CTS-V Suspension Tuning - Page 4
Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 46 to 60 of 78
Like Tree7Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, CTS-V Suspension Tuning in Cadillac CTS-V Series Forum - 2004 - 2007; I work the drilling rigs, I have a week off at a time so ill manage. Ill figure it out ...
  1. #46
    Manofmetal01's Avatar
    Manofmetal01 is offline Cadillac Owners Fanatic
    Automobile(s): 06 CTS-V Kooks 1 7/8, Corsa, KW Var 3, Hotchkis sways
    Apr 2012
    Alberta, Canada
    183
    I work the drilling rigs, I have a week off at a time so ill manage. Ill figure it out when I've got all the parts ready to go. Youre install posts will be invaluable
  2. #47
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    Ahhh, i am runnin penske style shocks, that could be the reason behind ur high spring rates.
    As i said before, u need a little give so u may shift the weight forwards and backwards...
  3. #48
    Iceman_jd's Avatar
    Iceman_jd is offline Cadillac Owners Fanatic
    Automobile(s): 2007 3.6 CTS
    Oct 2012
    Arizona
    112
    Re: CTS-V Suspension Tuning
    Quote Originally Posted by FuzzyLogic View Post
    Which ones?
    You (and everybody else here) should know that the KW Variant 3 spring perches run a millimeter or two large. So the Swift springs are going to be a very tight fit and won't rotate until they've broken in around the ring. Apparently, it's a well-known fact to the suspension experts out there, which I didn't pick up on until I tried installing (gasp!) a 60mm thrust sheet on the 60mm KW V3 perch and a 70mm thrust sheet on the 70mm KW V3 perch.
    Had to spend 30 minutes dremeling out each set of rings with a grinding tool I bought at Home Depot. A 65mm thrust sheet will work on the back perch, but nobody sells 75mm thrust sheets. So you'll have to dremel at least one set if you want thrust sheets.
    I spent around an hour today hand fitting the 896lb Swift springs to the four KW V3 rear spring perch. Will finish the job tomorrow with the install of the spherical shock mounts.
  5. #49
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Quote Originally Posted by Iceman_jd View Post
    You probably didn't have to muscle it...just get each spring centered and let the vehicle weight do the rest.
  6. #50
    Iceman_jd's Avatar
    Oct 2012
    Arizona
    112
    Probably but if I forced it what's the point of the thrust sheets if the spring is binding on the perch. At least now the springs are able to rotate freely within the KW3 spring perches.
  7. #51
    Mar 2011
    2,045
    Any driving impressions yet? I'd love to hear what you've got, whether negative or positive.
  8. #52
    Iceman_jd's Avatar
    Oct 2012
    Arizona
    112
    Yeah got a little side tracked today going to hit it hard tomorrow, will keep you informed when job is complete and impressions formed.
  9. #53
    mackey is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Black
    Sep 2012
    172
    best place to pick up the swift springs and thrust sheets?
  10. #54
    Apr 2012
    Alberta, Canada
    183
    Quote Originally Posted by mackey View Post
    I just checked their distributor page and went with one of them.
  11. #55
    Mar 2011
    2,045
    MAPerformance for the springs, FRSport for the thrust sheets. I don't have the receipt with me, but I believe I paid $85 or $80 per spring.
    Sigfod and mackey like this.
  12. #56
    Iceman_jd's Avatar
    Oct 2012
    Arizona
    112
    Finally finished installing the 896lb Swift springs and spherical RSM. Compression set to minimum, rebound set 3 clicks minus from max setting.
    Springs pre-loaded to zero lbs, just to the point of rattle loose. With that setting my ride height is 26.25" from the ground to fender lip.
    To get it any lower I was thinking (Big mistake) if it was possible to do a mighty mouse type setup with the mounting plate on top. That should raise the lower control arm to make up the difference of the shorter swift spring and giving greater range of height adjustment (to the lower side).
    Putting that aside quick test ride was pretty sweet, I thought it turned pretty quick before, now it seems very tight with very little steering lag. Just point and shoot. The rear feels a little stiffer but not in a bad way just more planted. Overall I would recommend this mod.
  13. #57
    Mar 2011
    2,045
    Try 5 clicks. Compare it with 3 clicks. Overdoing the rebound dampening is not a good thing--you're unnecessarily limiting the rebound rate of the springs.
  14. #58
    Iceman_jd's Avatar
    Oct 2012
    Arizona
    112
    Thanks Fuzzy will back off rebound damping 2 clicks.
  15. #59
    Sep 2012
    172
    not finding the springs on map
  16. #60
    Mar 2011
    2,045
    That's because you have to call them.
  17. Remove Advertisements
