Is there such a thing? :hmm: I was under the car today and had a little leakage on the exhaust pipe on the drivers side. :rant2: New Rear installed Friday, 550 miles on it. Slight whine under acceleration from 60-80. Could the dealer of over filled it and and some came out from this air vent. I never heard of air vents in the rearend, my rear end has a vent, that's how I fart! :histeric:
Seriously, Can't dirt get in there?
Stealth, Ctsv05, Wild, One of you guys know !
Most rearends have some kind of vent. It's very possible they over filled. Don't think it will hurt anything. Only problem you could run end to is if the rearend was submerged for a length of time under water. Had that happen before on another vehicle.
Change the fluid, then you'll also know its is good. Besides you'll get all of the break-in crap out of there. I'm putting redline in the rear and the tranny when it comes in. My rear end was replaced on Friday also.
I see a little overflow on the diff. casing after a track event. Most because of either the expansion of the fluid or lateral g's. But never from cruizing on the street.
Could be from the track, Pulled 1.2 on the G meter at Limerock this weekend. Maybe that's it
Dave's V, I think the Lucas might be a little thicker. I had Redline in the last rear and it made no difference! The whine was still there and got louder the hotter it got. New rear at 3K.
Reason I ask is on the last diff, after they swapped fluid, it started spewing out on the B&B exhaust. I thought initially the exhaust could be superheating the diff (even though Billy showed us that the exhaust was running cooler than stock in that area) but later learned the dealer confessed to "...possibly overfilling it...".
Just curious if you thought your exhaust could be contributing (B&B is not causing this on my current diff)...
I had a damp spot on my garage floor where the rear parks above it. When I took it to the dealer, they said that it was just the over flow - it had expanded during driving due to heating, therefore causing over flow.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
