Monster Stage 2 Clutch & 28lb Flywheel - Vibration in Clutch Pedal ? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Like Tree4Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Monster Stage 2 Clutch & 28lb Flywheel - Vibration in Clutch Pedal ? in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by HAMSTAR I've seen some posts that this happens when you mate a stock LS2 90 TB to ...
  1. #16
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Re: Monster Stage 2 Clutch & 28lb Flywheel - Vibration in Clutch Pedal ?
    Quote Originally Posted by HAMSTAR View Post
    I've seen some posts that this happens when you mate a stock LS2 90 TB to a 102 opening. The solution is purported to be an adaptor designed by VMax called the velocity ring. I'm curious to hear what Frost has to say.
    Mine's a Nick Williams 102 TB....almost stick your fist through the prick lol.
    If anyone is able to get the car tuned right, it's Frost. I'll let you know what he has to say.
  2. #17
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Quote Originally Posted by lollygagger8 View Post
    That's interesting, because I thought a 102 TB to FAST 102 would not result in the erratic idle/idle search problem. Please do let me know what he says.
    Quote Originally Posted by PISNUOFF View Post
    I installed the vmax ring on my 102 with a 90 mm tb. I don't have the erratic idle issue.
    Did you install in anticipation of a problem or did you install it to cure a problem with erratic idle/idle search? Also, wondering where you bought it from?
    OP, sorry to go so off track.
  3. #18
    Apr 2008
    Indiana
    4,913
    That's interesting, because I thought a 102 TB to FAST 102 would not result in the erratic idle/idle search problem. Please do let me know what he says.[COLOR="Silver"]
    He's still tuning it, but he said the lightweight flywheel (18lb) is the culprit.
  5. #19
    Apr 2012
    Seattle, WA
    731
    Hmmm... seeing as how I installed both at the same time, that could be. Please see if you can get any information from him as to why a lightweight flywheel could do that.
    Thanks!
  6. #20
    voodoochikin04 is offline Banned
    Automobile(s): 2003 cts, 2004 Cts-v
    Nov 2012
    Norfolk, NE (eastern Nebraska)
    31
    316
    Bringing up an old thread.. I just finished my LS7 clutch and flywheel install. Used a set from lindsay cadillac. stock ls7 flywheel/ clutch/ slave/ new cts-v pilot/ arp flywheel bolts/ stock pressure plate bolts. I had fully intended to get the wheel and plate balanced, and slacked off... then kind of spur of the moment we decided to replace it this long weekend, so I didnt get it balanced (beyond factory balance). Everything went fairly smoothly other than a few pain in the butt bellhousing bolts. I torqued the pressure plate bolts to 48ft -lbs according to advice from multiple posts by fuzzylogic. I torqued the flywheel bolts to 85ft-lbs according to the arp instructions using locktite and arp tru-torque moly lube. Bleeding the clutch was as painless as possible using the tick performance speed bleeder.. right off the bat air came out of the line, then dark fluid, then southern coffee, then clean fluid and no air other than initially. Pedal felt great right off the bat. engagement happens about 2" off the floor and has been creeping up over the last 60 miles. What i've noticed is that about 2200rpms I get a light buzzing in the clutch pedal upon engagement. Also I can hear more engine noise throughout the car above that 2200rpms. Other than that it seems great so far.
    carlson_mn likes this.
  7. #21
    SevillianSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V
    Aug 2005
    Northern IN
    1,006
    Quote Originally Posted by voodoochikin04 View Post
    It's just the pulses from the cylinders firing. Hold clutch halfway and play with the throttle, you'll get a feel for it. Has to do with loosing that dual-mass FW. I know its still there in my car, but I literally forgot about it now unless I pay attention for it.
  8. #22
    Nov 2012
    31
    316
    I was just adding to the confirmation that this is normal
  9. #23
    Nov 2012
    31
    316
    Now what's not normal is the way your hands and fingers have to operate to remove one studded bell housing bolt on the passenger side... Impossible to do with anything other than a short wrench moving 1/32 of a turn at a time.....
  10. #24
    Aug 2005
    Northern IN
    1,006
    LOL, I misread that as a question.
  11. #25
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    So did the question about shimming ever get answered and after everyone's breakin periods, how do you feel about your stage 2 monsters?
  12. #26
    Aug 2005
    Northern IN
    1,006
    I think next time I'm gonna go LS7. My monster stage 2 has a slight chatter when it is cold. Seems nice and smooth once warm; but the little bit of chatter when cold can't be normal. Dealer followed their directions exactly when installing. They even called me one time to confirm a question.
  13. #27
    BigDaddy-V is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V 04 LS6
    Mar 2013
    Wylie, TX
    412
    Well you helped my me make my choice on what to go with when I do mine down the road off your last post!
    BDV
  14. #28
    Feb 2009
    Greenville sc
    45
    992
    The ls7 clutch isn't a favorite over in the manual transmission section at ls1tech. After reading the negative reviews, it seems that most are posted by 4th gen f-body guys. They seem to have better luck with the monster stage 2 but i think the factory f body hydraulics may play some role in their problems....maybe.
    The v1 seems to do well with the ls7 from all you read here (on a stockish motor at least)....seems like a no brainer at this point!
    Thanks guys!
    BigDaddy-V likes this.
  15. Remove Advertisements
