Creative Steel WIDE WHEEL TRAILING ARMS - Page 7
Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 107
Like Tree18Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Creative Steel WIDE WHEEL TRAILING ARMS in Cadillac CTS-V Series Forum - 2004 - 2007; Yeah just got mine today too...pretty badass!...
  1. #91
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Re: Creative Steel WIDE WHEEL TRAILING ARMS
  2. #92
    sssnake's Avatar
    sssnake is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Dec 2008
    Huntsville
    48
    291
    Mine arrived as well.
  3. #93
    philistine's Avatar
    Sep 2011
    821
    I posted this on LS1tech and in the general section with my "pig in slop" mega do everything and lots of trial/error and bolt on stuff thread.
    Creative Steel Trailing Arms came in. You only need 4 spacers, I got an extra pack.
    Here's a comparison:
    The OEM bushing came out in about 1-2 minutes. Spray it with PB Blaster and push it out with a screwdriver.
    They look pretty good installed:
    Notice the spacers top and bottom, torque to 66[ft-lb]
    Torque this one to 129 [ft-lb]. Notice the bushings are not squished and bulged.
  5. #94
    BradCTSV is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 2005 CTS-V
    May 2007
    114
    I got mine on Thursday and they will be installed Monday. Looking forward to driving!
  6. #95
    Manofmetal01's Avatar
    Manofmetal01 is offline Cadillac Owners Fanatic
    Automobile(s): 06 CTS-V Kooks 1 7/8, Corsa, KW Var 3, Hotchkis sways
    Apr 2012
    Alberta, Canada
    183
    I'm beginning to realize I need to drop the cradle to get to and remove the forward most bolt. Has anyone had luck any other way? Otherwise looks like ill be continuing bright and early.
    Quote Originally Posted by barrok69 View Post
    the impervious bubble wrap/plastic wrap job
    More like impenetrable. Took me a good 10 mins to get them out! Why weld your parts together when you can just wrap em like this!?
  7. #96
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,306
    Quote Originally Posted by Manofmetal01 View Post
    I don't remember who it was, or if they're even on the forums anymore, but I remember one knucklehead cut holes from above so he could access the bolts.
    And the bolts are long enough that you can't feed them in from the bottom when you put things back together - the extra length above the subframe will contact the frame rail above it.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  8. #97
    CSTech's Avatar
    CSTech is offline Cadillac Owners Member
    Automobile(s): 04 CTSV
    Jul 2013
    50
    I'm beginning to realize I need to drop the cradle to get to and remove the forward most bolt. Has anyone had luck any other way? Otherwise looks like ill be continuing bright and early.[COLOR="Silver"]
    You should be able to disconnect the shock, jack the body of the vehicle up, loosen the rear sub-frame bolts a ways but still have them in, and then take out the front sub-frame bolts. The cradle should come down enough to get the front trailing arm bolt out.
    Jordan @ Creative Steel Inc.
    503-316-1811
    Open M-F 8:00-5:00 PST
    Jordan@creative-steel.com
    Check us out at: http://www.creative-steel.com
    We're on Facebook! https://www.facebook.com/pages/Creat...39612609499435
  9. #98
    Apr 2012
    Alberta, Canada
    183
    Yes, I found an old MAPerformance thread for installing trailing arms, shouldn't be too much hassle at all.
    Also read of guys cutting down that bolt and installing it from the bottom...in my industry, you never install a bolt from the bottom.
    How about removal of the bushing without removing the control arm? That's where I'm at now and its getting frustrating haha
  10. #99
    AAIIIC's Avatar
    Aug 2007
    6,306
    Which bushing? The one that's in the bottom of the rear knuckle? It's very squishy, comes out pretty easily - I just used a bigass C-clamp to push it out.
  11. #100
    Apr 2012
    Alberta, Canada
    183
    Ill try that, it would be easier if I was off the ground more. I'm not a small person by any means
    Did you remove the rotor to do this, that'll probably make my life easier!
  12. #101
    May 2007
    114
    I just got my trailing arms and toe rods in the V and noticed an immediate benefit in the way the chassis responds to bumps in a turn...the rearend stays much more planted so the shocks can do the work. I'm looking forward to driving on my favorite twisty roads to feel the full effect.
    The workmanship and design is very well done!
  13. #102
    AAIIIC's Avatar
    Aug 2007
    6,306
    I'm pretty sure that I did remove the rotor. I used the big C-clamp, and then had a chunk of exhaust piping or something like that as a receiver for the bushing to be pushed into.
  14. #103
    Apr 2012
    Alberta, Canada
    183
    I ended up just drilling two holes through the rubber and then putting a vise grip on the sleeve and twisting it out. Pretty easy. Need to do some more driving now!
  15. #104
    May 2007
    114
    Driving Feedback, trailing arms & toe rods: in 20 - 50mph twisty roads the rear is much more planted, less sideways shifting in the rear, I feel more of the vertical suspension travel when I accelerate out of the turns I feel more of the squatting of the rear...I have 64k miles on the stock trailing arms and toe rods so assuming I'm feeling a lot of the new bushing benefit. On high speed 60 - 80mph long steady carving turns when I turn-in the rear now feels much more confident in the way it carves with the front of the car....whereas before it felt like the rear was ever so slightly disconnected and I had to do slight steering inputs to keep the rear on-line. In an 80mph turn with a bump in the middle the rear just goes vertically up and down versus it used to go slightly diagonal so I'd have to catch a little with steering input. I went out after heavy rains so didn't want to push the cornering g's too much...I look forward to getting out in the dry to push the limits & feel if recovering from a slide will be easier.
    Overall this is a great improvement!! Much more confidence inspiring to push toward the limit and much more solid feel in the rear. Only thing is now with more clearance at the backside of rear wheels...I'm tempted to order wider rims/tires!! I already have 9.5" ccw sp600's with hankook rs-3 275's I want to stuff wider tires up front.
  16. #105
    Apr 2012
    Alberta, Canada
    183
    What greaseis recommended for these and the tie rods? Do the ballistic joints need a different grease or everything the same?
  17. Remove Advertisements
