Alignment information
Results 1 to 4 of 4
2004-2007 Cadillac CTS-V Performance Mods Discussion, Alignment information in Cadillac CTS-V Series Forum - 2004 - 2007; Ok I searched the V1 sections and read the FAQ and did not find this. Which surprises me. Alignment and ...
    vms4evr is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS
    Feb 2010
    119
    Alignment and options.
    So what does it come factory?
    How much can you get, typically, for camber, front and rear?
    What are some good good numbers for caster on the car to keep the steering feel good at higher camber settings?
    Does this tend to like a bit of toe-in in the rear like the C5? (it is a split axle that looks about the same).
    This is on a stock V1, no mods. Just curious.
    I'm going to throw it on a premium Hunter rack and find out anyway.
    This would just save me some guess work.
    If I messed a good discussion this then I apologize if you can point me to a thread that covers this.
    Thanks,
    PISNUOFF Guest
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    As a data point I have been running the aggressive street setting in that link for two years and I love it.
    I'd suggest a bit of toe to adjust for the crown in the road. Otherwise it's a good compromise between the stock settings which leave the steering kind of vague and the full race specs.
    My last set of tires wore even with that alignment. Didn't even bother rotating them as the wear was equal all around.
    Sent from AutoGuide.com Free App
    Feb 2010
    119
    Re: Alignment information
    Thanks guys. The only difference I see from what I use for street and track settings on my Z06. The Caddy has more camber to the rear.
  7. Remove Advertisements
