Hurst Camaro short throw shifter (391 6030) into the V
Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By PISNUOFF
2004-2007 Cadillac CTS-V Performance Mods Discussion, Hurst Camaro short throw shifter (391 6030) into the V in Cadillac CTS-V Series Forum - 2004 - 2007; ...
    Dan_Gurney is offline Cadillac Owners Fanatic
    Automobile(s): 07 - CTS-V
    Jun 2010
    Arizona
    407
    For those of you looking for another shifter option for our cars (well it has been mentioned before) the Hurst shifter for the new Camaro (391 6030) fits our cars with very little modification.
    It really only requires 2 modifications:
    1. The Hurst shifter cup diameter is too small for the CTS-V metal retainer. I cheated on mine and wrapped it in electrical tape until it was snug. It probably doesn’t really need anything as once the cup it torqued down it will hold it in place, but this was easy, and **should** last.
    2. The bottom of the shifter is too narrow by .2” I had to find some washers that fit in this gap. Conveniently the bushings from my PISNUOFF fit perfect into the Hurst shifter, so I reused those instead of the Hurst ones. (although I am not sure that the Hurst ones don’t work great)
    3. Ok maybe a 3rd modification. I had to add some washers under the ears of the CTS-v metal shifter cup (The CTS-V one) to account for the thickness of the hurst shifter flange that sticks out under it.
    Here are some overall pictures of the Hurst shifter vs. my PISNUOFF shifter. (note my modified stocker was also shortened 1” at the top from stock) As you can see the Hurst shifter is even shorter than my short stock shifter. The shifts definitely take some more effort, but they do feel good. Being a Hurst shifter you can easily change the top half of the shifter out though. If you want stock length you can buy a 5387238 (marked 7238 on stick) stick and be right about stock height (and with no angle backwards)
    The length below the pivot is about the same length, but the shifter pivot is raised so there is even more driveshaft clearance than the modified stock shifter, although this does raise the shifter into the car by the same amount.
    How does it work? GREAT! (although I don’t know that I would say any better than my modified stocker) I primarily did this because I wanted the HURST logo sticking out of my shifter boot. I had threaded my stock shifter to accept a Hurst shift knob and that looked good, but I think this is better. (I just need to get a black knob for it now)
    The shifter does sit back a little further now as the Hurst shifter has a curve to it, this doesn’t seem to be too big of a deal but could be good or bad for you. As a Hurst shifter though, this feature is replaceable so you have a lot of options here. You can see my custom redline shift boot as well. I had this one made a few inches shorter than stock to account for A. the shorter shifter, and B. to make sure the shaft is visible.
    PISNUOFF Guest
    Re: Hurst Camaro short throw shifter (391 6030) into the V
    I just modified one to work in our cars yesterday. I cut the ears and shortened the body, made a sleeve to adapt it for the OD and made a wider bushing. I'll be making my own shifters with this design soon. Also, the length below the pivot is longer than my modified ones but sits higher into the cabin so there is another .100" clearance to the driveshaft. The spherical bushing used as a pivot is a real nice setup that I've been wanting to use for quite some time.
    lollygagger8 and Dan_Gurney like this.
    Jun 2010
    Arizona
    407
    Quote Originally Posted by PISNUOFF View Post
    That would be the ideal way to do it, but more work than i felt like throwing into it at the time.
    I keep hearing about this new shifter you want to make, I can't wait to see what you come up with.
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    Nice job! Loving the classic look!
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    I'll post up pictures when I get around to the install. I am lagging on ordering the new bushings from Luke so I'll get those ordered this week. And I'll try and do it all next week.
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    To the OP, how is the shifter holding up? Did you have to make any more modifications?
  9. Remove Advertisements
