for ground (used alternator mounting bolt).
  8. #53
    philistine's Avatar
    Sep 2011
    821
    What size/grade wire did you end up going with? link plz
  9. #54
    Nov 2004
    8,788
    Quote Originally Posted by philistine View Post
    Refer to post #38.
  10. #55
    Nov 2004
    8,788
    Here are pics of the headers reinstalled showing off the hot jet coat and the wires run to the battery.
    Those are a bitch to work with.
  11. #56
    Nov 2004
    8,788
    Just an update FWIW.
    IT IS TOO GD COLD!
    I will not work or lay on my back on a creeper in a cold garage.
    Forget it. I will wait till it warms up a little.
    I have heaters, but I just am not gonna go throughout the trouble.
    I have beer also. That I will go through the trouble for.
  12. #57
    Nov 2004
    8,788
    PROGRESS!
    Exhaust is reinstalled, coil pacs and wiring installed.
    Eat your hearts out, it is 80 deg F here so the garage is perfect to work in.
  13. #58
    Jul 2005
    1,913
    Urg, this is what I have:
  14. #59
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    I was just changing my oil in 15 degree weather. Grow a pair!
  15. #60
    Jul 2005
    1,913
    Jim,
    Wait till we're old like Heavy. We may want to wait for that nice warm garage
    Nothing against old age Heavy, we're all on the way there
    Ron
  • You may not post replies
