remote clutch bleeder fail - pics!
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By PISNUOFF
2004-2007 Cadillac CTS-V Performance Mods Discussion, remote clutch bleeder fail - pics! in Cadillac CTS-V Series Forum - 2004 - 2007; I ordered a clutch bleeder from Tick Performance. It doesn't fit the stock LS6 slave. Here's a pic of the ...
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Here's a pic of the stock slave attached to the transmission.
    Installing the Tick Performance speed bleeder:
    Up
    Down
    Side
    Here's the only side that works:
    Bending it back to clear the bellhousing contact surface...not good.
    The stock bleeder tightens very nicely. The Tick Performance was a kinda loose. Here's a few shots of the end fittings.
    I purchased part# TPSBLC6
    http://www.tickperformance.com/tick-...6-04-07-cts-v/
    Just giving a head's up of what you get. So instead of fumbling around with end fittings that don't work (btw the two ends are different thread sizes and are not interchangeable) I decided to purchase the Mityvac and give it a try.
    Mityvac MV8000 Automotive Test and Bleeding Kit : Amazon.com : Automotive
    chime in if you know of something I overlooked. Again, the 45 degree end fitting and the straight are different thread sizes so no reversing them.
    Thanks!
    PISNUOFF Guest
    Re: remote clutch bleeder fail - pics!
    Most people bend that fitting more straight. Be careful. Tick would not believe me when I called them and told them it should be straight.
    lollygagger8 likes this.
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    why didnt you buy the katech remove bleeder?
    philistine's Avatar
    Sep 2011
    821
    Quote Originally Posted by PISNUOFF View Post
    I'm going to give them a call and see what they say. I'll bend it if I have to.
    Quote Originally Posted by Naf View Post
    I bought the Tick Perf. clutch bleeder long before I purchased the clutch.
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    I've got the tick bleeder as well. I think they bent it slightly and notched the bellhousing to make it work.
    philistine's Avatar
    Sep 2011
    821
    Quote Originally Posted by Junior1 View Post
    Bending the fitting or cutting a notch in the bellhousing is unacceptable. I called and I was told to send it back and to get the 2010 Camaro speedbleeder - wtf??? So I guess the scenario is...purchase 2004-2007 cts-v specific speedbleeder, find out it fits like real s**t and then send it back in to get the model car that I don't have.
    To be fair Tick Performance mentioned that they suspect not all cts-v bellhousings are the same. I took a pic of a Mallet cts-v, not sure if it has a T56 or not but the bellhousing was definitely different.
    Junior1's Avatar
    Jun 2008
    1,248
    If you look closely, I don't think mine has that much of an angle on it...
    philistine's Avatar
    Sep 2011
    821
    hmm that slave looks different...look at the spacing between the connections compared to mine. Yours looks a lot like the Mallet I posted above.
    Junior1's Avatar
    Jun 2008
    1,248
    Quote Originally Posted by philistine View Post
    My bad, I've got the LS7 slave
    I just noticed the whole setup looked different and realized that your running the stock slave
    The LS7 slave was only off by a little and needed a little reaming on the bellhousing to make the bleeder fit.
    Why not swap to the LS7 slave?
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    LAPD remote came bent like that as well. I straightened mine.
    philistine's Avatar
    Sep 2011
    821
    I'm thinking about swapping for a LS7 slave - any differences besides the obvious positions of the hydraulic fittings? I know I don't need the Katech spacer since I'm going with a light weight flywheel and twin disc clutch.
    Junior1's Avatar
    Jun 2008
    1,248
    Haven't had any issues to date (knock on wood)
    philistine's Avatar
    Sep 2011
    821
    Called Katech...LS7 slave will NOT work with their LS9x clutch kits. Mentioned the ZR1 is the closest fit but doesn't recommend it.
    Basically, LS6 stock slave with this kit...that's it.
    Edit:
    Just got off the phone with Martin from Tick Performance. The speedbleeder is getting swapped out for a straight fitting which is the same as the 2010 Camaro. There should be no issues with the end fitting either.
    Apparently for every 5 calls they get for a straight line, they get another 5 calls for a 45 degree line. I suspect people are using different slaves for different clutch set-ups and could account for these differences.
    In my case, I need a straight line (180 degree bend, lol) and the stock LS6 slave for the travel required for the Katech LS9x clutch kit (no spacer and confirmed with Jason at Katech).
    Just a heads up, Tick Performance was very easy to deal with and rushing me a replacement ASAP.
    Thanks All!
  16. Remove Advertisements
