Page 1 of 47 1234567891011 ... LastLast
Results 1 to 15 of 705
Thread: pig in slop
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    pig in slop
    Weekend just isn't long enough...
    brngrhd is offline Cadillac Owners Member
    Automobile(s): 2004 cts-v
    Apr 2013
    37
    93
    Re: pig in slop
    Lucky!!!! IIRC you're going with a McLeod right? What flywheel and throw out/slave?
    Heavybody is offline Cadillac Owners Fanatic
    Automobile(s): 04 CTS-V and 94 SLS
    Oct 2005
    NH
    149
    My question is what parts are still in your car??
    And I hope you don't need it for Monday!
  5. #4
    barrok69's Avatar
    barrok69 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Maggied
    Mar 2012
    Michigan
    271
    Re: pig in slop
    That diff looks massive compared to the size of the car. Nice optical illusion
    Looks like you have a bunch of work to do !
  6. #5
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    Went with the Katech LS9x clutch, 12lb aluminum flywheel, stock slave. I have the exhaust, entire drivetrain and cradle removed. Got the clutch and bellhousing bolted back up. I put some shifter bandaids in there from some bushings I got from PISNUOFF along with the Home Depot bushings - it's really tight now!
    I'm installing the CS 8.8 complete turnkey kit. Then gonna drop the gas tank and interrogate the fuel system with a DW300 pump, Racetronix hotwire, trapdoor, and new a new bulkhead connector for the fuel bucket etc.
    I got some DEI tunnel shielding to wrap the trans tunnel - it's sticky back but very stiff stuff so gonna form it and bolt it in. There are a few other odds/ends to get off my work desk and install - spherical RSM, brakes etc.
    I'm waiting for other parts to come in...new Revshift MMs since my headers torched the old ones (weren't shielded), new Tick Bleeder, and hopefully the CS trailing arms come in soon.
    I work in 2 modes...fast get-er-done mode, and slow beer drinking having fun wrenching in the garage with loud music mode. It'll be down for at least another week.
  7. #6
    Mar 2011
    2,045
    Re: pig in slop
    What kind of bulkhead connector and trapdoor?
  8. #7
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    Quote Originally Posted by FuzzyLogic View Post
    I purchased the following from Racetronix for the wiring:
    BCWS-001 - bulkhead connector wire kit
    BCA-4W - spare 4-way connector in case I mess up the connector
    RCS-001 - connector for intank pump
    WR-TEW-10-0-25 - 10awg black wire
    WR-TEW-10-2-25 - 10awg red wire
    Trapdoor hardware:
    gasket - FDA SILICONE RUBBER SHEET 1/16" THICK 12" X 12" SQUARE FOOD GRADE HIGH TEMP
    trap door cover - 12 ga 12" x 18" 304 2B Finish Stainless Steel Sheet
    fastening nuts - NEW PEM CLSS-032-2 SELF CLINCHING NUT , 10-32 THREAD ( 75 PC. LOT )
    screws - Stainless Steel Phillips Pan Head Machine Screw 10/32 x 3/8 Qty-25
    I also got a 16 gauge air nibbler.
    Basically, I'm going to go directly from the pump to the bulkhead connector and directly to the hotwire kit. I'll have to modify the current hotwire kit for the new bulkhead connection. After I get all that done, with any luck I'll fab up a trap door. It will be sealed and easy to access. The new bulkhead connector enables the addition of another fuel pump if/when the time comes. I will also eliminate the stock thin wire in the process.
    Edit: Hey Fuzzy, that writeup when you installed the Revshift cradle bushings was very handy when I dropped my cradle - thanks!
  9. #8
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,461
    Re: pig in slop
    Well, at least if you don't get the V done this weekend you can just drive the police cruiser. It's always good to have a 2nd car when you've got big projects going on!
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  10. #9
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    Here's some car porn:
  11. #10
    Mar 2011
    2,045
    Re: pig in slop
    Quote Originally Posted by philistine View Post
    Trapdoor hardware:
    Glad it helped! I'll probably reference it when I do a front Revshift control arm bushing thread. They've been installed for about two weeks now--I was waiting for Revshift to announce them before I posted. By the way, make sure you lubricated the metal sleeve on the upper control arm bushings. If you don't, they'll start squeaking. If you can move the control arms with your hands and don't hear any sound, then you should be good.
    I thought for a minute there that you were going to buy a sealed, stainless steel trap door for the back seat of the car. I'm in the market for one, should you locate a good one. I'm definitely considering purchasing those connectors for the tank. Right now, the debate in my head is whether to go with a DW300 or a Walbro 450 pump. I'm concerned about them overheating in the stock tank, though.
    Is that an iron or aluminum 8.8? Which differential option did you pick? Have you considered running a spherical billet bushing in the front?
  12. #11
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    Those front arms look good! You'll have to post your impressions on them soon.
    I have the Iron 8.8" Truetrac, 3:73 gears. I cleaned and generously lubricated all the bushings - good call though, I had it loosely bolted then tore it apart and lubed it real good.
    Regarding the fuel mod - I chose the DW300 for the low ampere load. I'm having all sorts of issues with the 340lph drop in tank in my other car. I originally ordered a bunch of stuff to fix that problem with Racetronix. The wiring is a little more robust on the s2k and that pump is causing all sorts of problems and will absolutely melt 18awg when wired to a relay from the battery. I don't want to repeat that issue with the V.
    The limiting factor going with a larger pump is the wiring you have going to it. A Walbro 255 and DW300 is very safe. Once you get past the wiring then it's the limitations of the bucket. A much larger pump is more likely to overheat and cavitate because it is beyond the design of the OEM bucket. That is where you have to run a return line. Just a FYI...the stock bulkhead connector is good for 13-13.5amps and it's a real POS.
    What is this spherical bushing you speak of?
  13. #12
    Mar 2011
    2,045
    Re: pig in slop
    Correction: none of the products I was referring to fit our cars, but I'll keep looking. Maybe something like this solid aluminum bushing:
    http://www.vintageperformancemotorca...rentialkit.htm
  14. #13
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    Hmm, I see what you are talking about. The CS 8.8 kit differentials eliminate the famous front bushing fiasco. It is all metal contact. I must say that if there is any incredulity about the fitment of the kit...rest assured, Max did his homework - fits perfect! The measurements to get that bracket dead-nuts must have been a pain.
    The fuel tank drops right down once you have the cradle out.
    Just unbolt the 2 strap bolts and done - it's just wire management after that. I put my raceramp wheel cribs under there to hold it so I can work on it. I should mention that I was so confident that I could bang that ring off to access the fuel bucket - fail! That phuckin sob pos mfer wouldn't give. I gotta check around for a rental but I did order one from Amazon. Doesn't really interfere with the other crap I gotta do but damn...I really got personal with that locking ring - had to walk away.
  15. #14
    Mar 2011
    2,045
    Re: pig in slop
    Are you sure about that metal-to-metal contact?
    http://ls1tech.com/forums/cadillac-c...ings-diff.html
  16. #15
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    Check it out...all metal contact and tight fit.
  • You may not post replies
