Can't shift into 4th after revshift tranny insert.... help
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Like Tree6Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Can't shift into 4th after revshift tranny insert.... help in Cadillac CTS-V Series Forum - 2004 - 2007; I installed revshift craddle, diff and tranny bushings. Finally took the car for a test drive and it won't shift ...
    platinum_V is offline Cadillac Owners Member
    Automobile(s): 2005 platinum Cts-V
    Dec 2012
    30
    67
    I installed revshift craddle, diff and tranny bushings. Finally took the car for a test drive and it won't shift into 4th. It shifts into 4th fine when I'm not moving, but when I'm driving it just sounds like its not grabbing the gear. Any suggestions?
    I do have an aftermarket shifter but can't remember the name, the previous owner put it in.
    NickL84's Avatar
    NickL84 is offline Cadillac Owners Member
    Automobile(s): 2005 Cts-V
    Jun 2012
    Boston, MA
    32
    39
    Re: Can't shift into 4th after revshift tranny insert.... help
    It sounds like something is out of alignment, and when you're driving, that's when it puts the greatest difference on the drive train. I would recheck every bushing and make sure they fully seated first. I know a few others on here will chime in eventually, as this has been mentioned before.
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Some people have reported interference with the old design PISNUOFF shifter. Post a pic so we can see if that's why you've got.
    Dec 2012
    30
    67
    I thinl I figured it out... I took the actual mount off the tranny, so when I put it back on, I guess I messed up the alignment of the mount/tranny?
    I'm going back under to raise my tranny and tighten the bolts from the mount to the tranny without it resting on the crossmember.
    I'm pretty sure it wasn't a PISSUOFF shifter, the previous owner told me what it was before and I know it wasn't from PISS.
    Nope. Made it worse, now its hard getting into 2nd also.
    PISNUOFF Guest
    The shifter/linkage is hitting the boss on the top of the transmission or the driveshaft. There have been enough debates about who's part does what to make it hit. Lets just leave it at most aftermarket shifters hit when used in combination with the Revshift trans insert or the UUC trans mount.
    You should first make sure the nylon pivot ball housing is flipped upside down inside the bezel. This will raise the entire assembly almost 1/4" and most likely fix your issue. If not, there are a couple other things you can try.
    Here are two pics of the different positions of the nylon housing and how it effects the pivot ball height.
    Stock:
    Inverted/upside down:
    NickL84 likes this.
    Dec 2012
    30
    67
    Ok ill try flipping the pivot ball first..
    Can I get to that from inside the car?
    Nvm. Already did it and now I'm putting it all back together. Hopefully it worked
    HAMSTAR likes this.
    Dec 2012
    30
    67
    Thanks a lot PISNUOFF! It fixed the problem completely!
    The car feels amazing now! Its incredible the difference that a couple of bushings make. It shifts better/easier, handles better and no wheelhop at all! For only $250 for all, you can't really ask for more.
    Congrats Revshift ; you have another satisfied customer.
    nikon's Avatar
    nikon is offline Cadillac Owners Connoisseur
    Automobile(s): 05' CTS-V
    Feb 2006
    Palm Beach Gardens, FL
    31
    3,718
    http://tpis.com/
    S
    hifter is from them. Just a modified stock shifter.
    Dec 2012
    30
    67
    Thanks justin. I got it all working great now. You should have done this! The car drives like a totally different car. Its amazing
    VscharesV is offline Cadillac Owners Member
    Automobile(s): 05 cts-v
    Jul 2011
    30
    22
    I did all of the bushings also, and have zero wheel hop as well. Do you have aftermarket axles? I honestly don't think the axles are needed to fix the wheel hop.
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by VscharesV View Post
    Easy killer.
    What tires do you have?
    PISNUOFF likes this.
    PISNUOFF Guest
    Quote Originally Posted by platinum_V View Post
    Thanks a lot PISNUOFF! It fixed the problem completely! ...
    Glad it worked.
    Jul 2011
    30
    22
    Haha figured that would ruffle some feathers. Goodyear eagle gs-d3 270's with around 7/32's
  16. #14
    PISNUOFF Guest
    It makes sense that stiffer cradle bushings will help with wheel hop. That was GM's fix with the nylon inserts for the '04-05's.
  17. #15
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    I have almost no hop with the cradle bushings and stock axles. No fear of doing burnouts with 150k. That being said, my burn out marks do show signs of possible hop, even though it is not felt.
  18. Remove Advertisements
