nitrous question
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
2004-2007 Cadillac CTS-V Performance Mods Discussion, nitrous question in Cadillac CTS-V Series Forum - 2004 - 2007; Hello everyone, I have a question I was looking into moving my single fogger to hide it better. I was ...
    LasCruces-V is offline Cadillac Owners Member
    Automobile(s): 2005CTS-V, 2006 CTS
    Oct 2009
    31
    57
    nitrous question
    Hello everyone, I have a question I was looking into moving my single fogger to hide it better. I was googling the best locations. I was looking at my intake manifold (ls6) and I have a capped port on the neck where the valve cover breather went. I tried to see if it was a good idea or not to mount it there. Which would be after the throttle body. Spraying directly into the manifold. Is this a good idea or would I be playing with fire? Thanks in advance.
    sammyboy is offline Cadillac Owners Member
    Automobile(s): 04 cts v
    Apr 2013
    30
    Re: nitrous question
    Bad idea foggers need to be ran through the maf.
    DMM's Avatar
    DMM
    DMM is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2010
    Maryland
    40
    389
    Wow....just wow. No on the port and absolutely no on the MAF. NOS requires atomization which is why the port on the intake is a bad idea. If I need to explain why NOS should not be run through the MAF, you're handing over your keys.
    rbzstsv is offline Cadillac Owners Fanatic
    Automobile(s): stsv
    Mar 2013
    491
    Handing over keys? You sir almost made coffee exit my nose lmao
    Oct 2009
    31
    57
    I am talking about a wet shot not dry. Even with the single nozzle premixing the n20 and fuel the fuel might cause puddling right? I was thinking the concept would be correct but was thinking if anything I would have uneven distribution throughout the cylinders if anything. I didnt know if anyone had tried it.
    Becker's Avatar
    Becker is offline Cadillac Owners Fanatic
    Automobile(s): 2006 black with tan V
    May 2013
    31
    391
    I have yet to see a Caddy have an intake explosion!!
    If you want to hide your nitrous (dont fully understand why) give nitrous express a call they make a fully hidden kit "The Money Maker" that is pretty trick. Check it out if you havnt already
    http://www.lsxtv.com/news/nitrous-ex...urce=pulsenews
    Actually I stand corrected, apparently Nitrous Outlet is the real Money Makers
    Apr 2013
    30
    Quote Originally Posted by DMM View Post
    Sorry from my experience with dry kit they are sprayed across the maf to compensate for fuel. Otherwise your tune would have to be just pig rich all the time. If I am incorrect please educate me. This is the first article I found on google http://www.go-fast.org/z28/new_to_nitrous.html . I would strongly recommend talking to Dave (n2o outlet) if you want to "hide" your setup. I have a nice 102 setup built by them it is truly a work of art.
    As far as a cheap way to hide it put the noida in the air box and tap the intake tube on the bottom wrap line in loom if its a wet kit.
    Hammar is offline Cadillac Owners Member
    Automobile(s): Cadillac CTS-V
    Mar 2007
    Illinois
    96
    Just to fuel the fire, I ran 100dry through the MAF for a couple summers. It let me hide the solenoid in the fender and just run one small steel line in to the airbox, with the nozzle pointing at the MAF. The stock ECU added fuel, it ran 12.5AFR's like a champ. I considered adding a bit more fuel, but it was dead consistent so I left it alone...
    Good luck whatever you choose.
    Hammar
    Maggied 2005V
    Becker's Avatar
    May 2013
    31
    391
    I am pretty sure a DRY Kit is before the maf, hence why it is a dry kit. If you were to spray after the MAF on a Dry system the ecm would not see that it needs to add fuel right? I could be wrong but I thought this is how it worked.
    xbladr is offline Cadillac Owners Fanatic
    Dec 2008
    377
    I also thought Dry had to be pre maf but then again I would not run a dry kit.
    CTS-V_07 is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V
    Apr 2013
    North Carolina
    38
    Dry is before the maf... I would perfer a wet kit over dry kit any day though.
    Becker's Avatar
    May 2013
    31
    391
    From 50 to 125 I think Dry is well worth it as far bang and buck. Now anything more than that a good direct port is the way to go!
    Mar 2007
    Illinois
    96
    Correcto.
    I ran several hundred pounds through mine dry with no issues. I understand some folks aren't comfy with dry, to each their own I guess
    Hammar
    Maggied 2005V
    Quote Originally Posted by Becker View Post
  16. #14
    Dec 2008
    377
    Hammar can you enlighten us more on your setup. What dry kit what mods did your V have when you were running the dry kit etc.
  17. #15
    Becker's Avatar
    May 2013
    31
    391
    Check out some threads on LS1tech there is some good stuff over there. If it were me doing nitrous on my V I would absolutely go Dry. When I had my trans am I use to be on LS1tech quite a bit, and I would see these 75 - 125 jet DRY systems on various setups and they just kicked ass. Ran great very streetable, no tuning issues.. Obviously if you want more its going to be more money and also more work but I think if you did a poll on Dry vs Wet for 75-125 or 150 most would say Dry. Best bang for Buck imo.
  18. Remove Advertisements
