SHIFTER: Dissecting, and fixing the CTS-V's shifter... - Page 5
Page 5 of 5 FirstFirst 12345
Results 61 to 70 of 70
Like Tree12Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, SHIFTER: Dissecting, and fixing the CTS-V's shifter... in Cadillac CTS-V Series Forum - 2004 - 2007; Im rarely on here anymore as the v is long gone. Its interesting to see where things have gone. I ...
  1. #61
    lasstss's Avatar
    lasstss is offline Cadillac Owners Connoisseur
    Dec 2003
    Ellicott City
    2,873
    SmileRe: SHIFTER: Dissecting, and fixing the CTS-V's shifter...
    Im rarely on here anymore as the v is long gone. Its interesting to see where things have gone. I will blow my own horn.
    I supplied the first shifter to UUC to make the first replacement. It needed all of the help it coiuld get. I also created the first urethane bushing kit for the crappy shifter including the front bushings. I ha s a shoulder bole in the shifter handle though.
    Also made the first door lock lifts, radio knobs and gage pods in the ash tray. I was busy back in 2004. Nice to see everyone enjoying all of this stuff.
    On the shifter, what I did was a band aid that made a micky mouse remote shifter better! Its became a better bad shifter. What was needed was a trans with a tailshaft that fit the car! But a bigger issue that that is the early differential but thats another story. Good luck all..
    Marty
  2. #62
    Tom400CFI is offline Cadillac Owners Member
    Automobile(s): '05 CTS-V
    Jul 2009
    Park City, UT
    46
    91
    Quote Originally Posted by PISNUOFF View Post
    Try dynamat first.
    Seriously. That is what this thing needs.
    So I cut my shift lever/stalk again, racked the rubber/goober part back onto the upper lever the slid that back down over the lower -basically putting it back to stock (just the shift lever portion. Result? That solved the noise issue completely. THe only remaining noises are driveline chuck or whip, is pretty noticeable when depressing the clutch quickly, and the shifter knob rattles -which it always has. So I believe that the two piece shift lever solves the noise issue. At what expense? Not too much. The quality of the shifting feel is still about the same. The accuracy, precision feeling to it is still there, and there is still no play or slop in the system. There IS, of course, compliance in the rubber in the shifter, so once it's in a gear, you can force the shift lever to bend or deflect some.
    Quote Originally Posted by lasstss View Post
    It became a better bad shifter.
    Yep. That is what is going on here too, for the most part. The shifter is a total piece of crap. I've made it way better, but in principle, it still sucks. The goal (not my goal in this thread) is to manipulate the internal shift rail. The fewer number of parts and joints you have between your hand, and that internal shift rail, the better. The V probably has 20 pieces between your hand and that rail. It's a joke.
  3. #63
    Jul 2009
    Park City, UT
    46
    91
    So now I've gone and busted into the shift KNOB. Not including the two pices of "leather", the shift KNOB, is made out of 5 pieces of junk!! I don't know what others think, but in MY mind a shift knob is one piece, w/a cover and maybe separate shift pattern. 5 pieces! Here are 4 of them (shift pattern didn't make it into the pic)
    So, the shift knob rattles b/c the part in the middle there, is loose fitting inside the actual molded handle. It is hard plastic and of course the handle is hard plastic too, so the handle moves around like a "bobble head" on the center piece. I whipped up some epoxy and turned the whole thing into one solid unit. Put the leather back on and it's setting up now.
    The Mythbusters proved that you CAN, polish a turd! So I am proving it too!
  5. #64
    Headhunter Pro Mod's Avatar
    Headhunter Pro Mod is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Oct 2013
    World Wide
    3
    Good job Tom, I like it and will use your ideas on mine thanks!!!
  6. #65
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    Quote Originally Posted by HAMSTAR View Post
    ^ offer something up. I will buy it, as will others.
    Great work.
    I'm trying to resurrect this thread because we have forum members who have the talent and the desire to offer us quality products. In my feeble mind, this project makes a lot of sense! Feedback/encouragement is appreciated!
    MarkOne likes this.
  7. #66
    Jul 2009
    Park City, UT
    46
    91
    UPDATE: It was a good improvement, but much better craftsmanship would have to be used to make it last. The glue I used to glue the upper shifter to the lower, keeps failing. I've glued the thing at least 4 times.
    The guide pin broke off during some very aggressive shifting, which eliminated much of that "precision mechanical" feel. It still shifts good, and much better than it did before (before you couldn't even get it in first or reverse 1/2 the time), but over all, I think the BEST solution to this problem is to reduce the number of parts in the system. I "polished a turd"; I MADE the shitty stock shifter "feel good", by giving the actual shift lever a guide. But it's still a mess.
    I wouldn't put any more effort into my version of this shifter (improving what I did). If I pursue this further, what I plan to do is remove and lengthen the internal shift rail, and then attache the shift lever directly to that, through a precision universal joint and shaft, very much like the shifter in the C4, ZF6 transmission.
    Less parts, stronger parts, it's the right way to have a good, strong interface w/the transmission, I feel. That is the way to go, IMO.
  8. #67
    Feb 2009
    Greenville sc
    45
    992
    Based on your lead, I welded tabs (not tubing) to my shifter base, bolted it to the transmission, ditched the gate option but went one further by modifying the shift linkage to capture both sides of the shift shaft coming out of the transmission so that it looks like a hurried but functional version of the linkage outlined in the link below...
    http://www.cadillacforums.com/forums...ul-thread.html
    With all this in combination with a 54 shifter, My car shifts comparably well to any massed produced car I've ever owned. Could it be better, sure I guess but it is what it is....a massed produced GM vehicle.
    While the route you're proposing seems fascinating to some degree, I can't imagine what a pain in the axx that would be. FuzzyLogic suggested that Tremec will be introducing a new MagnumXL that will have an extended shift rail/tailshaft which would be ideal...
    http://www.cadillacforums.com/forums...-2014-a-2.html
  9. #68
    hefftone's Avatar
    hefftone is offline Cadillac Owners Member
    Automobile(s): LS2-V
    Jul 2014
    Dallas, Ga
    84
    Quote Originally Posted by ctsv247 View Post
    ...I welded tabs (not tubing) to my shifter base, bolted it to the transmission...
    I'd like to see how you did that. Got any pictures?
  10. #69
    Feb 2009
    Greenville sc
    45
    992
  11. #70
    jcozine@gmail.com is offline Cadillac Owners Member
    Automobile(s): '06 CTS-V
    Apr 2014
    Orange, CA
    29
    10 millionth sloppy shifter thread - my advice
    Just posting this in case it helps anyone else - I installed the pissinuoff short shifter to try and tighten mine up. After a month or two the knob itself had a rattle, and the knob came loose from the post so it could twist, so I took it apart and found that the top half of the shifter had separated from the bonded-in rubber isolators on the bottom half. Anyway, I bonded it back in place with good rubber glue (motocross grip glue actually), and also threw some glue in between the knob and shaft, and it all feels SO much tighter now.
    The other thing I learned when I first replaced it was that a lot of my lateral slop was due to the looseness of the bolt at the bottom of the shifter (the bolt going through ball bearings on the fancy ones). I don't even want to get started on how poorly designed that bolt and joint are, but just replacing the socket head bolt with a high grade shouldered hex head bolt that you can crank down on with a lot of torque would've fixed a lot of the play I had. The rest of the new parts didn't really make much of a difference.
  12. Remove Advertisements
