pig in slop - Page 46
Page 46 of 47 FirstFirst ... 36 37 38 39 40 41 42 43 44 45 46 47 LastLast
Results 676 to 690 of 705
Like Tree66Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, pig in slop in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by FuzzyLogic You should note that I'm not 100% certain that the magnets will work yet. I have ...
  1. #676
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Re: pig in slop
    Quote Originally Posted by FuzzyLogic View Post
    You should note that I'm not 100% certain that the magnets will work yet. I have two of them here for testing, and frankly, there's not a whole lot of pull force because of the spacing provided by the rubber sheet. I may have to substitute stronger magnets, or take more drastic measures (e.g. removing the magnetic sheets and replacing them with a 1/8" sheet of steel). Stay tuned.
    You might have a cover but it won't seal. The surface area is far from flat after you cut an access door. I ended up sealing mine with Valco Cincinnati silicone gasket maker.
    Have some of that stuff handy if it doesn't work out the way you intended.
  2. #677
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
  3. #678
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    Is there any particular reason why you chose Valco over Permatex Ultra Black?
    It will seal anything and bulletproof strong. If you are looking for alternates I use Permatex 81878 Silicone Gasket Maker as well and I think just about any exhaust shop uses this too.
  4. #679
    Mar 2011
    2,045
  5. #680
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    Did you apply a thin layer of this Valco silicon gasket stuff to the lid before setting it down, or did you use it to build up a level foundation? Were the screws in your door necessary after the material dried? When it dries, does it set hard or soft?
    The PEM nuts didn't turn out as good as I hoped. If you use the gasket maker, you won't need screws. The surface wasn't level enough for a thin layer so I laid it on thick. I used a couple screws to tighten it down. I really just wanted it completely sealed and the original gasket left too many gaps. It's not low modulus - dries to a hard rubber. You would have to cut it out with a razor to remove and scrape both sides to reinstall like any other gasket.
    A fab shop could have made a nice flange for a perfect showcase fit but I settled for the gasket maker stuff - it's under the seat anyways, well supported and out of sight.
  6. #681
    Mar 2011
    2,045
  7. #682
    Mar 2011
    2,045
  8. #683
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    Re: pig in slop
    Nice work...
    Which way did you decide to go on the alternator??
    Thanks
  9. #684
    Feb 2009
    Greenville sc
    45
    992
    Re: pig in slop
    I see in a few other threads you're up and running. Did you shelve the spindle swap?
  10. #685
    Mar 2011
    2,045
  11. #686
    Mar 2011
    2,045
  12. #687
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    What a long thread! I'm glad to have shared all this stuff in CF. It was the first forum I joined when I purchased my CTS-V. A lot of guys moved to facebook "CTS-V VS The World" where worlds collide with V1 and V2 owners. I believe the heart of the community is there. As much as I enjoy social content there needs to be a place to explore the platform freely with no restrictions, a place well preserved, modern and maintained by V enthusiasts - specific to the V community.
    This thread started here on CF and evolved to becoming a 'sticky' on LS1tech and the work continues on VSeriesForums.
  13. #688
    H-town_V's Avatar
    H-town_V is offline Cadillac Owners Fanatic
    Automobile(s): 05 cts-v
    Feb 2013
    341
    Quote Originally Posted by philistine
    What a long thread! I'm glad to have shared all this stuff in CF. It was the first forum I joined when I purchased my CTS-V. A lot of guys moved to facebook "CTS-V VS The World" where worlds collide with V1 and V2 owners. I believe the heart of the community is there. As much as I enjoy social content there needs to be a place to explore the platform freely with no restrictions, a place well preserved, modern and maintained by V enthusiasts - specific to the V community. This thread started here on CF and evolved to becoming a 'sticky' on LS1tech and the work continues on VSeriesForums.
    All real V enthusiast enjoyed this thread... I'll admit a lot of the info was over my head but I loved reading the progress u guys were making. F$&@ the cf mods for taking down half the info on this thread.
  14. #689
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,148
    Re: pig in slop
    Quote Originally Posted by H-town_V View Post
    If you're referring to Fuzzy's deleted posts and pictures, he did that himself. Looking at the moderator log on this thread there has been a grand total of one moderator action, and that was me moving the thread to the Performance Mods forum way back when the thread started.
  15. #690
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    AAIIIC is correct. Moderators did not interfere or interrupt with any content on this particular thread. It has been clean and free flowing the entire time. I keep all my stuff on Photobucket and do no remove it so that way all the pics can be preserved even if I move to another forum or facebook. Content is content and I try to preserve the stuff in the past as well as moving on.
    This was a clean fun thread of learning so lets keep it that way. I still draw on some of the references so many contributed but evolution takes its place and the content continues on VSeriesForums.
  16. Remove Advertisements
