Maggie install started - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 65
2004-2007 Cadillac CTS-V Performance Mods Discussion, Maggie install started in Cadillac CTS-V Series Forum - 2004 - 2007; The air inlet was flow tested to handle 600+ rwhp worth of air!! Whil how is the install going? Where ...
  1. #16
    blownchevy is offline Cadillac Owners Fanatic
    44
    280
    Re: Maggie install started
    Whil how is the install going? Where are you located again???
  2. #17
    Dreamin is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 ATS-V
    Feb 2004
    Calif.
    2,261
    I'll keep you posted and try to give you enough warning as to when I'm going for the rest should you want to head this way
    Wild: My offer is still open... looking forward to it
  3. #18
    Feb 2004
    Calif.
    2,261
    About the diff... make sure the insurance company is involved too... if it's accident related, they need to pay for it...
    Just had a problem like that on a different car... lots of back and forth between dealer and insurance company about something that stopped working after an accident.... eventually the dealer ended up fixing it and picking up the tab...
  5. #19
    wildwhl's Avatar
    wildwhl is offline Cadillac Owners Master
    Mar 2004
    Reno, NV
    5,496
    Quote Originally Posted by blownchevy
    No install work today, leaving the V intact for the dealer in the a.m.
    I almost went ahead and did the crank pins and heat exchanger/reservoir but decided against it. Don't want to get the dealer too suspicious.
    Northern Nevada (so close to hell (Reno) I see Sparks!)
    I'm excited to get going on it. If the dealer doesn't tear down the car tomorrow (I believe their plan is to disassemble the diff) then starting Tuesday I'll go for it (in the evening). I believe I can finish her out in two evenings, if I limit the Irish Car Bomb consumption
  6. #20
    44
    280
  7. #21
    wildwhl's Avatar
    Mar 2004
    Reno, NV
    5,496
    So, IF I EVER GET THE CAR BACK, where should I conceal a nice digital boost gauge
  8. #22
    2004ctsv's Avatar
    2004ctsv is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTSV
    Mar 2004
    Blitzburgh
    1,133
    Quote Originally Posted by wildwhl
    Reprogram the DIC with a big analog gauge picture.
  9. #23
    Feb 2004
    Calif.
    2,261
    I've been eyeing this unit: http://www.zeitronix.com/Products/zt2/zt2.htm
    Boost, wideband AFR, and EGT... and it will easily fit inside the ashtray compartment with some surgery... (For occasional checking, troubleshooting... for full time use, the ashtray is probably too low).
  10. #24
    wildwhl's Avatar
    Mar 2004
    Reno, NV
    5,496
    Quote Originally Posted by 2004ctsv
    I like it, if only it could be done
  11. #25
    lasstss's Avatar
    lasstss is offline Cadillac Owners Connoisseur
    Dec 2003
    Ellicott City
    2,873
    I have not checked but perhaps an A pillar gage pod has been made for the CTS??
    http://gaugepods.com/products.html or perhaps autometer
  12. #26
    V-Max Guest
    wildwhl, how much did the box the kit came in weigh?
    Thanks,
    Norm
  13. #27
    wildwhl's Avatar
    Mar 2004
    Reno, NV
    5,496
    2 boxes.
    One was over 70 lbs (the maggie itself - I would guess 80 lbs?)
    The second was all the rest of the stuff at about 50 lbs (guessing).
    Wild
  14. #28
    Bugeater is offline Cadillac Owners Member
    Feb 2005
    13
    Anyone know how much weight the blower adds to the car? 80pounds? Just a guess.
  15. #29
    44
    280
    After removing the stock intake and adding the blower you will net approx 60 lbs.
  16. #30
    wildwhl's Avatar
    Mar 2004
    Reno, NV
    5,496
    Day two (weekend morning number 2 really) and add 2 hours to the install. I was working on the V and running the CD74 over a 4 hour period going back and forth - so I'll call it 2 hours.
    Managed to install the heat exchanger and reservoir today as well as pin the crank. Took a little longer than anticipated due to some difficulty in pulling the radiator. There are some (4 on each side) plastic rivets that hold the radiator attached to some rubber and plastic shrouds. Tough to remove - but a long (26") screw driver did the trick.
    Also had to ream the mounts on the heat exchanger a bit to get everything to line up - a real tight fit with everything in there. Managed to get everything in place without removing the front fascia - just the lower splash guard, airbox, and radiator.
    Pinning the crank was a pretty straightforward and easy task - no worries - just follow the excellent instructions.
    So, that leaves the actual Mag install, fuel pump booster, and wiring. I'm willing to bet this is about 4 hours remaining. So that still means total install time in under 10 hours (actually about 8 if I manage 4 hours on the balance). I bet two guys together with at least 12 Fat Tires or 6 Irish car bombs could manage start to finish in 6 hours. Just a guess, but it wouldn't surprise me.
    Now...where's that replacement differential
  17. Remove Advertisements
