Major vibrations after Corsa Exhaust install
Results 1 to 13 of 13
Like Tree5Likes
  • 2 Post By rand49er
  • 1 Post By barrok69
  • 1 Post By rand49er
  • 1 Post By Cattivod
2004-2007 Cadillac CTS-V Performance Mods Discussion, Major vibrations after Corsa Exhaust install in Cadillac CTS-V Series Forum - 2004 - 2007; Only seems to happen between 25-35km/hr and is MUCH more violent when car is cold... Any ideas or anyone have ...
    Cattivod is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    May 2013
    7
    Any ideas or anyone have this issue ?
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Re: Major vibrations after Corsa Exhaust install
    Put it on ramps, jackstands, or a lift and take a closer look. Look for any areas where the exhaust is touching the chassis, rear-end, or transmission. Make sure all fittings are snug in the sockets and properly tightened.
    Sometimes it takes a little driving around and re-adjustment to get it just right but...that is unusual for the Corsa exhaust.
    Just a FYI, I also notice vibrations around 2k rpm and 20-35 mph. In my case I suspect the dual mass flywheel boat anchor.
    eagle-co94's Avatar
    eagle-co94 is offline Cadillac Owners Fanatic
    Automobile(s): '09 V, '10 SRT8 Chlnger, '96 Impala SS, '85 Mini, '11 9C3
    Jul 2013
    Hollywood, FL
    151
    I'm guessing it's one of the connections and once the exhaust heats up it tightens up. Have you noticed it being louder before it's warmed up?
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Quote Originally Posted by philistine View Post
    I have an Ls7 clutch and ATI super damper. Vibration at 2k PM is still there. aAnd will be till the end of time.
    May 2013
    7
    Well to clarify the vibration...it actually feels like a "jack hammer" is banging from under the arm rest. What's crazy is it doesn't happen when the car is warm after about 10 minutes...the first couple of times I felt the need to pull over. Then it gradually gets better as I continue to drive...
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    When I first installed my Corsa, I had tightened everything while it had drooped down on that little crossbar mid-way back. It made quite a rattling sound especially at certain RPMs. I went back, loosened it all back up, then jacked it up against the underside of the carriage before retightening it all. Voila! The exhaust didn't touch that crossbar anymore and no more noise.
    Not sure if yours is that, but it's easy to check and is cheap to fix.
    barrok69 and Cattivod like this.
    philistine's Avatar
    Sep 2011
    821
    Quote Originally Posted by HAMSTAR View Post
    Hmm, I wonder what my luck will be with the Katech LS9 clutch and Fluidampr crank pulley.
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,372
    How is the trans mount?
    barrok69's Avatar
    barrok69 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Maggied
    Mar 2012
    Michigan
    271
    I had a similar issue with the corsa on my V. It was resting on the thin chassis cross brace like randy pointed out. It was easy to fix, just re-adjust a few joints and voila.
    Cattivod likes this.
    May 2013
    7
    I just put rev's in
    I'm going in on Friday to have the exhaust adjusted will keep you guys posted. Thanks a lot for the feedback Gents MUCH appreciated
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    Quote Originally Posted by Cattivod View Post
    ... I'm going in on Friday to have the exhaust adjusted ...
    In half an hour with a couple of rhino ramps and a couple of jack stands, you could do it yourself. Then, you won't even have to go to the gym afterward.
    May 2013
    7
    So shes up on the hoist and there's plenty of space between the exhaust and the cross bar...no sign of real play or wear spots on the frame.
    Any ideas ? Thinking we may still tighten the exhaust up a bit
    Put some rev shift flex mounts in with the exhaust going to switch back to OEM and try that. Maybe it's drive related...
    May 2013
    7
    Problem solved. I went back to the OEM flex mount and shimmed the cross bar beneath the exhaust and problem has been solved.
    Happy Happy
    barrok69 likes this.
  16. Remove Advertisements
