Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: still clunking
    KB V is offline Cadillac Owners Member
    Automobile(s): 2006 CTS-V
    Apr 2012
    Orlando
    85
    still clunking
    After ls7 clutch kit, revshift motor mounts and trans mount insert, cs diff bushing and block. Should I try rev shift flex disc? Much cheaper option than cs 8.8 kit. Is the 8.8 the only way to lose the clunk?
    Revshift is offline Cadillac Owners Fanatic
    Automobile(s): none
    Apr 2011
    Warren, MI
    258
    Re: still clunking
    The Revshift diff bushing would most likely help. Get under the car and inspect your flex disk. If it is not cracked and it looks like everything is solid then it most likely is not the issue.
    Apr 2012
    Orlando
    85
    Re: still clunking
    Quote Originally Posted by Revshift View Post
    I am a Revshift fan, but I find it hard to believe that the diff bushing is so much better than creative steels. I am not trying to start a debate, I am just frustrated.
    The original diff bushing I took out (before adding cs bushing) was in near perfect shape. The original owner had the diff brace on (it's off now because it made it noisier). So, I'm thinking the only less than solid part is the flex disc. The shop that installed my clutch said the disc looked good.
    I'm suspecting that it's the diff that is clunking.
  5. #4
    Automobile(s): none
    Apr 2011
    Warren, MI
    258
  6. #5
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    FWIW I have more clunk after installing the revshift diff and cradle bushings. I believe the old bushings were so worn the entire diff was moving around so there was less clunk. Now that the diff is more secure, it let's me hear the slop in the posi unit or gear backlash. Bushings are great but its a gen I or II diff with 150k. What more can I expect.
  7. #6
    2007V is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V, maggie
    Apr 2011
    85
    Re: still clunking
    I just installed the revshift subframe, diff bushing and trans mount insert, most of the clunk is gone but the rear end wine is very noticeable now. I'm second guessing the diff bushing.
    Quote Originally Posted by JFensty View Post
  8. #7
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    Quote Originally Posted by 2007V View Post
    Same here with the whine. I went with red cradle and blue diff and thought I was being safe. I can usually drive around the clunk. But it is always there hiding.....
  9. #8
    Apr 2012
    Orlando
    85
    Re: still clunking
    Um, I'm not seeing a resolution with this post. Whine is ok, but I can't stand the clunk! So, is the 8.8 the only way?
  10. #9
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Re: still clunking
    My thoughts on the CS 8.8 is that is for slapping down some power. I'm sure it cures a lot of other stuff as well. I have parade clunk with the stock clutch, Revshift MMs & trans mount, and Delrin cradle bushings. I share your frustration but do not have anything to add that can solve your issues.
    I lived with the embarrassing parade clunk for quite awhile. I decided to give CS a call on the 8.8 rear end. I plan on putting my order in on Monday but that is largely due to prepping for forced induction. Based on a large amount of feedback...the 8.8 kit solves the parade clunk but that is not the primary reason for purchase.
  11. #10
    Apr 2012
    Orlando
    85
    Re: still clunking
    Quote Originally Posted by philistine View Post
    Exactly! Too much dough too get rid of clunk! That's what I'm struggling with. Maybe 25k in a car that could make me happy with another 10k??? I just want to know what will work!!! plus I'm adding in 5k in cosmetics!!!
  12. #11
    Mar 2011
    2,045
    Re: still clunking
    I don't think you torqued down the front bolt well enough. That or you forgot to use loctite.
  13. #12
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    Re: still clunking
    How many miles on the CS diff bushing?
    Have you checked the torque on the front diff bolt?
  14. #13
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    Quote Originally Posted by FuzzyLogic View Post
    I can't remember the exact torque, but it was enough to start to distort the bushing on the ends. Do you have the torque spec? Yes, loctite was used.
  15. #14
    Mar 2011
    2,045
    Re: still clunking
    The stock dual-mass flywheel will always clunk. So will both the stock two-piece driveshaft and the 2-piece aluminum/chromoly driveshaft that's included in the Creative Steel 8.8 kit. Either learn to accept some amount of clunk or pay the $4600 premium for a 8.8 kit with a one-piece carbon fiber driveshaft and $750 for a good single-disc clutch.
    129 ft-lbs for all three. I doubt you torqued them that much--it's hard to do when you've got the car on floor jacks. While you're at it, make sure you torque the front and rear subframe bushings to 195 ft-lbs and 141 ft-lbs, respectively.
    http://www.cadillacforums.com/forums...ml#post2159717
  16. #15
    Apr 2012
    Orlando
    85
    Re: still clunking
    Thanks for the heads-up. I hope this helps.
  • You may not post replies
