APR splitter available - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
2004-2007 Cadillac CTS-V Performance Mods Discussion, APR splitter available in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by jclayc yeah, the supporting structure is more important than the splitter itself, in my opinion. I've been ...
  1. #16
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    Re: APR splitter available
    Quote Originally Posted by jclayc View Post
    I've been thinking about a more aggressive wing too - Junior, which wing are you thinking about?
    Those guys are using the APR GTC-500. I've also checked with Crawford, which is who makes the ones in Grand-Am. I did not call Pratt
    Neither are specific to the V. You basically give them the measurements for the supports and overall width (in my case determined by CCR).
    For all carbon fiber budget around 1500-2k
    Quote Originally Posted by FuzzyLogic View Post
    Junior, have you discussed or considered having molds made that would replace the stock foglamps with full-blown inlets? I've got a couple of potential manufacturers here, but I'm not sure whether to mock up tubing that would channel cold air to the rotors or the engine bay (or both). The idea of building a ram air inlet for the cold air intake tube is intriguing, but that would lead to an asymmetrical cooling design unless I simply ran air past a vertically-oriented air filter and then to the driver's side rotor.
    I looked into it briefly. I had enough into it with 3 sets of ducting and fabwork.
    D3's are one offs made out of sheet metal that serve to cool brakes and their oil cooler IIRC.
    For Grand-Am, Powell removed the whole assembly and added tubing just for the brakes. They simply zip tied it to the mesh. Yooper had something similar I think
    The old T2 cars had the assembly cut in half removing the fog light portion, again with tubing for the brakes.
    My setup just uses the stock openings with carbon fiber mated up.
    I think the biggest issue that will come up is that the ECU is mounted on the leftside just above the assembly and that poses the most issues for clearance with the ducting and any ram-air intake setups. Of course anything is possible with enough money but it may get cost prohibitive for some, especially losing the fog/turning signal in the process.
  2. #17
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    If I had something built, I would replace the turn signal with a vertical hybrid LED bar or a pair of bars. I'm glad you mentioned the oil cooler--that sounds like a worthy objective for the passenger side duct.
  3. #18
    xbladr is offline Cadillac Owners Fanatic
    Dec 2008
    377
    junior post up some pics when you get it
  5. #19
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by Junior1 View Post
    BTW: Mike, clear out your inbox
    PM sent. I also picked up a splitter from Sean. We can compare notes when we get them mounted.
  6. #20
    barrok69's Avatar
    barrok69 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Maggied
    Mar 2012
    Michigan
    271
    I did a quick photoshop of the APR splitter from the ebay auction.
  7. #21
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by barrok69
    URL]
    Looks good. A little piece of the rubber lip is still visible but overall a great rendering.
  8. #22
    barrok69's Avatar
    Mar 2012
    Michigan
    271
    Quote Originally Posted by crankedupforit View Post
    Thanks. I left it there on purpose actually. I wasn't sure if you guys remove that piece on your full race cars or not. For a street car it's quite beneficial from an aerodynamics/Fuel economy perspective.
  9. #23
    Junior1's Avatar
    Jun 2008
    1,248
    Quote Originally Posted by barrok69 View Post
    It would come off and this would mount flat, directly to the underside of the bumper.
    Mike you get that PM/email I sent?
  10. #24
    Feb 2007
    Cheese land
    1,596
    Yes. Thanks Chris.
  11. Remove Advertisements
