CTS-V Mod Hell - Fall 2013
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Like Tree3Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, CTS-V Mod Hell - Fall 2013 in Cadillac CTS-V Series Forum - 2004 - 2007; Looks like I won't be watching the Bears game this weekend. Things to note: The reason why I purchased new ...
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Things to note:
    • The reason why I purchased new rear calipers is because I scraped their finish, compressing the pads over and over again. After much searching, I finally found a caliper spreader that a) can handle 6-piston calipers, b) isn't a pain in the ass to use and c) won't damage my pads or my calipers.
      MAMotorworks makes this beefy thing--the pictures don't do it justice. Not only is it a lot bigger than it looks in the sample pictures, it turns out to be finely made piece of tool steel that includes machine oil for the extra heavy-duty threads. For $27, it's hard to beat. And it has 1/2" drive and 21mm hex drive on the end!
    • Whiteline KLL135 (1-3/8" or 35mm) and KLL127 (1" or 25-27mm) lateral locks are a necessity when running the Addco sway bars to keep them from sliding sideways, since they don't feature a welded-on lateral lock like the Hotchkis sway bars do.
    • After noticing some wear on my $20 1-3/8" (35mm) Energy Suspension 9-5168R sway bar brackets, I finally said "screw it" and bought those machined 7075 aluminum Hotchkis 23391375 sway bar brackets that I've been eyeing for a long time. These things are seriously strong--I think they were originally designed for 4x4 race applications. Expensive as f---, though.
    • Edelbrock/Russell 639560 speed bleeders are indispensable aids when bleeding your brakes. 99% of the mess and the mistakes you make when bleeding your brakes by yourself can be attributed to using the stock nipples. I liked them enough to buy a second, full set for my V2 brakes.
    • The other source of error when bleeding your brakes is having air in the master cylinder. Bench bleeding is a pain in the butt, and honestly, I recommend avoiding it because you can do it much, much better, faster, and cleaner with the Napa on-car bench bleeding kit.
    • The last part of the equation, this time for the remote clutch line, is the Earls' 280040 solo bleeder. I haven't installed these yet (fitment is a real concern--they sell parts for all kinds of 10mm remote line threads), but I'll report back with impressions when I do.
    • A Deka ETX20L battery weighs 15.5 lbs, versus the 37.4 pound Everstart Maxx 78N battery. I'm going to try to see if I can make this battery last the winter, and if so, I'll never run a standard flooded cell battery again. By the way, the battery is TINY--about the size of a box that can hold 4 tennis balls. But since that small battery weighs 15 lbs, it subjectively feels like it's the heaviest thing ever.
    • Although the Deka ETX20L isn't particularly expensive, once you add the cost of a NCI Deka battery bracket (originally intended for the Lotus Exige), and RLS cutoff switch, and insulating kit, it's a $200 project. Never having to remove the battery again to pull the passenger side spark plug / remove the headers: priceless.
    The V2 calipers are gorgeous. I'm still missing quite a few parts--need to call Racing Brake, Coleman, and Luke @ Lindsay to decide on rotors (either 355x32mm @ 19 lbs or 370x34mm @ 23.5 lbs). I also plan on replacing my Goodridge stainless steel brake lines with either Girodisc or RacingBrake's product, since I question whether the Goodridge kit seals correctly. The plan also calls for:
    You may recall my earlier "Mod Hell Weekend" thread where I fell off the map. Well, it really did turn into a mod hell scenario--a few things went wrong, a few plans changed, and I had to work overtime to get the car operational.
    By the way, HUGE shout out to MIGHTYMOUSE, who literally ran all over the place, fabricating an extra set of 3/16" wheel spacers for me when I found that my ARP wheel studs were too long for my McGard spline drives. I blew through the ends of two of them before I stopped trying to seat the ARP wheel studs fully, and had to gingerly drive the car around for a couple of days while I waited for replacements to arrive. :usa:
    Ultimately, I wound up running all four 3/16" wheel spacers on my front wheels, which gives me 9.525mm of extra room on the inside. The car looks great now (remind me to take pictures)--that typical CTS-V "underbite" is finally gone. Theoretically, now that the track width of my car is greater, the front-end roll resistance should be increased, although I can't feel anything because I've changed so many variables recently.
    Here's a comparison on the three sets of bolts I used:
    Raybestos 2093B (1.575"), ARP 100-7709 (1.850"), and ARP 100-7708 (2.500")
    Originally, I was running Ray 2093B studs everywhere. These things cost about $1.50 apiece, and are a significant upgrade over the stock studs. I've never broken one, despite having snapped 11 of my stock lugs with a wrench. Interestingly, they also have more threaded length than the supposedly "longer" ARP 100-7709 studs. Check it out, above! Although the stud *is* longer, the threads stop short, like the OEM stud.
    Raybestos 2093B thread protrusion with one 3/16" (4.7625mm) spacer. One finger is approximately the same thickness as the flange on the Forgestar F14 wheel, so you can see that you're in real danger of losing a wheel if you don't a) remove the spacer or b) install longer studs.
    Now, if you're running Forgestar F14 wheels and want spacers, you need to consider running ARP 100-7708 studs in the front, because you'll only get about 3-4 threads engaged on the Raybestos 2093B lugs (at best). Don't even think about the ARP 100-7709 studs--the front wheels won't even stay on. However, if you choose to upgrade to ARP 100-7708 studs, you must have at least an 8mm thick spacer on the wheel to avoid blowing out the end of the McGard Spline Drives.
    McGard Spline Drive against ARP 100-7708 wheel stud. I'm holding the Spline Drive to show you approximately how long the spline drive is compared to the stud. The Spline Drive is NOT resting on the wheel. In this configuration, with Forgestar F14s, the end of the wheel stud will blow through the end of the Spline Drive. It's hard because the rotor is not fully seated on the hub in this picture.
    Thread protrusion with one 3/16" spacer, for comparison purposes to the Raybestos 2093B picture only. DO NOT try to run your car this way (as described above), unless you have open-ended lug nuts.
    As you can see (above), the ARP 100-7708 is dramatically longer, and engages all of the threads inside the spline drive. As you may or may not know, the ARP 100-7708 is also slightly thicker than the ARP 100-7709 and Raybestos 2093B--both of which, in turn, are slightly thicker than the stock wheel studs. You have concerns about your rotors vibrating on your hub, ARP 100-7708 studs will solve that problem. They're thick enough to prevent the rotor from having significant play.
    Follow up on the other 08/10/2013 "Mod Hell" stuff:
    • LED tail lights got installed, along with the 50W 3157 LED turn signals and 5630 sidemarkers. Requires load resistors. Amazon sells good, 6 ohm, 1% stuff.
      Anyway, the tail lights are awesome, but I haven't had time to take pictures yet. Similar to the aftermarket CCFL headlights, you have to futz around with the tail light fitment (i.e.: press them hard into place while simultaneously screwing on the bolts) to get them to follow the lines of the car perfectly--and on one housing, I had to take an X-acto knife to the edge of the plastic trim to shave off a couple of millimeters of excess molding.
    • The blind hole puller that I found at Harbor Freight fits our pilot bearing perfectly (you need to use the smallest attachment). Sadly, this is after I pulled out the transmission and found that both AutoZone and Advance Auto Parts' tools were too big to fit through the pilot bearing hole. You can save about $20 on eBay by buying it without the case (linkage).
    • The Toyota Supra end links are an improvement over the Miata end links--they're stronger, and much closer in quality to the PowerGrid end links. I'm now running them on all four corners. The pictures on that eBay auction are not accurate. Here's what you'll get (notice how much beefier the ball joints are):
    My initial cut on the front end links is pictured above. I need to cut a few more millimeters off to achieve the correct sway bar curve and still maintain clearance on the KW Variant 3 / Addco sway bar combination. The nice thing is that I don't have to worry about the Corvette Z06 end links scraping on the side of the KW V3 shock body anymore. As you can see, I've got good clearance, and the end link is no longer crossing diagonally under the sway bar.
    • I replaced the fender liners with new ones. The 3M Rubberized spray worked well (one full can per fender liner), and I was very pleased with the way they sounded when I rapped my knuckles on them. I recommend putting the coating on the inside of the fender liner, as opposed to the outside, for aesthetic purposes. While the rubberized coating looks great when it's brand new, it's hard to clean if it gets dirty because a) it's porous and b) it's not as durable as plastic.
    Mar 2011
    2,045
    Re: CTS-V Mod Hell - Fall 2013
    • I found a replacement for my failing PA15-VETTE cord. Apparently, there are two cables sold by USA Spec: one that charges, and one that doesn't. If you need a new cord, get the CB-PA105. Costs $35--linkage here.
    • I finally got the car re-aligned, following my installation of the Revshift control arm bushings and subframe bushings. It was WAY out of alignment (no surprise there). I actually felt bad for the alignment guy, despite getting my hands on a Kent Moore J-45845 camber/caster alignment tool. So although I wanted 2.0 degrees camber on the front end, I didn't push it. Once I do a few more mods, I'll head back in and get the front camber increased and equalized.
    The big change, this go-around, was almost 0.1 degree of positive front toe, and the reduction of rear toe from 0.3 degrees to 0.15. I'm absolutely loving the front toe--the car finally feels nimble. It doesn't wander on the highway or feel twitchy under any circumstances. The rear toe adjustment took more time to get used to--I was accustomed to being able to hit the gas with relative certainty that nothing I could do would spin the car out. Now, there's less stability margin. Now that I've had a couple of weeks to get used to it, I wouldn't go back. And my tires are probably thanking me--this should eliminate most of the wear on their insides.
    mackey likes this.
    69stangscj's Avatar
    69stangscj is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V sedan, 69 Mustang Mach I
    Jul 2013
    Dayton Ohio
    331
    Can you use that spreader on stock calipers without removing them?
    barrok69's Avatar
    barrok69 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Maggied
    Mar 2012
    Michigan
    271
    FYI this Fixed Caliper spreader will change your life forever.
    SevillianSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V
    Aug 2005
    Northern IN
    1,006
    Nice work Fuzzy.
    what is the rubberized coating on the fender liners for ? So they are more rigid or road noise ?
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,365
    Quote Originally Posted by barrok69 View Post
    Can we get a link?
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    That's a neat tool but to be honest I always compressed them using the worn brake pad, c-clamp, and a block of wood.
    rand49er and robojesus like this.
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    29
    979
    The v2 pistons are small enough that you can compress them by hand. Makes it easy to swap pads. Two guide pins and one center support bolt.
    barrok69's Avatar
    Mar 2012
    Michigan
    271
    Quote Originally Posted by odla View Post
    Can we get a link?
    http://www.ebay.com/itm/Lang-Tools-4...-/231041123428
    The one I originally linked with picture is made by Blue Point. This one above in the URL is "Lang". Looks identical just different color handle, made in USA.
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    Dang, Fuzzy ... probably took you three days to write that first post. Amazing amount of research, and the pics are super.
    Mar 2011
    2,045
    By the way, according to AAIIIC, you need to plan on carefully shortening the GM V2 M14-2.0x50mm bolts, or purchase M14-2.0x45mm Grade 10.9 bolts.
    I checked Fastenal's prices, and they're terrible--$30 for 4 bolts including economy shipping. Screw that. Instead, I purchased 25 black-oxide coated Grade 10.9 bolts for $40 from a local machine shop. I'm only interested in keeping eight bolts (four and four spares). If two other people want a set of bolts, I'll ship you four for $10 or eight for $15.
    Quote Originally Posted by SevillianSTS View Post
    Nice work Fuzzy.
    The rubberized coating isn't rigid--it's for road noise reduction. Specifically, it's intended to help prevent the fender liner from vibrating or rattling.
    philistine's Avatar
    Sep 2011
    821
    Quote Originally Posted by FuzzyLogic View Post
    Why did you snap so many wheel studs?
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    This works pretty good as well for swapping pads...
  16. #14
    Mar 2011
    2,045
    Quote Originally Posted by philistine View Post
    There's no denying that I torque wheel lugs beyond GM's recommendation, but I believe that they sheared due to a combination of that and the number of tighten/loosen cycles I put on them. Taking your wheels off the car and putting them back on once or twice per week for three years is like bending a paper clip back and forth...back and forth... metal fatigue eventually rears its ugly head.
  17. #15
    69stangscj's Avatar
    Jul 2013
    Dayton Ohio
    331
    Quote Originally Posted by Junior1 View Post
    Nice! Link?
  18. Remove Advertisements
