pig in slop - Page 2
Page 2 of 47 FirstFirst 123456789101112 ... LastLast
Results 16 to 30 of 705
Like Tree66Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, pig in slop in Cadillac CTS-V Series Forum - 2004 - 2007; Wow, that 8.8 & bracket looks great... definitely car porn Fuzzy - what size/where did you get that single bolt ...
  1. #16
    jclayc's Avatar
    jclayc is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Sep 2008
    SC
    43
    418
    Re: pig in slop
    Fuzzy - what size/where did you get that single bolt holding your upper control arms in?
    Quote Originally Posted by FuzzyLogic View Post
    Glad it helped! I'll probably reference it when I do a front Revshift control arm bushing thread. They've been installed for about two weeks now--I was waiting for Revshift to announce them before I posted. By the way, make sure you lubricated the metal sleeve on the upper control arm bushings. If you don't, they'll start squeaking. If you can move the control arms with your hands and don't hear any sound, then you should be good.
  2. #17
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Re: pig in slop
    jclayc--those are two wrenches. See:
    If you're asking me for the part number on the bolt, I unfortunately don't know it.
    [/COLOR]
    Quote Originally Posted by philistine View Post
    Check it out...all metal contact and tight fit.
    That is awesome.
    philistine likes this.
  3. #18
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,542
    Re: pig in slop
    http://i1058.photobucket.com/albums/t404/jaysenbaker/cts-v_misc/2013-09-08101131_zps7ec621be.jpg
    http://i1058.photobucket.com/albums/...psc39d77db.jpg
    There are still bushings in there, though, as seen in your 2nd picture here:
    Here's some car porn:
    Those are the bushings that lollygagger was asking about in the thread that Fuzzy linked from ls1tech.com, and those bushings could be replaced by something like the ones he linked here:
    Correction: none of the products I was referring to fit our cars, but I'll keep looking. Maybe something like this solid aluminum bushing:
    http://www.vintageperformancemotorca...rentialkit.htm
    Assuming the front bushings are normal 8.8" IRS bushings, then aluminum bushings like this should work just fine. There are a number of companies that make them - Full Tilt Boogie Racing, Maximum Motorsports, etc.
    lollygagger8 likes this.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  5. #19
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Re: pig in slop
    Ahh, for some reason I thought it was in reference to the bushing on the old differential - the front that many have replaced. The smaller bracket on the 8.8" clearly has bushings sandwiched in there normal (perpendicular) to where the OEM was on the old differential. Other than that the only bushings left are in the cradle itself where you slide the 2 bolts through to top CS bracket.
  6. #20
    Mar 2011
    2,045
    Re: pig in slop
    Quote Originally Posted by AAIIIC View Post
    Any idea whether there's an option for the rear bushings on the 8.8 IRS?
  7. #21
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    A little progress...
    The trapdoor access has been cut. I have the gas tank lifted into position. There is enough room to remove the fuel lines and pull out the bucket. I have to fit the ring removal tool to make sure that works - waiting for that part to come in. Once fitment is confirmed, it's all monkey work fabricating the cover and I have all the parts here to complete that.
  8. #22
    Mar 2011
    2,045
    Re: pig in slop
    If you find a ring removal tool that works, let me know. I bought one that was too big and sold it back on eBay a month or two ago.
  9. #23
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    Quote Originally Posted by jclayc View Post
    ^^^This
  10. #24
    brngrhd is offline Cadillac Owners Member
    Automobile(s): 2004 cts-v
    Apr 2013
    37
    93
    Re: pig in slop
    Hammer and screwdriver works great
  11. #25
    Mar 2011
    2,045
    Re: pig in slop
    Quote Originally Posted by brngrhd View Post
    Not in my experience. You can wreck the ring, even with something fatter like a crowbar and a hammer.
  12. #26
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    Yeah I'm done with the hammer and screwdriver method - results vary and it wasn't happening for me. Regarding the pem self clinching nuts...no luck. I have a sample piece that I cut out and the metal is just too thin. I drilled and pressed them in perfect without distorting the metal...eventually driving the screw in there spins the self-clinching nut out. My test piece looks like swiss cheese. I took a thicker piece of metal and it clinches perfectly.
    I could dip them in JB weld and possibly get them to stick. The shear strength just isn't high enough with that low contact surface area.
    JB weld test piece:
    Edit: Gonna use a sheet metal punch. My standard drill bits were chewing the thin sheet metal too much. That should solve the problem.
  13. #27
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,884
    Re: pig in slop
    Put some shoes on...
    Pillow likes this.
  14. #28
    philistine's Avatar
    Sep 2011
    821
    Re: pig in slop
    I thought for a minute there that you were going to buy a sealed, stainless steel trap door for the back seat of the car. I'm in the market for one, should you locate a good one.
    Fuzzy, I don't think you are going to find a pre-fabbed stainless steel trap door. You are still going to have to cut/nibble an access area. I took measurements and made templates. The metal in there is stamped and not flat. After you cut, you have to straighten it out - ding hammer works ok. I'm going with a 1/16" high temp gasket with a 1/2" lip sealing area around the opening. Once I confirm the ring-tool fits then it's drilling holes for the self-clinching nuts (that don't self clinch I should mention).
    I'll make another template of the as-built hole opening and then trace over the stainless steel sheet I have. I'll overlap that trace by 1/2" around the periphery and cut the access door. I'll mark the location of the pem nuts with contact dye and drill the holes in the stainless steel door. What you will see in the end should be a nice piece of stainless steel with a 1/2" fillet on the corners and with screws along the edges fastening it to the frame.
    Once that is all done...sound deadening material the entire backseat area.
    Pic of simple template I made for the hole opening:
    I took some reference measurements where to place the template for tracing to make the cut-out.
  15. #29
    Mar 2011
    2,045
    Re: pig in slop
    I recommend two layers of something like b-quiet, making sure to follow the driveline into the trunk. Then you will find that one layer of Luxury Liner Pro will fit over that. I've still got my back seat out--I want to add a second layer under there, but the seat bottom won't latch with it in place. Thinking about a couple of options, including cutting a 0.25" slit in the foam seat bottom to create a void with which to insert the second layer.
  16. #30
    AAIIIC's Avatar
    Aug 2007
    6,542
    Re: pig in slop
    As installed in a Mustang, yes - those same shops that I mentioned before do all of the various bushings. But those bushings don't apply when installing the 8.8" into our cradle.
  17. Remove Advertisements
